Old 05-12-2014, 06:50 PM   #1
RKCamaro13
RKCamaro13's Avatar
Drives: 2011 Red 2SSRS A6
Sway Bar Endlinks
I just ordered BMR's FE4 swaybars, and I'm trying to find a good endlink to go with it. What would y'all recommend?
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Struct Tower Brace, Foot well Lighting, CNC ported throttle body, Roto-Fab CAI, SW long tube headers, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Magnuson Supercharger (soon to be).
RKCamaro13 is offline   Reply With Quote
Old 05-12-2014, 06:59 PM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
They all pretty much perform the same, so whatever you can get your hands on.
The factory endlinks aren't horrible, but they can get beat up pretty quickly if you really push the car alot (auto-xing).
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 05-12-2014, 07:57 PM   #3
RKCamaro13
RKCamaro13's Avatar
Which ones would you recommend getting?
Old 05-12-2014, 07:59 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Did you go with Part # SB037 or 039?
Best regards,
Tyler
888-308-6007
Old 05-12-2014, 08:09 PM   #5
RKCamaro13
RKCamaro13's Avatar
Best regards,
Tyler
888-308-6007
SB037
Old 05-13-2014, 07:14 AM   #6
marolf101x
Drives: 2010 Test Mule
We've been using our Posi-Links for years with great success:
12mm:
http://www.ridetech.com/store/12-mm-elbow.html
http://www.ridetech.com/store/12-mm-straight.html
10mm:
http://www.ridetech.com/store/10-mm-elbow.html
http://www.ridetech.com/store/10-mm-straight.html
If there's enough interest we could supply a direct bolt-in kit. Our strut moves the sway bar mount, so the link in our kit is shorter than stock.
Skunk Werks
Ridetech
www.ridetech.com
marolf101x is offline   Reply With Quote
Old 05-13-2014, 11:16 AM   #7
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
I have the Pfadt. Don't really have much experience/knowledge for the brands still in business.
Old 05-13-2014, 05:27 PM   #8
JDP Sales
JDP Sales's Avatar
SB037
BMR's ELK005 will work well for you, or Detroit Speed's 031411 is more affordable. Let me know if you have any questions.
Best regards,
Tyler
888-308-6007
Old 05-13-2014, 05:52 PM   #9
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, the front ELK005 end links will work great with the front bar in the SB037 Kit. But for the rear end links, you will have to use factory links or find another aftermarket company.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 05-13-2014, 05:57 PM   #10
JDP Sales
JDP Sales's Avatar
The factory FE4 rears are good. DSE also has their rear endlinks which are awesome! They actually articulate with the sway bar movement rather than relying on the deflection of the factory rubber bushings.
Part # 042305
Best regards,
Tyler
888-308-6007
Old 05-13-2014, 05:59 PM   #11
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I have the Sphon ones. They are noisy, despite the claim to being quiet.
http://www.spohn.net/shop/2010-Chevr...et-Camaro.html
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan coil overs, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Dynamat, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 05-13-2014, 06:09 PM   #12
JDP Sales
JDP Sales's Avatar
Those are for the older FE3 sway bars. The OP is updating to the FE4 style.
Best regards,
Tyler
888-308-6007
Old 05-13-2014, 06:40 PM   #13
sting808
Drives: 2010 SS RS
12mm:
10mm:
The elbows look familiar. Are they available in reverse thread(nut side)?
sting808 is offline   Reply With Quote
Old 05-13-2014, 06:43 PM   #14
sting808
Drives: 2010 SS RS
Part # 042305
Best regards,
Tyler
888-308-6007
Have you tried them with the Pfadt Z-Spec rear bar? How's the clearance with a larger CV axle?
