third_shift studios
Old 05-02-2014, 07:30 PM   #1
No Excuses
Drives: 2011 2SS/RS
Need New Endlinks for Rear Sway Bar Suggestions??
I have always had a knocking and squeaking sound coming from the rear of the car, so today I finally decided to get it looked at it. Shop told me the end links were pretty much toast, so I need to get new ones.
I have a eibach rear sway bar, so which endlinks will go with it?
Thanks.
No Excuses is offline   Reply With Quote
Old 05-02-2014, 08:12 PM   #2
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
BMR has adjustable ones, would think they would work with just about any setup. Maybe PM JDP or Apex and see what they have that would work for you. Both are super helpful shops.
RolltideSS is offline   Reply With Quote
Old 05-02-2014, 08:44 PM   #3
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I am experience the same sounds, wonder if i need to replace my end links.
kjkjr27 is offline   Reply With Quote
Old 05-03-2014, 03:49 AM   #4
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
You have FE3 suspension unless you updated your LCA's to FE4. The FE3 rear sway bar mounting bracket is very weak and has been known to break. Besides upgrading your endlinks get the endlink mount stiffeners. If you have FE4 LCA's the factory ZL1 endlinks are good and quiet.
SS PANTHER is offline   Reply With Quote
Old 05-03-2014, 12:25 PM   #5
No Excuses
Drives: 2011 2SS/RS
Do the BMR endlinks work on any years? Do they sell the mount stiffeners?
Old 05-03-2014, 05:23 PM   #6
SS PANTHER
SS PANTHER's Avatar
yes & yes
Old 05-03-2014, 06:24 PM   #7
No Excuses
Drives: 2011 2SS/RS
Ok I have a guy that has new BMR adjustables he wants to sell
Old 05-03-2014, 09:42 PM   #8
SS PANTHER
SS PANTHER's Avatar
Be sure they will fit your FE3 sways. That is what you have, right? FE3 sway in black, aftermarket FE4 sway in orange. The FE4 is noticeably longer.
Old 05-03-2014, 10:07 PM   #9
SS PANTHER
SS PANTHER's Avatar
http://www.jdpmotorsports.com/manufa...maro-ss-elk006
http://www.jdpmotorsports.com/manufa...aro-zl1-elk009
Old 05-04-2014, 03:11 AM   #10
No Excuses
Drives: 2011 2SS/RS
Its for my 2010 SS I have. The previous owner had installed eibach sways on the car.
Old 05-04-2014, 03:57 AM   #11
SS PANTHER
SS PANTHER's Avatar
Again, if the suspension and sways were not updated to FE4, 2010 to early 2012's came with the FE3 suspension. You would have the shorter black bar as shown and would need the links as I showed as an example in the previous post with links. The stiffener is shown also. You do not need adjustable links, but, if they are a good deal go for it. Do not use another factory GM endlink. You may want to consult with JDP or Apex on Monday. Good luck.
Old 05-05-2014, 12:11 PM   #12
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, our ELK006 Rear End Links will work with any FE3 style rear sway bar. And yes, the End Link Mount Braces (ELK009) are highly recommended with any aftermarket sway bar when using factory lower control arms.
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 05-05-2014, 03:13 PM   #13
No Excuses
Drives: 2011 2SS/RS
Looks to be a FE3 here is a pic of a members sway bar of the one I have:
Old 05-05-2014, 04:37 PM   #14
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yep, that's an FE3 sway bar.
T.C. Davis
813-986-9302
