HeadlightArmor
Old 05-04-2014, 08:55 AM   #1
madmax13
Drives: '13 2SS/RS/1LE/NPP
Thumbs up Z/28 Upgrade Packages Available for Standard Camaros This Summer
Official Chevy announcement:
Camaro Z/28 Components Available from Chevrolet Performance this Summer
HOUSTON – Beginning this summer, Chevrolet Performance will offer nine Camaro upgrade packages, each featuring components from the all-new Z/28. Each package has been validated for use in most model year 2010 and later Camaros. Many of the parts preserve the vehicle warranty when installed by a Chevrolet dealer – an advantage aftermarket installers cannot provide.
Combined with existing upgrade packages offering components from the Camaro ZL1 and Camaro 1LE models, Chevrolet Performance now offers a comprehensive line of performance upgrades for the track, the drag strip and the street.
“We have taken some of the very best components of our track-capable Camaros –and packaged them together for easy installation on other fifth-generation Camaros,” said Mark Dickens, director, Chevrolet Performance Engineering. “Each package gives customers the performance upgrades they want, and the peace of mind knowing each part has been engineered and tested to the same specifications as our production cars.”
The nine packages include:
• Camaro Z/28 Suspension – The kit includes front and rear spool-valve dampers, springs, and stabilizer bars; front ride/handling links; and rear upper control arms and trailing links.
• Rear Differential Cooling System – This kit includes the rear-differential cover, integrated heat exchanger, and all cooling lines and fasteners. On the Camaro Z/28, this system reduced the temperature of the differential fluid by 100 degrees Fahrenheit – and is ideal for track usage.
• Recaro Sport Seats – Compatible with 2012 and later Camaros, the Recaro front seats feature more pronounced side bolstering – ideal for performance driving. The driver and passenger seats are offered individually, and feature manual adjustment for reduced weight.
• Z/28 Cold Air Intake – This kit includes the full air induction system, including a K&N high-performance air filter and cold-air intake box assembly for improved engine power and cooling.
• Camaro Z/28 Exhaust Manifolds – This kit includes dual, hydroformed “tri-Y” headers from the 7.0L LS7 engine, offering increased airflow for other LS-series V8 engines.
• Camaro Z/28 LS7 Exhaust system – This includes the cat-back exhaust system from the Camaro Z/28. For an additional $150, an adapter kit is also available to join the 2.75-in diameter Camaro Z/28 system to the 2.5-in diameter LS3 exhausts.
• Camaro Z/28 Aerodynamics Package – Compatible with 2014 model and later Camaros, this package includes four components that contribute to the aerodynamic performance of the Z/28: front splitter, front wheel-lip extensions, underbody belly pan, and rear spoiler.
• Camaro Z/28 Brake Ducts – Compatible with 2014 model and later Camaros, this package includes the front-fascia opening and ducting to direct cooling air to the front brake rotors to increase braking performance for track use.
• Camaro Z/28 Helical Differential – This kit includes a zero-preload limited-slip differential with helical gears rather than traditional clutch packs. By continuously adjusting the torque bias, this differential maximizes available traction for faster lap times. The kit also includes the 3.91 axel ratio and integrated heat exchanger in the cover.
More information about the packages, including final pricing and vehicle fitment, will be available this summer at www.Chevrolet.com/Performance. Package will be available for sale directly through authorized Chevrolet dealers.
“The Z/28 is the most track-capable Camaro we have ever produced,” said Dickens. “With these packages, customers can buy some of the Z/28 performance hardware to improve their own track capabilities.”
madmax13 is offline   Reply With Quote
Old 05-04-2014, 09:09 AM   #2
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
yes its true. heard right from Chevy at Cfest.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 05-04-2014, 01:17 PM   #3
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
I'm in for these 2:
•Z/28 Cold Air Intake – This kit includes the full air induction system, including a K&N high-performance air filter and cold-air intake box assembly for improved engine power and cooling.
•Camaro Z/28 Exhaust Manifolds – This kit includes dual, hydroformed “tri-Y” headers from the 7.0L LS7 engine, offering increased airflow for other LS-series V8 engines.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 05-04-2014, 02:26 PM   #4
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Originally Posted by Mikamaro View Post
I'm in for these 2:
Any thoughts on HP gains from these items?
2cnd chance is offline   Reply With Quote
Old 05-04-2014, 03:56 PM   #5
tones2SS
tones2SS's Avatar
I'm in for these 2:
I would be for those as well.
They'll work hand in hand.
Old 05-04-2014, 04:08 PM   #6
toehead93
Drives: 2014 2SS/1LE
Are the break ducts similar to the ZL1 that dump air near the brakes or do they pump air through dict all the way to the rotor like those doing custom aftermarkts ducts.
Also curious on the manifold gains.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-04-2014, 05:31 PM   #7
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
The CAI is gonna be a huge hit!!
TSP 231/236 111 lsa cammed 1LE
WHAMMO is offline   Reply With Quote
Old 05-04-2014, 05:48 PM   #8
L99CAMA2011
L99CAMA2011's Avatar
"Camaro Z/28 Helical Differential – This kit includes a zero-preload limited-slip differential with helical gears rather than a traditional clutch pack. By continuously adjusting the torque bias, this differential maximizes available traction for faster lap times. The kit also includes 3.91 axel ratio and integrated heat exchanger in the cover." This really interest me. Any Idea when these will be available.
Old 05-04-2014, 05:53 PM   #9
L99CAMA2011
"Camaro Z/28 Aerodynamics Package – Compatible with 2014 model and later Camaros, this package includes four components that contribute to the aerodynamic performance of the Z/28: front splitter, front wheel-lip extensions, underbody belly pan, and rear spoiler." Only front wheel lip extensions, I actually noticed the rear 11.5" wide rims still looked as though they didn't require wider fender extensions.
Old 05-04-2014, 06:04 PM   #10
DuskSS
DuskSS's Avatar
why bother with the big heavy CAI when the aftermarket has it down pat?.. and the manifolds still looked way more restrictive than a true header setup. I saw them in person I seriously doubt they will make any power vs a real long tube setup.
530/520 SAE
Old 05-04-2014, 08:42 PM   #11
Doubleblank
Doubleblank's Avatar
Drives: 2010 Camaro SS, 2014 Z28
But they imply you can do these and keep your warranty.....if that's important to you.
ERL 500 ci Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, MGW Shifter, StopTech BBK, Pfadt C/O's, Pfadt ASB's, etc, PowerFab Dynotune
Doubleblank is offline   Reply With Quote
Old 05-04-2014, 09:04 PM   #12
Mikamaro
MikeNoMaro
Mikamaro's Avatar
The Intake about 15, the header alone about 10 but coupled with HF cats 25 to 40.
Old 05-04-2014, 09:06 PM   #13
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Gains will be made on the TQ curve. The LS7 in the Z06 makes 470TQ while the LS7 with the new headers makes 481Tq in the Z28.
Old 05-04-2014, 09:33 PM   #14
2cnd chance
Thanks.
