Jason 98 TA
Old 04-28-2014, 10:42 AM   #1
BossHogg
Mexican SS
BossHogg's Avatar
Drives: Black 2SS/RS
** Horrible Gas Mileage **
My SS has 48,000 miles on it and I haven't been noticing car running that bad at all.. But I filled up the other day and the gas like evaporated it seems like... I reset the mpg and driving around town it says 7.8 mpg.... Something isn't right..
Possible spark plugs or no??? Please help
Black 2010 2SS/RS...
Dyno Tune..
Volant Cold Air Intake..
Custom Installed Escort 9500 Ci Radar
Smoked Tail Lights-Reverse Lights -Front/ Rear Corner Lenses
Painted Bow Ties front & rear
Pacesetter Long Tube Headers
Magnaflow Competition Cat Back Exhaust....
Eibach Pro Lowering Kit
Painted Heritage Grille
1969 Camaro Emblems
Phoenix Gold I-Amp Sound System
22 inch Replica Wheels:
VMAX Ported Throttle Body
BossHogg is offline   Reply With Quote
Old 04-28-2014, 10:56 AM   #2
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Thats really low!!! What I would expect from a cammed car and a heavy foot. How many miles have you driven since the reset? Did you think your mileage was bad prior to the reset?
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-28-2014, 11:08 AM   #3
BossHogg
Mexican SS
BossHogg's Avatar
I reset it after every fill up... And I noticed gas going quickly so I went to mpg and it said 7.8 it normally says about 12.8 - 13.5
Dyno Tune..
1969 Camaro Emblems
Old 04-28-2014, 11:38 AM   #4
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Is it possible you got e85 gas by mistake?
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 04-28-2014, 11:49 AM   #5
mailclerk
Drives: 2013 Camaro 2LT/RS
BossHogg,
I wonder if you need a new air filter cleaner??? Check you tire pressure and gas it up and re-test and see what happens. Otherwise a trip to the dealership is in order.
Mail Clerk
mailclerk is offline   Reply With Quote
Old 04-28-2014, 11:54 AM   #6
BossHogg
Mexican SS
BossHogg's Avatar
Bkscott man i dont think so bro.... I sure as hell hope i didnt.. Man im hoping that its like water or something, im gonna go to shell in a few minutes and fill it up, wonder if i should also use some kinda water remover/ fuel treatment
Dyno Tune..
1969 Camaro Emblems
Old 04-28-2014, 12:44 PM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
Last time I saw something like this, it was a misfire.
I see you have a tune, so maybe the dealer is not your best option.
Rock-It Man is offline   Reply With Quote
Old 04-30-2014, 08:51 AM   #8
uniqueskillz
uniqueskillz's Avatar
Drives: ETMC built 700+hp Twin Turbo LS3
I would check wires and plugs first. I see you have headers so you might just be melting a spark plug wire.
uniqueskillz is offline   Reply With Quote
Old 04-30-2014, 09:22 AM   #9
jbb1073
Drives: 2012 RS 1LT A6
Ran into a similar issue with my V6. Nothing seemed wrong (drive-wise), but my mileage was getting horrible. After a while, I finally got a CEL (still no change in the way the car was operating). Took it to the dealer & it turned out that the Evap Solenoid was stuck in the open position.
jbb1073 is offline   Reply With Quote
Old 04-30-2014, 09:37 AM   #10
BossHogg
Mexican SS
BossHogg's Avatar
Man I hope I'm not melting a wore but if it's that then it should be an easy fix.... I'm gonna check as soon as I get to work thanks man....
Dyno Tune..
1969 Camaro Emblems
Old 04-30-2014, 06:04 PM   #11
TooCool5
TooCool5's Avatar
Its an SS which means ..... Fuse pull.
Your stuck in the wrong octane table.
Old 04-30-2014, 06:09 PM   #12
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Check for codes and go from there.
Bye bye, Bumblebee!
Old 04-30-2014, 06:47 PM   #13
BossHogg
Mexican SS
BossHogg's Avatar
I thought the fuse pull went out the window when the car has a tune in it...
Dyno Tune..
1969 Camaro Emblems
Old 05-01-2014, 03:23 PM   #14
strych9
Gone Euro!
strych9's Avatar
The fuse pull is a complete myth, but my opinion is in the minority.
Bye bye, Bumblebee!
