Old 08-02-2009, 09:40 AM   #1
Koolwip
Steve & Stefani
Koolwip's Avatar
Drives: 2010 Camaro 2SS/RS
VIDEO FROM WEDNESDAY NIGHT
I am going to check my sons camera to see if he has any of Lionel's IOM. My wife tried to get everyone. Enjoy!
LEGEND 13.8 / 106.5 mph
TAG 13.61 / 109.7 mph
WINGNUT 14.1 / 107 mph & CAMAROSCOOTER
KOOLWIP 13.9 / 107
TAGandKOOLWIP
WINGNUT 13.7 / 108.2 mph
Koolwip is offline   Reply With Quote
Old 08-02-2009, 12:18 PM   #2
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I gotta take out that speaker box, go out there with less than a 1/4 tank, see if I can remove some other weight, and work on that launch.
That 60ft time HAS to come down!
Good times!!!
Old 08-02-2009, 12:36 PM   #3
DeathChill
Drives: 2010 Hyundai Genesis Coupe 2.0T
DA?
DeathChill is offline   Reply With Quote
Old 08-02-2009, 12:41 PM   #4
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
Badass guys, good job!
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
Old 08-02-2009, 04:06 PM   #5
TAG UR IT
TAG UR IT's Avatar
Originally Posted by DeathChill View Post
DA?
huh?
Old 08-02-2009, 04:16 PM   #6
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
He means Density Altitude.
mike@newera is offline   Reply With Quote
Old 08-02-2009, 04:17 PM   #7
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Man those Gen4's must be really souped up beating you guys.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-02-2009, 04:30 PM   #8
TAG UR IT
TAG UR IT's Avatar
altitude is 600ft if that helps.
http://www.sanantonioraceway.com/track_map.htm
it was also 91 degrees on the first run.
it was hotter than hell on the track. wait till the temps come down a bit and the times will drop dramatically.
Old 08-02-2009, 06:59 PM   #9
"prima"Donna
HWAY STR
"prima"Donna's Avatar
WOW, THOSE ARE SOME BAD A** "BITCHIN' CAMAROS"...................cool videos...
~ HWAY STR 2 ~
Old 08-02-2009, 08:07 PM   #10
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
Yours sound pretty mean tag.
SleepWarz is offline   Reply With Quote
Old 08-02-2009, 10:42 PM   #11
97one
97one's Avatar
Drives: 2016 & 1967 Camaro, 2015 Impala, +1
Thanks for sharing those cool Videos........
97one is offline   Reply With Quote
Old 08-02-2009, 11:13 PM   #12
mike@newera
Density Altitude tells you if the cars were running slower or faster based on the Ambient conditions(temperature, humidity, etc.) so if the track is 600 feet above sea level, but it is 100 degrees and 100 percent humidity, you are basically running the cars down the track on top of a mountain if you catch my drift(meaning the times will be slower because of the weather). The higher the altitude, the less oxygen in the air which makes the engine have less horsepower/torque. Cool videos though!
Old 08-03-2009, 02:46 AM   #13
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Looks like a fun day... good times indeed.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 08-03-2009, 08:53 PM   #14
DeathChill
What day was it? The DA calculator tells you the DA if you give it the day and track name.
