HeadlightArmor
Old 04-28-2014, 07:10 AM   #1
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
Sway bar support question
So Friday I decided to make sure everything in my rear suspension was tightened down, was hand tightening a bolt on the driver side sway bar support, felt it getting easier to tighten, then SNAP!!! broke the bolt head off, two days later, two trips to Home Depot and a trip to borrow a corded drill I finally got the bolt out.
My question is I bought some bolts from Home Depot and one of the guys there was saying that those bolts aren't obviously made for cars suspension and aren't up to spec. Will I have any issues or should I order some OEM bolts? I mean these bolts seem pretty tough but what do ik.
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 04-28-2014, 07:46 AM   #2
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Order the correct bolts.....most bolts at HD are Grade 2 or 8.8. There might be some Grade 5, but if you don't know what you have you need to order the correct ones
Explanation of bolt grades.
http://www.boltdepot.com/fastener-in...ade-chart.aspx
Old 04-28-2014, 12:41 PM   #3
usafboy
usafboy's Avatar
I do know the bolts that I bought have the three lines on the head, bcus I was tryin to use the three letter code on the OEM bolts to try and find a replacement. The stock bolts are 13mm but all they had were 5/16", it worked but in the long run I don't want to run into issues.
Old 04-28-2014, 02:08 PM   #4
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Not sure how you got the standard bolt in there without destroying the threads but I would use the correct bolt. Use an OEM replacement unless you can get an (Metric)ARP replacement.
...and stop breaking bolts by hand Hercules
jeremywes is offline   Reply With Quote
Old 04-28-2014, 02:43 PM   #5
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
The problem has nothing to do with the thread because there are only a couple different standardized threads available. You can get plastic bolts that would screw in just fine. This is entirely a bolt material issue as mentioned above and should be addressed with OEM or better bolts.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 04-28-2014, 04:33 PM   #6
usafboy
usafboy's Avatar
Oh I'm sure the threads are probably ruined now after putting the standard bolt in, I'll test it out tonight and see if it's possible to get an OEM bolt to go in after using the replacement bolt. If not I might be stuck with the standard bolt but might just have to find a suitable one made for suspension.
Old 04-28-2014, 04:54 PM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I would suggest a Grade 8 metric bolt (if you haven't destroyed the threads already)!!!
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 04-29-2014, 09:10 AM   #8
jeremywes
jeremywes's Avatar
Might be a good idea to run a tap through it once you remove the bolt. The other alternative since the backing nut is welded to the sub frame would be to drill a slightly larger hole and tap new threads. Good luck... and don't worry we all have a story like that.
Old 04-29-2014, 11:22 AM   #9
usafboy
usafboy's Avatar
So let me ask this, if looking at the chart posted in an earlier post, the OEM bolt was a metric 8.8 bolt, the standard replacement bolt I used is a standard grade 5 bolt with the three lines on the head.
Is the replacement bolt I got better or worse? I know the threads and size are slightly different but it worked, or at least I made it work by using the standard bolt.
Old 04-29-2014, 11:49 AM   #10
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
The bolts are roughly equivalent in tensile strength. A metric 8.8 bolt in that size has a minimum tensile strength of 116,000 PSI, and a grade 5 in that size has a minimum tensile strength of 120,000 PSI.
A "grade 8" version of a metric bolt would be the 10.8 bolt, where a 10.9 bolt has a minimum tensile strength of 150,800 PSI and a grade 8 standard bolt would be rated at a minimum tensile strength of 150,000 PSI.
The threads and diameter of what you used are close, that's why the bolt went in, but you should run the correct metric tap through the hole and install the correct bolt if there are enough threads left. If not, go up to the next size and drill and tap again.
2012LS3VERT is offline   Reply With Quote
