BORLA
Old 08-04-2009, 12:50 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Question for the gearheads.
The L99s have averaged around 50 less HP to the wheels, stock, than the LS3.
Why did the L99 test .1 sec faster 0-60 and only .1 sec slower in the Quarter mile?
According to GM and most of the rags, they were pretty much the same within a tenth either way. It would seem to me that the LS3 would be a lot faster.
Anyone?
Old 08-04-2009, 12:53 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
bait and switch with the test cars that magazines got and the cars sold to the public??
Old 08-04-2009, 01:01 PM   #3
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2016 1SS Summit White
Yea it seemed strange to me how the L99 being handicapped 26HP, a few pounds heavier, and about an additional 10% drivetrain loss kept such close times to the LS3.
The way I justified it was the gearing difference made up for it.
--Edit-- removed my false information to prevent future confusion. Thanks jsuperman81
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD)
2016 1SS Summit White A8
Camar0wn3d is offline   Reply With Quote
Old 08-04-2009, 01:03 PM   #4
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
The A6 is not a 3.73 it actually has a lower numbered gear. It was suppose to be something about how the car was tuned and programmed to shift and it would edge out the manual in the 0-60, i remember reading it on here long time ago. Obviously with the slow ones out there, a mistake was made somewhere.
jpsuperman81 is offline   Reply With Quote
Old 08-04-2009, 01:06 PM   #5
ElAntonius
Drives: 2010 Camaro 1SS A6
Taller gearing off the line, IIRC. Also, if you look at the torque curve for the L99, it's flatter, meaning it has a wider power band than the LS3.
Truth is, horsepower is largely a false construct...again examining the nature of the engines, while the LS3 makes 26 more horsepower, it only is over 10 lb-ft of torque, and the L99 is closer to its maximum across more of the rev range.
The reason for the higher HP rating on the LS3 is that it revs a bit higher, but as the old saying goes:
Horsepower sells cars, Torque wins races.
A House Divided...
ElAntonius is offline   Reply With Quote
Old 08-04-2009, 01:08 PM   #6
jpsuperman81
Yep I'm back!
Hydra-Matic 6l80 six-speed automatic (SS) w/ TAPshift
Gear ratios (:1):
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Final drive ratio: 3.27
TR6060 six-speed manual (SS)
Gear ratios (:1):
First: 3.01
Second: 2.07
Third: 1.43
Fourth: 1.00
Fifth: 0.84
Sixth: 0.57
Reverse: 3.28
Final drive ratio: 3.45
Old 08-04-2009, 01:09 PM   #7
Camar0wn3d
Camar0wn3d's Avatar
Edited my above post. Yea I just read that the A6 final drive is 3.27 so that blows my theory out of the water.
Old 08-04-2009, 01:16 PM   #8
PQ
Booooosted.
PQ's Avatar
I'm not gonna say that, but you can.
We're seeing bigger Torque gains with the tunes than HP.
So I guess the L99s are just tuned lower than the ones the testers got.
Gear ratios (:1):
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: 3.06
Gear ratios (:1):
First: 3.01
Second: 2.07
Third: 1.43
Fourth: 1.00
Fifth: 0.84
Sixth: 0.57
Reverse: 3.28
Old 08-04-2009, 01:16 PM   #9
PQ
Booooosted.
PQ's Avatar
Well, that's all good but the LS3s seem to be easily faster across the board from what we've seen.
Old 08-04-2009, 01:19 PM   #10
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I dunno about that. Junkie's fast list for stock cars in the quarter mile has a few L99's on there...
Old 08-04-2009, 01:23 PM   #11
PQ
Booooosted.
PQ's Avatar
Yup. I looked at that. But I did an average and the LS3s are performing a lot better. Considering there are a lot more L99s out there than LS3s, it's kinda interesting.
Old 08-04-2009, 01:25 PM   #12
ElAntonius
http://www.camaro5.com/forums/showthread.php?t=21013
I might be misunderstanding you, but seems to be an even sprinkling of L99s and LS3s there.
TBH, if a MT is slow, everyone is quick to blame the driver. If an AT is slow, it's 'gotta be' the car's fault.
Someone on here (sorry, forgot who it was) alluded to having a feel for the AT, having to know when to step it in, when to back off. Not saying it should be as difficult as some people are having a time with, but sub 14 should be possible even in summer conditions...if someone is getting really close to that, maybe they should analyze factors other than blaming the trans.
That doesn't excuse the poor showing of some cars on here, but analyzing the problem also means dismissing other sources of car slowdown.
A House Divided...
Old 08-04-2009, 01:27 PM   #13
GTAHVIT
Blessed
GTAHVIT's Avatar
Truthfully, I think a lot of those L99 times are slower due to driving skillz.
I just don't think GM deliberately detuned the cars for production???? To make customers unhappy???
So It's not like it saves them money to detune the ECM...
Just doesn't make sense to me. I know that's not the topic of this thread.
so back on topic...
It really isn't that much easier to launch an Auto over a manual. In fact I'd probably have worse launches with an auto now cus my dd's have always been manuals.
Old 08-04-2009, 01:30 PM   #14
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
first gear is way lower so that helps a munch
Gentry78 is offline   Reply With Quote
Please answer my question... IROCanSS 5th Gen Camaro SS LS LT General Discussions 23 07-16-2009 05:49 PM
LS3 Transmission Question Seawolf 5th Gen Camaro SS LS LT General Discussions 13 06-12-2009 02:16 PM
Question about the After.... Tecca Camaro Price | Ordering | Tracking | Dealers Discussions 1 04-15-2009 04:05 PM
OK WILL SOMEONE PLEASE ANSWER THIS QUESTION OM FINANCING leatherneck Camaro Price | Ordering | Tracking | Dealers Discussions 22 03-26-2009 03:53 PM
2SS exhaust, 2 part question. HELP!! 2SS is mine!! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-16-2008 06:51 PM
