BeckyD @ James Martin Chevy
Old 05-12-2014, 01:10 AM   #1
ArmyEOD17
ArmyEOD17's Avatar
Drives: 2013 2LT RS
Worth the price? CTS-V calipers
Hey guys, I dont know too much about breaks but I want to upgrade my 2013 2LT/RS to better breaks for the autobahn. There is a guy on base selling some calipers for 300 could someone who knows more about this tell me if its worth the price?
http://graf.bookoo.com/i/44992902
Thanks so much guys
ArmyEOD17 is offline   Reply With Quote
Old 05-12-2014, 01:15 AM   #2
nitto85
Caffeine Injected
Drives: Chevrolets!!
Might be worth it, but they're about 7 years old. Looks like they've been well used, logos are fading likely from heat if I had to guess. You'll need rotors as well as bolts, and I'm not certain if you lines will work you'll probably need SS specific lines.
Pretty much the same calipers that come on a SS.
If I were you, I would wait and get a SS set in better shape for a little bit more money.
The newer CTS-V calipers are 6-piston fronts, this is the older style by the way.
nitto85 is offline   Reply With Quote
Old 05-12-2014, 02:08 AM   #3
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
To answer you're question, Yes for 300 bucs worth the price. But you will need rotors and brake lines.
christianmotox is offline   Reply With Quote
Old 05-12-2014, 11:40 AM   #4
camarostar2010
Drives: 2011 SS
the ctvs brakes are the best money can buy besides super exotic kits. If you look good the ctvs brakes are the ones ferrari and mercedes amg use on their super cars
camarostar2010 is offline   Reply With Quote
Old 05-12-2014, 11:43 AM   #5
sycraft
COTW 5/06/2013
sycraft's Avatar
Those are the same as stock SS brakes, not the 6 piston ones on the current CTSV. Look around a little, someone may be selling Stock SS brakes, the rears on those will need to be modified as I think they are mounted in a different position from the Camaro.
Old 05-12-2014, 12:52 PM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I would pass on these and look at the marketplace here on C5. I just picked up a complete set for $700. (calipers, pads & rotors).
Mods:
Old 05-12-2014, 07:03 PM   #7
toehead93
Drives: 2014 2SS/1LE
You can get a very niced used SS set for $500-$600 on this site wiht everything you need for the front, not sure what the rears go for.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-13-2014, 01:34 AM   #8
ArmyEOD17
ArmyEOD17's Avatar
Drives: 2013 2LT RS
Awesome thanks a lot guys!
