JUICEDMOTORSPORTS
Old 05-10-2014, 11:31 AM   #1
hittman
Drives: 2010 Camaro SS
Replacing Toe Arms-Need Help
I am replacing the rear toe arms and have run into a problem. I can not get the
bolt out on the top of the toe link. It is pushed out as far as it will go and is
hitting the body. It looks like to me the bolt was installed the wrong way from
the factory. Should the bolt head with cam be facing the rear of the car or the
nut? The nuts on both toe links are facing the rear of the car. If this is the
correct way how is everyone getting the top bolt out on the drivers side of the
vehicle? Maybe I am missing something here.
"It just costs a little more to go first class"
CAI - LT Headers - HF Cats - Borla S-Type Mufflers - Heritage Grill - Tuned By Ted
hittman is offline   Reply With Quote
Old 05-10-2014, 01:13 PM   #2
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
It's been a couple of months since I did mine...As I recall, those bolts are in there correctly. If you go to the BMR website it has instructions on how to get the bolts out. What I did was to put my floor jack under the diff and support the weight. There are 4 large 15/16 bolts that hold the diff assembly on the bottom going up. With a large breaker bar remove one bolt at a time and then put the bolt back in at least 1.5". Do this on all 4 bolts. Slowly lower floor jack and you will be able to remove the toe arms bolts. After you are done replacing the toe arms, raise floor jack and tighten the 15/16 bolts to 130 ft/lbs.
Dimitrim is offline   Reply With Quote
Old 05-10-2014, 07:49 PM   #3
hittman
Thanks Dimitrim that was the information I needed. This is why Camaro5 is such an awesome forum.
Old 05-10-2014, 10:01 PM   #4
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
Some people like to reverse the bolt when they reinstall so they don't have all that hassle in the future.
LGM G6X3 cam, LGM headers, Vararam intake, throttle body and intake ported by ADM Performance, 477 hp 454 ft-lb tq, tuned by PCMforLess
jamesc1123 is offline   Reply With Quote
