Old 08-03-2009, 08:28 PM   #1
Treadstone
Treadstone's Avatar
Drives: Z51 BABY!
500 mile oil change (metal shaving)
Guys, I'm looking for the photo of a user here who took a pic of their first oil change and there was metal shavings in it. Can't find it with search.
Treadstone is offline   Reply With Quote
Old 08-03-2009, 08:48 PM   #2
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
i don't remember that, but it's gonna happen to any car
your just checking to see how much there is right
Gentry78 is offline   Reply With Quote
Old 08-03-2009, 08:50 PM   #3
ALLT4
ALLT4's Avatar
Drives: 2010 Camaro 2SS RJT
It's normal for the break in oil to look little silvery, but not actual metal shavings you can feel.
ALLT4 is offline   Reply With Quote
Old 08-03-2009, 08:57 PM   #4
DarrenJ
DarrenJ's Avatar
Drives: '67 Camaro ZZ4 & 2010 IOM 2SS
The last 2 HHR's of mine had metal shavings and cuttings lodged in the pleats of the oil filter. First time it caused some worry, but the oil filter did it's job. I took the filter to the service dept and the owner of the dealership looked at it with me, he smiled and told me the AC/Delco filter was doing what it was intended to do and not worry about it. Some owners of HHR's also reported similar issues on their forum site - nothing to worry about.
DarrenJ is offline   Reply With Quote
Old 08-03-2009, 09:02 PM   #5
dayvedayve
Drives: 2006 Chevy Avalanche
Actually there will be a small amount. If you look in the oil pan there is a magnet and the tip of the oil pan drain plug is magnetic also. It is there to catch the one the filter doesn't. The motors almost always have left over shavings that were stuck in the motor from boring and assembly. They get most of them out but not all. After the first oil change then you might want to question it.
dayvedayve is offline   Reply With Quote
Old 08-03-2009, 09:06 PM   #6
Treadstone
Treadstone's Avatar
Drives: Z51 BABY!
I'm looking for a picture, cuz I wanna make show a buddy who doesn't believe in the 500 mile change.
Old 08-03-2009, 09:09 PM   #7
Capstone
Capstone's Avatar
Drives: .
After my trip back to VA from PA picking up the car, I took it to JiffyLube (323 miles). Boy were they surprised to see the car. I asked about the oil, they said it look pretty clean. I made sure to insist they put back regular oil, not synthetic...
Capstone is offline   Reply With Quote
Old 08-03-2009, 09:24 PM   #8
ALLT4
ALLT4's Avatar
Why? It comes factory filled with synthetic.
Old 08-03-2009, 10:11 PM   #9
Treadstone
Treadstone's Avatar
Drives: Z51 BABY!
Werd, you just downgraded your oil.
Old 08-03-2009, 10:14 PM   #10
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
I changed mine at 1000, and after close inspection of used oil and filter I think I wasted my money.
It's good to have peace of mind though.
two_wheel_mayhem is offline   Reply With Quote
Old 08-03-2009, 10:15 PM   #11
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Aluminum magnet?
I realize the crank and some lesser parts are steel, bit isn't this an aluminum engine?
Old 08-03-2009, 10:32 PM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Because it saves a nice chunk of change for those who believe in changing the oil the second time at 1,000-1,500 miles. Why spend $100 on something that will be in your car for so short amount of time.
Old 08-03-2009, 10:42 PM   #13
heidi
heidi's Avatar
Drives: Black SS, Black Expedition
Use the oil recommended and the interval recommended by your owners manual. The engine was designed to use that oil. Pay particular attention to what the manual states is outside of normal driving conditons. It sometimes is vague. The rule of thumb for traditional conventional oils was 3000 miles. Some manufactures were starting to use sythentic or synthetic blends and sometimes pushing out the intervals.
There will usually be more metal in the first filter because everthing is seating and any other debri is going through the filter. There will be aluminum and metal in the filter.
heidi is offline   Reply With Quote
Old 08-04-2009, 12:28 AM   #14
ALLT4
ALLT4's Avatar
$100.00 for oil and filter?
Frist oil change SSRS2010 USA - Southwest 17 11-21-2009 01:53 PM
Oil change based on oil life monitor? trm0002 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 46 10-19-2009 01:19 PM
Huge offshore oil discovery KILLER74Z28 Off-topic Discussions 36 11-14-2007 07:14 PM
