BeckyD @ James Martin Chevy
Old 05-05-2014, 01:53 PM   #15
MoCamaro20
MoCamaro20's Avatar
Drives: 2010 Camaro SS RS L99
We'll they they t
MoCamaro20 is offline   Reply With Quote
Old 05-05-2014, 01:54 PM   #16
MoCamaro20
MoCamaro20's Avatar
They told me for all 4 pads it will be 550 and they said they will resurface the rotors
Old 05-05-2014, 01:58 PM   #17
stmbtwilli
stmbtwilli's Avatar
Drives: 2016 Garnet Red 2SS
I supplied the Hawk Ceramic pads and the dealer charged me $153 to install them.
stmbtwilli is offline   Reply With Quote
Old 05-05-2014, 02:09 PM   #18
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Then that price isn't bad. Time is $$ and it takes a little time to pull all 4 calipers, turn the rotors, and reinstall. Many dealerships charge $85+/hour so figure in 2-3 hours book time.
Many times, you don't need to turn your rotors. A quick pad change is all that's needed. Lots of people only change their fronts, if it's the first pad change. The fronts wear a lot faster than the rears. Then change all 4 the next time. If you're considering this, be sure to check the rear pads to see how they are wearing. Many vendors here sell brake pads. If you're wanting to eliminate the brake dust, the ceramic pads are a great option. You do lose a little braking performance though. The Hawk street performance pads are good pads that will dust less than stock and give better braking performance.
Lots of options and things to consider. Pull your wheels and check everything out to see which options will work for you.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-05-2014, 02:27 PM   #19
batman53201
Account not blocked
batman53201's Avatar
Drives: The Batmobile
always cheaper to do it yourself
batman53201 is offline   Reply With Quote
Old 05-05-2014, 04:22 PM   #20
NJBourne23
Master of Nothings
NJBourne23's Avatar
Drives: 2010 Chevy Camaro 2LT/RS
Originally Posted by Gillis View Post
Whenever you change brake pads you should have the rotors resurfaced. If you change your own pads, this means taking them to an auto parts store to be turned. I heard that our stock rotors are pretty thin so they can only be resurfaced a couple of times before you need to replace the rotors.
Alot of people are not willing to do the work involved to change their own brake pads. Even for a red-headed idiot, if you have never done it and have no experience with working on cars, it's not that easy.
$550 is too much but what do expect from a dealer.
You DO NOT need to cut your rotors when you change your breaks every time. This is an old myth or way of thinking. Only time you cut them is if you somehow gouged out a spot in them with a rock or something or let your breaks go so long that they cut into them. If you buy quality ceramic or composite breaks, they will last a long time and not warp your rotors. You can buy breaks for just about any car at Autozone, PepBoys etc. Just don't be frugal and go for the cheapest ones. Like is said, if you buy good composites break pads you can get great stopping power and minimal dust
2010 Chevrolet Camaro 2LT/RS
NJBourne23 is offline   Reply With Quote
Old 05-05-2014, 05:39 PM   #21
freddyD
Drives: 2016 summit white lt
please! Do it yourself-it's EASY
freddyD is offline   Reply With Quote
Old 05-05-2014, 05:48 PM   #22
Gillis
Drives: Car
True. You DO NOT need to change your oil filter each time you do an oil change either.
Gillis is offline   Reply With Quote
Old 05-05-2014, 06:03 PM   #23
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Brake change dealer price
Originally Posted by Comrando View Post
Whoa. Tell me you are joking.
I put the wrong oil in my Hyundai once but drained and changed it without changing the filter, so it is true. Lmfao!
Sent from my 2SS/RS
FSP tuned: 377/389
Old 05-05-2014, 06:04 PM   #24
RedRaven
RedRaven's Avatar
Drives: 2012 2SS M6 CRT
If your pads are worn enough to warrant changing, you either need to turn the rotors or replace them. Look at the outside edge. Is there a ridge? They're worn enough for your cheap ass to wind up in the morgue.
2012 2SS M6 CRT
SOLD! - - 1983 Berlinetta, 305HO, Comp 235 cam, shorties
First real car: 1968 Malibu, '67 283, Canary yellow
RedRaven is offline   Reply With Quote
Old 05-05-2014, 06:40 PM   #25
omgitsmikeyC
Drives: 2014 CTS-V Coupe
If you need, it would be cheaper to give one of us gas money or fly us there to do it, and buy the parts.
2014 CTS-V... with some go-fast bits coming
omgitsmikeyC is online now   Reply With Quote
Old 05-06-2014, 11:09 AM   #26
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Lol.
Yep, the maintenance on these 5th gens is pretty expensive. If you don't DIY. I'll be honest brakes aren't my forte but think I will ask my bro for some help. Not sure about the resurfacing/ turning rotors though. Where would one go to get the rotors done? Is it ur local auto parts place?
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 05-06-2014, 11:48 AM   #27
Mighty SS
Mighty SS's Avatar
Drives: 2013 Camaro SS
I'm have some serious problems with my brakes on my '13 SS Brembo brakes. I recently installed ceramic pads to eliminate squeaky which was coming from the stock OEM pads. I am now hearing even more squeaking. Can anyone recommend me some good brake pads or suggestions. Also think I may go back to semi metallic pads because the stopping power on the ceramics arent as great.
Sent from my HTC One using Tapatalk
Mighty SS is offline   Reply With Quote
Old 05-07-2014, 08:41 AM   #28
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
I would go with the Hawk ceramic pads and turn the rotors only if needed. There is a YouTube video on how to change the. Real easy to do!!
CamaroLS is offline   Reply With Quote
camaro brakes cost
