Solo Performance
Old 05-13-2014, 09:01 PM   #1
Roger Stattel
Drives: 2012 Camaro 1ss
best trailing arms and toe rods with bushings?
I know this may be alot of preference but who has the best package. Pfadt was my first choice but are difficult to get a hold of now. Any experience?
Roger Stattel is offline   Reply With Quote
Old 05-13-2014, 09:14 PM   #2
NYYFan325
Drives: 2010 Camaro 2SS/RS
Read my thread a few below this one... I just got my BMR setup. I recommend contacting Apex-speed and go the same route
NYYFan325 is offline   Reply With Quote
Old 05-13-2014, 09:19 PM   #3
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Everything under the ass end of my SS is BMR.
Old 05-13-2014, 09:30 PM   #4
Roger Stattel
Thanks ya I had read ur thread, was just trying to get multiple views. For the trailing arms is there only one bushing or is there one for each end of the ta? I see that all the toe rods have one for each side.
Old 05-14-2014, 10:30 AM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Hey Roger, the Trailing Arms (TCA026) do utilize both an inner and outer bushing. The inner bushings are included with the Trailing Arms because they are physically installed in the Trailing Arm. The Outer Trailing Arm Bushings (BK006) are sold separately because they are installed in the rear spindle and not directly in the Trailing Arms. We always highly recommend upgrading that Outer Trailing Arm Bushing any time you upgrade your Trailing Arms. Without them, you're not getting the full potential out of the new Trailing Arms.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 05-14-2014, 10:41 AM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
BMR is what I would recommend. Their parts work great and are priced right.
Thanks!
Same here.
Old 05-14-2014, 11:15 AM   #7
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
another vote for BMR. Solid quality and their sh*t works.
BMR Suspension, SLPTVS2300, GFORCE Driveshaft & HalfShafts, Kooks with cutouts and other fun things.
Old 05-14-2014, 11:24 AM   #8
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Thanks Man....that's the best description I've heard yet!!! LOL!!!
T.C. Davis
813-986-9302
Old 05-14-2014, 01:00 PM   #9
Roger Stattel
Alright it looks like bmr then. Can bmr tell me the difference between the two boxed trailing arms. Specifically why is the one with the bearing more expensive? Obvious I want it if it better but can I get an explanation?
Old 05-14-2014, 01:02 PM   #10
NYYFan325
I full expect this quote to be in your signature shortly or I'll be disappointed
Old 05-14-2014, 01:51 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The only difference is the inner connection point, one being a polyurethane bushing, and the other being a Teflon-lined spherical bearing. For a primarily street-driven car, we recommend the poly bushing version just because it will suppress the NVH better than the spherical bearing, and it is still a significant improvement over the stock rubber bushings in the factory trailing arms. The TCA027 with the spherical bearing is more suited to the high HP guys who regularly track their cars and are looking for the strongest arm possible with zero deflection on that inner joint.
T.C. Davis
813-986-9302
Old 05-14-2014, 02:19 PM   #12
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Just a suggestion for the toe rods, I am running the 1LE/ZL1 rods with the spherical bearings.
The rods themselves are identical to the SS, but instead of the soft factory bushings or a slightly stiffer urethane bushing they utilize spherical bearings. Because of the way the loading is applied to the toe rods, the real controlling factor on how well they perform is through the bearings. By eliminating any potential binding because of the bearings, the rod will be able to perform to it's capacity.
Plus, you can find a set of take-offs in the marketplace for under $100 (bought mine for $70).
For the price, you could also look into the Spohn brand carried by JDP. Their bushings are a little stiffer than BMR, and the prices are comperable. Another option would be to look at LSR.
You really can't go wrong with any of them.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 05-14-2014, 02:43 PM   #13
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
BMR, Spohn and DSE from most cost effective to best IMO. The biggest difference you will find between brands is weight, bushing material and arm material.
What bushings you go with will depend on your usage with the car. We have hands on experience with all of the above. Feel free to call, PM or email me anytime with questions and I will be happy to explain the differences and benefits and help get you dialed in with the right parts to meet your application.
Best regards,
Tyler
888-308-6007
Old 05-14-2014, 03:04 PM   #14
forklord
forklord's Avatar
Drives: 2010 2SS
BMR
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
