BeckyD @ James Martin Chevy
Old 05-05-2014, 11:50 AM   #1
Red 2010 Camaro
Drives: Red 2010 Camaro
1LE Rear Diff. Direct SWAP Question?
Has anyone replaced their rear diff. with a 3.91 1LE complete rear diff. ASSY., & is this a DIRECT SWAP. I have a 2010 1LT M6 Camaro.
Remember that ALL the 1LT manual transmision cars ALL have the same SS 218 mm. 8.6 in rear diff. from the factory, and will accept ALL the gear sets that are used in the SS cars.
What I would like to do is swap out the entire rear diff ASSY. with one from a 1LE car, and not have to go through all the hassle of having the gears installed.
Any info. would be greatly appreciated.
Red 2010 Camaro
Red 2010 Camaro is offline   Reply With Quote
Old 05-05-2014, 07:21 PM   #2
Synner
Drives: not stock
Its a direct swap. Buy the whole pumpkin and it goes right in. Buying the axle removal/install tool will help preserve your seals if you're doing it yourself.
Old 05-06-2014, 09:42 AM   #3
Jerry7297
Jerry7297's Avatar
Drives: 2016 3LT Stingray RIP-2010 CamaroSS
I just did this. It goes in great, no problems. As for the axles I had 2 people and we just pulled them right out and put them right back in with no problems. I would suggest replacing the Diff bushings at the same time.
Jerry7297 is offline   Reply With Quote
Old 05-06-2014, 01:12 PM   #4
Red 2010 Camaro
Thanks SO MUCH to all for the helpfull info.
Red 2010 Camaro
Old 05-06-2014, 06:14 PM   #5
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
I helped Jerry with this. Hardest part was getting the old bushings out. Axles came out and went back in with no problems or leaks. We did everything in about six hours. Replaced bushings then dropped the whole cradle. Disconnected all suspension at the hub, removed rotors and then pulled axels. Swapped out diff and replaced everything in reverse. We were both surprised how easy it went.
mp51998 is offline   Reply With Quote
