BORLA
Old 05-03-2014, 04:08 PM   #1
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
installing wheels found issue, question
putting on my summer tires and found this when I took the stock wheel off:
Now I am a novice but I know that is not supposed to be sitting there! I think it is the bolt that holds the rotor on, yes? So I screwed it back in, but is that all? Do I need to Loctite it or re-check it? The wheel really wasn't at risk for falling off due to the lugs right?
IPT is offline   Reply With Quote
Old 05-03-2014, 04:20 PM   #2
SSMY1LE
SSMY1LE's Avatar
Drives: '14 1LE RS NPP Recaro
Loctite is good to use but not always required.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be
SSMY1LE is offline   Reply With Quote
Old 05-03-2014, 04:30 PM   #3
IPT
thanks.
Old 05-04-2014, 08:52 AM   #4
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
the bolt doesnt serve much of a purpose. its to hold the rotor in, but the rotor cant go anywhere anyway, so... there's that.
DietCoke is offline   Reply With Quote
Old 05-04-2014, 04:00 PM   #5
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
It is for ease of maintenance. I don't believe it was sitting loose where it is now or your tire would not have mated up flush. It was probably pinched just above or its stripped and fell out when the wheel was removed.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 05-04-2014, 04:19 PM   #6
Broke Pilot
Drives: '14 1SS 1LE,'68 Chevelle,'70 Vette
You have the exact opposite problem as most,.. Those screws like to weld themselves in over time. No loctite on it... Use anti seize. But it's really not needed in the first place. It's more there for ease of pad swaps so the rotor doesn't droop on the studs and stays centered in the caliper
Overkill is underrated....
Broke Pilot is offline   Reply With Quote
Old 05-13-2014, 11:49 AM   #7
Stitch
Stitch's Avatar
Drives: SS, CTS & SRT-4
It's for ease of pad swap and to hold the rotor in place during assembly.
Stitch is offline   Reply With Quote
