Old 04-30-2014, 06:12 PM   #1
maxx210
Drives: EVERYTHING BLACK 1SS/RS
best trailing arms
Did a quick but not thorough search for this topic. Did not see anything. I was wondering what everyone's thoughts were on best bang for buck as well just the best trailing arms for our cars. Im not looking to get a complete rear end kit unless there are some good deals out there with toe end links and upper arms AND trailing. Thanks to all.
maxx210 is offline   Reply With Quote
Old 04-30-2014, 06:24 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I would look into the LSR billet Al trailing arms.
kjkjr27 is offline   Reply With Quote
Old 04-30-2014, 07:28 PM   #3
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Can't go wrong with BMR or if you can find a set of PFADT's!
What do you have done to your Camaro so far?
JT
Team STILLEN is offline   Reply With Quote
Old 04-30-2014, 07:33 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Best bang for your buck??? Check out our TCA026 with poly inner bushing, or the adjustable TCA033 with spherical rod end. Both incredibly strong and both will help reduce wheel hop. Don't forget to include the outer trailing arm bushings (BK006).
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 04-30-2014, 08:46 PM   #5
tanur420
Drives: 2011 Camaro SS
I went with the bmr as I caught them on sale and have no complaints. Lsr is good also from what ive heard
tanur420 is offline   Reply With Quote
Old 05-01-2014, 10:01 AM   #6
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
What are your goals for the car?
For most applications a "basic" non-adjustible, poly bushing trailing arm will work just fine (~$140/set). If you're going hard-core, look into the chrome-moly arms or adjustible options as well as either a delrin bushing or a spherical bearing (up to $300/set). With any of these upgrades, it's a good idea to go ahead and upgrade the outer trailing arm bushing as well (I believe BMR is the only real option, see above ~$30).
The three companies that come to mind right away are (no particular order):
Spohn
BMR
LSR
The Spohn and BMR both have different options with their arms (non-adjustible, adjustible, bushing types, etc). Spohn and LSR each have a chrome-moly upgrade option. They are all about the same for pricing if you compare "apples to apples". When I was discussing my upgrades with JDP, they recommended the Spohn arms with the poly bushings since Bee is mostly a daily driver. They said if I was looking at doing more racing they would highly recommend upgrading to at least the spherical bearings.
Another relatively inexpensive option would be to go with some 1LE/ZL1 toe rods (you can find some take-offs in the classifieds). The rods themselves are identical to the base SS, but the upgrade comes in the form of spherical bearings instead of the poly bushings. There is no change in road noise, but the bearings help remove any possible binding associated with wheel hop.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 05-01-2014, 10:38 AM   #7
L99CAMA2011
L99CAMA2011's Avatar
BMR pieces also improve grip, ask me how I know.
Old 05-01-2014, 11:47 AM   #8
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
I only have experience with the BMRs so I can't offer a comparision. I will say the BMRs are excellent!
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 05-01-2014, 12:13 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Bang for the buck: Standard BMR or Spohn arms with poly ends.
Best: Spohn and DSE
Really depends on what you plan on doing with the car. Dexman gave a great detailed post. Feel free to call, PM or email me if you would like an explanation of different options.
Best regards,
Tyler
888-308-6007
Old 05-01-2014, 02:49 PM   #10
Joe@CPR.com
Joe@CPR.com's Avatar
Drives: 03 vette, 94 trans am, 04 gto
We stock the BMR pieces and absolutely love the fitment and quality they provide.
Joe@CPR.com is offline   Reply With Quote
Old 05-02-2014, 04:13 PM   #11
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
+1 on the BMR Trailing arms. Good value. Also did the outer bushing. That along with my standard ZL1 toe rod setup has reduced but not eliminated wheelhop. If it happens you just get out of it before things break.
But now with extra power SS sidestep is back big time. May have to go full polys. While I did the TAs myself, I will farm that project out. What a PIA unless you have the right shop and equipment to work with. Man I hate getting under the car on jack stands.
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 05-02-2014, 05:50 PM   #12
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
I got the lsr toe rod and trailing arm chromoly package - the cost was less than the bmr and spohn stuff but they don't offer the spherical joints. Haven't got them on yet so I can't comment to that but the reviews of them were very positive. Like most people, I'll never be able to compare them to another brand
RolltideSS is offline   Reply With Quote
Old 05-05-2014, 07:25 PM   #13
JDP Sales
JDP Sales's Avatar
At your power level, solid subframe bushings or at LEAST a full poly bushing is a must! Don't forget the upper control arm bushings while you are in there.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
