BeckyD @ James Martin Chevy
Old 05-07-2014, 01:42 PM   #15
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
The BMR Endlinks and braces would be my suggestion as well. Let me know if I can answer any questions for you and thanks to those who recommended us!
Best regards,
Tyler
888-308-6007
Old 05-07-2014, 01:55 PM   #16
Dyk-NO
Trust me I'm a Scientist.
Drives: My wifey ;P
what's the benefit of the sway bar endlinks anyways? I just replaced my front driver side because it was bent for some reason. I replaced it with an OEM one.
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator.
Dyk-NO is offline   Reply With Quote
Old 05-07-2014, 02:07 PM   #17
JDP Sales
JDP Sales's Avatar
The factory 10-11 endlinks are weak and can bend and break, and can also deflect causing the sway bars to feel softer than they really are. Ultimately they will make your sway bars more effective.
Best regards,
Tyler
888-308-6007
Old 05-07-2014, 02:11 PM   #18
Dyk-NO
Drives: My wifey ;P
what about the adjustable ones? what would it do when you decide to make it shorter than the stock ones for your sway bars?
Old 05-07-2014, 02:13 PM   #19
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
When chaining end links, is it necessary to get an alignment?
Proud owner of litho #179 Click Picture for Build Thread
Old 05-07-2014, 02:23 PM   #20
BMR Sales
BMR Sales's Avatar
Drives: Race Car
It makes no difference, you just want them to be exactly the same length left-to-right. We always recommend setting them to the same exact length as the OEM links.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 05-07-2014, 02:24 PM   #21
BMR Sales
BMR Sales's Avatar
Drives: Race Car
No alignment is necessary when changing end links or sway bars. As stated above, just make sure the end links are set to the same length as the OEM links.
T.C. Davis
813-986-9302
Old 05-07-2014, 02:35 PM   #22
Dyk-NO
Drives: My wifey ;P
So the main idea is just replacing the oem ones with a more durable link?
Old 05-07-2014, 03:54 PM   #23
JDP Sales
JDP Sales's Avatar
The adjustability is there to remove any potential pre-load from the sway bars. Basically, you'll set one to OEM length and install one on one side. You will then lower the car back down on it's own weight on a LEVEL surface, adjust the length of the opposing side endlink so that you can install it without using any force.
Nope not at all.
For the most part yes, and the ability to remove pre-load as I spoke about above.
Best regards,
Tyler
888-308-6007
Old 05-07-2014, 04:17 PM   #24
No Excuses
Drives: 2011 2SS/RS
I went with the BMR endlinks. I was getting a knocking and squeaking sound from the rear come to find out the stock endlinks were bad
No Excuses is offline   Reply With Quote
Old 05-07-2014, 05:34 PM   #25
menendez1293
Originally Posted by JDP Tyler View Post
Nope not at all.
Best regards,
Tyler
888-308-6007
Great, once I pay off my new desktop and the trip to Texas I will get in touch to place an order with you guys.
Sent from my HTC One_M8
Old 05-07-2014, 05:36 PM   #26
JDP Sales
JDP Sales's Avatar
Sounds good! It was great meeting you by the way!
Best regards,
Tyler
888-308-6007
Old 05-07-2014, 05:43 PM   #27
menendez1293
Best regards,
Tyler
888-308-6007
It was great meeting you too and to finally put a face to the name.
