Caryle Racing
Old 05-03-2014, 12:57 PM   #1
JBoy
Drives: '13 LFXv6
problems with eibach lowering springs
Just installed a set of eibach lowering springs on my 2013 v6 camaro. Install went really well but the front shocks arent sitting right. Under the hood on the single screw the bolt/washer sits higher than it did causing the top bolt and washer to be approximately 1/4 inch higher. In other words the top bolt and washer do not hold the shock in place and if i drive it it seems like it would bounce around. They were tourqued down to spec and was told i do not need to trim the bushings or anything for this install. Anyone have any ideas? I will try to get pictures later this afternoon once I get back home
JBoy is offline   Reply With Quote
Old 05-03-2014, 01:22 PM   #2
JBoy
Drives: '13 LFXv6
It seemed like it was tight on it when i first took it off.... I figured like that the spring would bounce around going over a good bump or two?
