BeckyD @ James Martin Chevy
Old 04-26-2014, 08:30 PM   #1
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
New Rotors/New Pads - Thumping Noise
I changed my rotors and pads earlier today on the front. Also bleed all four corners.
I just went to drive and bed them but I get a thumping noise I can hear and feel on the brake pedal. Also think I can hear it on the drivers side, but not 100%. The rotor are dealer rotors and the pads akebono for daily driving.
Bad rotor? Bad pads? Should I remove the pads and double check they are seated?
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 04-27-2014, 07:50 PM   #2
29er
29er's Avatar
Drives: 14 1LE Garage King
check back all the work you've done. make shure all is tight. why did you bleed your calipers ?
29er is offline   Reply With Quote
