Caryle Racing
Old 04-28-2014, 09:23 PM   #1
specialfx
Drives: 2013 LFX V6 2LS Auto
What should I do while the rear cradle is out of the car?
I have a '13 V6 A6 2LS & I'm swapping in a complete rear end from a low mileage '13 1LE. What if anything should I do while I've got the cradle out? (Don't worry I'm doing the front as well for a full FE2~FE6 upgrade) It's a 2nd car not a DD so I don't mind a stiff suspension but I don't want the ride too harsh so no solid bushings. I'm doing this upgrade to correct the body roll I experienced at the track(see pic below from Laguna Seca) and improve my AutoX performance.
I've already done the Brembo upgrade and they seem more than adequate.
specialfx is offline   Reply With Quote
Old 04-29-2014, 08:45 AM   #2
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
The 1le will already have the 3.91's but the rest is advisable.
http://www.camaro5.com/forums/showth...e+rear+bushing
jeremywes is offline   Reply With Quote
Old 04-29-2014, 10:41 AM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
For the best autocross performance, you might consider swapping the Cradle Bushings to our Pro-Version Polyurethane Bushings (BK024). Also, while the cradle is out, it's a real good idea to replace the rear upper control arm bushings, I would recommend the BK039 Delrin version. The rest can be later after the cradle is installed. And if you're looking to get rid of body roll, our BMR sway bars will outperform the 1LE bars in every aspect!!!
BTW, what car is that parked behind your new cradle? Looks pretty cool!!!
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 04-29-2014, 10:48 AM   #4
specialfx
Thanks for the link to your awesome write up JEREMYWES! I'll do some research on the bushings, seems like there are a few brands out there.
BMR I'll be in touch once I do my research and get some more opinions from the forums.
The car in the background is my 1972 Volvo 1800e that's undergoing a restomod(actually it's accumulating dust while I play with my new Camaro)
Old 04-29-2014, 06:17 PM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Keith @ BMR gave great advise; the subframe/cradle bushings and upper CAB's are all that really need to be addressed while the cradle is down. I'd also suggest installing the toe link bolts in the reverse direction to prevent having to lower the cradle again to replace them. (they hit the fuel tank when removing them)
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 04-30-2014, 10:56 AM   #6
specialfx
I'm a bit confused on these subframe mounts, I have this bushing insert kit that I got from another member here(thanks HYPURONE) but they don't seem to fit for my '13 1LE rear end. Chevy seems to have gone to more solid mounts. Is there even an upgrade for these? The big upper ones seem to have little to no flex when I pry on them, but the lowers do seem to move around a little.
Old 04-30-2014, 11:01 AM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yep, those are the wrong inserts for your car. As you figured out, Chevy did upgrade to a little bit better bushing....I believe it was during the changover to the FE4 Suspension. You need the BK040 inserts (as pictured below), and you currently have the BK016 inserts.
T.C. Davis
813-986-9302
Old 04-30-2014, 11:04 AM   #8
specialfx
Got it, I guess I'll have to sell the ones I got and get those. Do those go over the lower metal hats or do they replace it? It seems like the underside metal part doesn't want to come off.
Old 04-30-2014, 11:30 AM   #9
BMR Sales
BMR Sales's Avatar
Drives: Race Car
No, they go under the "lower hat" (lower bushing retainer plate). You've gotta take them off. I used a chisel and hammer to "wedge" them apart from the bushing. You also will have to lower the subframe/cradle enough to put the upper inserts on top of the bushings (in between the bushing and the frame).
T.C. Davis
813-986-9302
Old 04-30-2014, 12:45 PM   #10
JDP Sales
JDP Sales's Avatar
You can also trim the "fingers" to make those ones fit, but I'd still recommend a full replacement bushing over the inserts. Getting rid of the soft factory rubber is really a big part of the upgrade.
If cost is a concern, check out the Prothane replacement bushings Part # 7-142. They are a full bushing at about the same cost as inserts.
Best regards,
Tyler
888-308-6007
Old 04-30-2014, 01:33 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Tyler is absolutely correct, the full bushing replacements work a LOT better than the inserts. They're a lot more work to install, but because of the difference in performance, they're worth it in my opinion. If you're looking to stick with BMR, we do have the BK024 Pro-Version Full Bushing Replacement in-stock.
T.C. Davis
813-986-9302
Old 04-30-2014, 04:45 PM   #12
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
Go for full replacement. Although I'm sporting a different brand, we have the inserts in my wife's car and the bushing replacement in mine. You can tell a difference. We'll be upgrading to replacements in hers eventually. I wanted full race car and hers was more of a DD at the time.
mp51998 is offline   Reply With Quote
Old 05-01-2014, 12:49 AM   #13
Lio Martinez
SoCal HT5!!!!
Lio Martinez's Avatar
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
What's the easiest way to drop the rear craddle?
2013 CAMARO 2SSRS 1LE Metallic Inferno Orange. Turbonetics T76 Kit, Granatellis Spark Plug Wires and Performance MAF Sensor, Wilwood Big Brake 6 Piston Kit. Eibach 1 1/2 drop lowering springs. ZL1 conversion of rear diffuser with heat shields, Side skirts and rear spoiler matter black. Original GM Transformers edition AuTobot fender logo and autobot wheel caps and autobot stiched ARM rest . Inferno Orange interior seats and dash trim panels, red billet racing pedals , Black CAMARO fuel door with lock. Chevy logo speaker covers, and Camaro logo chromed door kick panels . GM MTX subwoofer box.
Lio Martinez is offline   Reply With Quote
