Old 05-11-2014, 06:53 PM   #1
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Setting up suspension on ZL1 for Road Course Racing
I'm interested in hearing what should be upgraded on the ZL1 if I'm setting it up for road course racing? I've read through Pete's suspension evaluation thread but it appears most of it is for the SS.
My understanding is GM upgraded the bushings and various other suspension parts for the 1LE & ZL1, so with that being said what are the critical suspension parts on the ZL1 that should be upgraded?
BaylorCamaro is offline   Reply With Quote
Old 05-11-2014, 08:02 PM   #2
Synner
Drives: 2011 2SS/RS M6
I would be dealing with brakes first, cooling 2nd, suspension third on a ZL1.
Old 05-11-2014, 08:46 PM   #3
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
I'm going to swap out brake fluids but the rotors and calipers should be fine. Pads maybe.
I'm addressing the cooling issues and have my plans for that.
Sooo back to my suspension question.
Old 05-12-2014, 03:38 AM   #4
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
I have installed on my 2013 ZL1 Pedders HD bushings front and rear, lowering springs, and sway bars. Much better feedback from the car after installing the parts. It is also more controlled when the rear begins to step out. I already added Racing Brake rotors, steel lines, and Motul 600 brake fluid. I am using Pete's alignment specs on my ZL1. Good luck with your project.
ZL1-V is offline   Reply With Quote
Old 05-12-2014, 05:39 PM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
While some parts in the ZL1 are better than the SS, most can still be improved upon.
Here are the key things I would suggest:
Subframe bushings
Upper control arm bushings
Trailing arms
Sway bars
Best regards,
Tyler
888-308-6007
Old 05-13-2014, 10:07 AM   #6
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Subframe bushings
Trailing arms
Sway bars
Best regards,
Tyler
888-308-6007
Thanks Tyler! I've been talking to Jordan recently and we're getting some things worked out
Old 05-13-2014, 05:34 PM   #7
JDP Sales
JDP Sales's Avatar
Right on, you're in good hands then.
Best regards,
Tyler
888-308-6007
Old 05-13-2014, 05:49 PM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Good recommendations from Tyler! I agree completely!
T.C. Davis
tc@bmrsuspension.com
813-986-9302
