Old 08-05-2009, 08:10 PM   #1
69 Camaro 09
69 Camaro 09's Avatar
Drives: 69 Camaro, 010 2SSRS
Spacers
Is it bad to use spacers? I'm finding it hard to find any wheels that fit the SS otherwise..
I am new to what spacers really are, whats the problem with them?
Thanks in advance..
69 Camaro 09 is offline   Reply With Quote
Old 08-05-2009, 08:41 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
well there are regular spacers and there are wheel adapter/spacers.
regular spacers are just that, a spacer that goes between the brake/wheel hub and the wheel itself to move the wheel outward
one problem that is seen with these is that you have less wheel stud protruding for the lug nuts to tighten onto which can lead to lug nuts being pulled off or wheel studs being broken depending on how thick the adapter is.
the other style of spacer is the adapter spacer that uses the stock wheel studs and has its own set of studs to mount the wheel to
a couple problems with these is that you now have more isht to break as well as putting stress on the stock wheel studs as well because now you have an extra link in the drivetrain chain.
none of the problems I listed are frequently seen, nor should they scare you from using spacers. I am currently running 1.25" spacer/adapters on my 94Z to fit my 18" C5 Z06 wheels on the back of the car.
I piss excellence
and fart awesomeness
Old 08-05-2009, 08:59 PM   #3
69 Camaro 09
Thank you once again CamaroSpike, i should probably just PM you with my silly questions haha
Old 08-05-2009, 09:13 PM   #4
CamaroSpike23
Truth Enforcer
no problem. I'm here for you guys.
and now that I'm a mod, my PM box is at 5000 so I'm not too worried about it getting filled up anytime soon.
pm me or post up the thread.
I piss excellence
Old 03-06-2010, 09:48 AM   #5
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
Where can you get the above adapters? I need a set of 4.
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
Orange5thGen is offline   Reply With Quote
Old 03-06-2010, 04:36 PM   #6
TresLS'S
'10 SS/RS,'08 C6,'00 SS
TresLS'S's Avatar
Drives: '10 Summit White SS/RS LS3
Good info I was a little concerned about this as well! Orange5thGen: I'm pretty sure H&R makes a 20mm adapter/hubcentric spacer like the one above that uses the stock studs and its own.
TresLS'S is offline   Reply With Quote
Old 03-06-2010, 07:52 PM   #7
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
You can ping Andy at admperformance as well. I think he just put in an order that hopefully he will get soon.
Crowley
Crowley is offline   Reply With Quote
Anyone install wheel spacers ? Santos Wheels and Tires Talk Sponsored by The Tire Rack 4 09-16-2009 09:18 PM
