Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 08-03-2009, 12:32 PM   #1
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Arrow ORACLE 5202 LED 18SMD Cool White Fog Light Bulbs for Camaro!> ONLY $79 > 20% OFF!
ORACLE Super-Bright LED Foglight Bulbs from AAC
Website Price: $99... Forum Member Price Only $79 a Pair!
http://www.automotivelightstore.com/5202special.aspx
These LED Bulbs eliminate the Yellowish Look of the Factory Foglight Bulbs with Cool White LEDs!
Easy Installation, just remove the existing bulbs and plug these in. No Wiring, Ballasts, Adapters, Just Plug and Play!
Not only do these look better but they run 150% COOLER that the factory Halogen Bulb! As you can see here:
Factory bulb after 10 Min "ON" is at 219° F
ORACLE LED Bulbs after 10 Min "ON" only at 84° F
The cooler temps mean that the foglight lenses will not fade, oxidize, singe, or microcrack which are all problems with aftermarket HID systems in this application.
Get the LOOK you want without busting your lenses or your wallet!
Camaro5 members can purcahse here:
http://www.automotivelightstore.com/...ROD&ProdID=452
www.AACstyle.com
AACstyle is offline   Reply With Quote
Old 08-07-2009, 04:12 PM   #2
AACstyle
AACstyle's Avatar
www.AACstyle.com
Old 08-07-2009, 04:28 PM   #3
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Installed pic's?
Old 08-08-2009, 11:55 AM   #4
AACstyle
AACstyle's Avatar
Originally Posted by Andro View Post
Installed pic's?
Several members have already purchased and will be posting pics soon!
If some pics installed on Dodge Chargers will hold you over here you go:
www.AACstyle.com
Old 08-10-2009, 01:59 AM   #5
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Sorry but are these for the RS or non-RS version? I really want to replace my RS foglights/running lights.
Old 08-10-2009, 08:49 AM   #6
AACstyle
AACstyle's Avatar
These would be for the non-RS type foglights.
www.AACstyle.com
Old 08-10-2009, 12:15 PM   #7
Bear
Bear's Avatar
Drives: 2015 Green Flash 2SS M6
What about the RS type Foglights?
Back in the Game.
Bear is offline   Reply With Quote
Old 08-11-2009, 11:06 AM   #8
AACstyle
AACstyle's Avatar
If anyone wants to ship their foglight assemblies (including the bulb) to our shop we can build something for the RS type DRL foglights.
www.AACstyle.com
Old 08-18-2009, 09:40 AM   #9
AACstyle
AACstyle's Avatar
Here is a pic installed on the Camaro:
www.AACstyle.com
Old 08-27-2009, 08:45 AM   #10
AACstyle
AACstyle's Avatar
Installed on another non-RS:
www.AACstyle.com
Old 08-27-2009, 05:08 PM   #11
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
are the rs housings different?
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 08-27-2009, 05:53 PM   #12
ralyrat
ralyrat's Avatar
Drives: RS/SS Vector Tuned Kooks Roto
But thats a RS?
ralyrat is offline   Reply With Quote
Old 08-27-2009, 06:54 PM   #13
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
Originally Posted by ralyrat View Post
But thats a RS?
You say that just because the Camaro in that pic has Halos? AAC makes custom Halo rings as well.. I doubt it is an RS.
2010 Camaro 1LT/RS
Mods: Staggered 20" Lexani LX15 Wheels, Airraid CAI, AAC Blue LED Dome/Trunk Lights, AAC LED License Plate Lights, AAC LED P13W Running Lights w/Harness, Metra Radio Kit, Kenwood DNX9960 DDIN Radio, JL Audio 10" W6 Sub, JL Audio 500/1 Amp, ******** Sub Box and Amp Rack, AeroExhaust Resonators
BigBOSS is offline   Reply With Quote
Old 08-31-2009, 09:33 AM   #14
AACstyle
AACstyle's Avatar
You are correct, that is a 1LT pictured above with our halo kit installed.
www.AACstyle.com
5202, 9009, bulb, h16, hid
