Old 05-02-2014, 07:25 AM   #1
Rob21sf
Rob21sf's Avatar
Drives: Black 2011 Camaro LLT
Pfadt rear sway bar hardware help needed!
Long story short. My car was on a lift yesterday, getting X-pipe installed, while it was up I was looking around the under carriage when I noticed that one of the bracket on my rear Pfadt Sport sway bar was gone! The bushing was still there but no bracket. I know Pfadt is no longer doing business but somewhere out there there should be still replacement hardware floating around, someone had to have bought there remaining stock.
If anyone can point me to a business that has the bracket or any professional suspension gurus can give me recommendations what I can use as replacement, I would greatly appreciate it.
Rob21sf is offline   Reply With Quote
Old 05-03-2014, 05:45 AM   #2
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
JDP Motorsports or Apex Motorsports can help you out. You have a 2011, so, unless you changed your LCA's to FE4 you have FE3 rear LCA's and the rear end link mount is weak and is known to crack or break off. They sell end link mount stiffeners and get some new aftermarket endlinks.
SS PANTHER is offline   Reply With Quote
Old 05-03-2014, 10:41 AM   #3
Synner
Drives: not stock
Measure the bar and you can get one from Energy Suspension or other major suspension distributor.
http://www.energysuspensionparts.com...r-Bushings.asp
Old 05-05-2014, 12:25 PM   #4
Rob21sf
Rob21sf's Avatar
Thank you gentlemen!
Old 05-05-2014, 12:45 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I believe he's talking about the actual "saddle clamp" that mounts the bar to the subframe, not the end link mounts. Just measure the diameter of your bar and give me a call....we can hook you up.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 05-05-2014, 05:21 PM   #6
SS PANTHER
SS PANTHER's Avatar
Your right.
Old 05-06-2014, 08:37 PM   #7
Rob21sf
Rob21sf's Avatar
Gentlemen, thank you for all the input. Issue resolved.
