Old 05-09-2014, 09:50 PM   #1
Kill3mall
Kill3mall's Avatar
Drives: Black on Black 2011 Camaro2SS/RS
Installing lowering springs help!!
So today I tried to install my pfadt lowering springs on my ss. Everything went good no real trouble until the last spring of course. On the right rear of the car I cannot get the spindle assembly to line up with the control arm to put the bolt through. I tried for over an hour taking everything out and putting it back in and the damn thing wont line up... I'm hoping anyone has some advice for me it would be greatly appreciated! My car is blocking the garage from closing and I need to get to work tomorrow! lol
Kill3mall is offline   Reply With Quote
Old 05-09-2014, 10:06 PM   #2
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Disengage the emergency brake.
Obzen is offline   Reply With Quote
Old 05-09-2014, 10:09 PM   #3
Squillo
Squillo's Avatar
Drives: 2013 Camaro 2SS/RS BRM LS3
I just did this last weekend. You just have to maneuver it around until it goes in. It's SUPER helpful to have an extra set of hands to help, and I ended up using a floor jack under the control arm to help push things into the right place. You can also use a large screwdriver to help align the holes.
Don't give up, get a neighbor or your wife to help if you need to.
It can be done!!!
Performance
AirAid CAI
Apex Motorsports ported spiraled Throttle Body
Kooks 1 7/8" LT headers and 3" mid-pipes (cat delete)
Hurst shifter
Dyno Tune
Cosmetic
Camaro badge GOBO door lights
"SS" badge GOBO hood and trunk lights
Blacked out side markers with 30% tint
Blacked out tail lights with 30% tint
Afterburner tail lights
Blue / white color changing headlight and foglight HALOs
Blue LED upper and lower grille accent lights
30% tint windows
Plasma fog light bulbs
DRL harness
"BDMFER" Hawaii state issued license plates
"Bad Mother****er" custom blue lighted door sills
Blacked out bow ties
Squillo is offline   Reply With Quote
Old 05-09-2014, 10:23 PM   #4
Kill3mall
Kill3mall's Avatar
that should be the last step right? I tried bolting it down first and last and what not. Had some friends tuggin and pulling too! Is pulling the parking brake really gonna help anything?
Old 05-09-2014, 10:30 PM   #5
Squillo
Squillo's Avatar
No.
Performance
AirAid CAI
Hurst shifter
Dyno Tune
Cosmetic
30% tint windows
DRL harness
Old 05-09-2014, 11:40 PM   #6
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Make sure the brake is off. If it doesn't help then no harm done.
Old 05-09-2014, 11:46 PM   #7
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
It can be done!!!
What he said. Use a screwdriver to line up the holes from the opposite side that you are gonna put the bolt through. The insert the bolt while pulling the screwdriver out.
LoneStar is offline   Reply With Quote
Old 05-10-2014, 04:59 AM   #8
pyroguy
pyroguy's Avatar
Drives: ABM #824
BFH and/or a pry bar?
'10 Camaro 2SS/RS | Aqua Blue #824 of 3903 | Silver Stripes
Follow SCPA5 on Instagram! Follow SCPA5 on Facebook!
Check out my build thread
Old 05-10-2014, 09:43 AM   #9
Jamie Mac
NCM-WINR
Jamie Mac's Avatar
Drives: 2010 SS/RS IOM 2014 2LT Stingray
Put it in neutral and make sure the parking brake is off. It makes a difference
also drives a heavily modified Jeep Wrangler. It has LED headlights and wheel weights blacked out with Plasti Dip. It's Baller.
Jamie Mac is offline   Reply With Quote
Old 05-10-2014, 03:02 PM   #10
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
Like Squillo said put a floor jack under the control arm and Jack it up a little at a time and it should help line it up or a lot closer than it is in the picture.
CamaroLS is offline   Reply With Quote
Old 05-11-2014, 09:23 AM   #11
Squillo
Squillo's Avatar
Did you get it done OP?
If so, what worked in getting it aligned?
Performance
AirAid CAI
Hurst shifter
Dyno Tune
Cosmetic
30% tint windows
DRL harness
Old 05-11-2014, 10:44 AM   #12
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
I used a floor jack, pry bar, and a really big azz hammer. I compressed it with the jack used a pry bar to get it close to get the bolt most of the way in. After I got it in a bit it would be super tight I pried it up and hammered the bolt all the way through, it took some muscle and mixture of bad words but it got done.
Trob85 is offline   Reply With Quote
Old 05-11-2014, 11:06 AM   #13
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Show us some before/after photos
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake | Pfadt Suspension | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 686rwhp/590rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 05-11-2014, 11:46 AM   #14
Camarodriver2
Camarodriver2's Avatar
Drives: Bumblebee 1 of 1
You could put the wheels on and push the from the inside with your foot.
Camarodriver2 is offline   Reply With Quote
