JDP Motorsports
Old 04-28-2014, 03:09 PM   #1
CrisisMusick
Drives: 2014 AGM 1LE/2SS/RS
Negatives to lowering Camaro?
I've been contemplating lowering my 2014 1LE anywhere between 3/4"- 1" in order to get it closer to the Z/28 stance. However, aside from of course driving over speedbumps and driveways, I've heard other negatives like the ruining the length of life for my shocks. I was looking into purchasing the BRM 1" lowering springs:
http://www.bmrsuspension.com/?page=p...&productid=836
I wanted to hear feedback on whether I should or not. My girlfriend already hates the ride on my 1LE sayings it's too "rough", but I figured this shouldn't be that different.
CrisisMusick is offline   Reply With Quote
Old 04-28-2014, 03:51 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
That's a true statement about reducing the overall life of the factory shocks/struts. However, it's hard, if not impossible, to calculate just how long they will last. Some people have lowering springs and their factory components last for years, others aren't so lucky, and only get a few months out of them. I suppose it depends on how many miles you have on them already. With a 2014 1LE, I think you'd probably be safe for quite a while without having to worry about it. Also, you can expect a little stiffer ride with lowering springs. Probably not enough to worry about, but they do have a higher spring rate over the factory springs. I hear very, very few complaints from our customers who have made the switch!!!
Old 04-28-2014, 04:42 PM   #3
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
I have my BMR 1" springs ready to go. My only concern is dragging my headers, but I'll get over that as soon as I see it
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 04-28-2014, 04:48 PM   #4
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
I had BMR 1" drop springs on my car with AR Headers and never had a problem.
Old 04-28-2014, 04:49 PM   #5
nevrenz
nevrenz's Avatar
Drives: 2011 RED Camaro
Rides stiffer and scrap my lower front splitter allot on driveways. That's about it for me. I went with BMR 1.4"/1" split kit.
nevrenz is offline   Reply With Quote
Old 04-28-2014, 05:05 PM   #6
prostcj
Drives: 05 Evo 8, 09 Mazdaspeed3, 12 ZL1
You change the roll center which usually makes the overall effect a poorer handling car.
Sent from my RM-877_nam_att_205 using Tapatalk
prostcj is offline   Reply With Quote
Old 04-28-2014, 05:18 PM   #7
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Car sits lower.
Old 05-02-2014, 12:51 AM   #8
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Originally Posted by Camaro_Corvette View Post
Car sits lower.
That's a positive.
SS PANTHER is offline   Reply With Quote
Old 05-02-2014, 10:42 AM   #9
need4spd
need4spd's Avatar
Drives: 2012 2SS Black on Black
I have bmr 1.4 all corners and it sits pretty well. But the ride is stiff. I had it for almost 2 years and shocks are still good. I will swap it though with a coil over because I need the car to be lower.
previous ride - 2010 CGM 2LT RS auto w/roof, eibach lowering springs, volante cai, mrt v2 axle back
current ride - 2012 Black on Black 2SS RS w/ sunroof, muffler delete with SLP exhaust tips, rotofab cai, gm strut brace, BMR 1.4 drop springs all four corners, Stainless Power 1 7/8 long tubes, Hex Vents, Jannetty Racing Tune, Helmholtz J pipe, MMR 228 Z28 replica wheels.
need4spd is offline   Reply With Quote
Old 05-02-2014, 11:39 AM   #10
Nor Cal ZL1
Nor Cal ZL1's Avatar
Drives: 2013 ZL1 M6
Suspension geometry can be compromised and the negative camber gain from suspension can turn into negative camber loss.
In other words you can end up with a mean looking stance but your geometry works backward from design. The other negative is lower roll center.
At the number your looking at your probably OK for the geometry.
Nor Cal ZL1 is offline   Reply With Quote
Old 05-02-2014, 04:14 PM   #11
EmeryZ28
EmeryZ28's Avatar
Drives: 2011 Camaro 2SS/RS LS3
so you are telling me now that I have just intalled 1" BMR drop springs, that my car is going to handle worse??
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
EmeryZ28 is offline   Reply With Quote
Old 05-02-2014, 04:39 PM   #12
prostcj
Yes, that is usually true.
Old 05-02-2014, 04:50 PM   #13
19car69
19car69's Avatar
Drives: 2012 1LS
I did BMR 1.2 inch drop on my car and it handles much better. A lot less body roll and no fighting with understeer.
2012 1LS, Cold Air Inductions CAI, Apex scoop, Apex water bottle relocation, VMax Ported TB, Vitesse Throttle Controller, BMR Sway bars, BMR 1.2" drop springs, Koni rear shocks, Elite catch can, Solo Performance V6 Mach X-LFX Cat-Back Exhaust, Hex Vents, 1LE strut tower brace, Barton short throw, separate clutch reservoir, American Racing TORQ THRUST M 18X9, HiTS radio with reverse camera, GM Blade Dovetail spoiler, 2010 leather wrap steering wheel, vented engine cover, added Homelink to overhead console.
19car69 is offline   Reply With Quote
Old 05-02-2014, 04:58 PM   #14
cj04
cj04's Avatar
Drives: 2010 2ss/rs
Eibach 1 inch drop, certainly feels like it handles much better, ride quality relatively uncompromised as well. I have never heard drop springs making your handling worse...
Sent from my SCH-I545 using Tapatalk
cj04 is offline   Reply With Quote
