Old 05-23-2014, 12:35 PM   #1
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
Car takes awhile to start *update
I have a problem. Ever since I got my Maggie installed and tuned my car will take awhile to start sometimes. This only happens if it's been sitting for awhile, and I have no idea what is causing it. The car will crank over but won't start until after about 4-8seconds. Anybody have any insight?
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 05-23-2014, 12:58 PM   #2
Bubble85
Drives: 2012 SS
Had a simalar problem it was a loose ground
Bubble85 is offline   Reply With Quote
Old 05-23-2014, 02:04 PM   #3
Twin2010
Drives: 2010 twin turbo ss
Did you change injector size? My car and a few buddies cars had to take some cranking fuel out after installing bigger injectors. It would start right up cold in the morning then after it sat for a few hours it would crank a while to start. We pulled 20-25 percent fuel out of the cranking fuel and it fixed the problem. You might try that and see if it helps
Twin2010 is offline   Reply With Quote
Old 05-23-2014, 04:10 PM   #4
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
What is your exact parts list and we can better help.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
JANNETTYRACING is online now   Reply With Quote
Old 05-23-2014, 04:11 PM   #5
JANNETTYRACING
If the injector data is correct you never have to Fudge that tune that way.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 05-23-2014, 07:17 PM   #6
jake2212
jake2212's Avatar
here's a list of all the motor mods on my car
CAI intake
catch can
ported TB
LT headers
LS3 conversion
7.400 pushrods
BTR dual valve springs
GT9 cam
ZL1 fuel pump
ADM FPCM
80 lb injectors
Magnuson tvs2300
3" sw retro catback
Old 05-23-2014, 10:23 PM   #7
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
If you turn the key on for about 15sec and then try to start it does it start?
Nitroman28 is offline   Reply With Quote
Old 05-24-2014, 07:48 AM   #8
JANNETTYRACING
CAI intake
catch can
ported TB
LT headers
LS3 conversion
7.400 pushrods
GT9 cam
ZL1 fuel pump
80 lb injectors
Magnuson tvs2300
3" sw retro catback
I suspect these are a brand of injectors that there is no Real Data available to enter in to your calibration and is the root cause of your hard starting.
There is also Some Idle control stuff that needs to be done when a cam is added to the combo.
You should also consider adding
ADM FPCM
ZR-1 Map sensor
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 05-24-2014, 12:38 PM   #9
jake2212
jake2212's Avatar
ADM FPCM
ZR-1 Map sensor
Ted.
Already have the adm FPCM, forgot to mention that. What good would a zr1 map sensor do?
Old 05-24-2014, 12:38 PM   #10
jake2212
jake2212's Avatar
I'll go try that now
Old 05-24-2014, 04:04 PM   #11
jake2212
jake2212's Avatar
Tht worked, so I'm gonna try it again when I get home from work today to see if it was just a one time thing
Old 05-24-2014, 05:48 PM   #12
Nitroman28
Nitroman28's Avatar
We'll I was wondering if your pressure is bleeding off and the pump is taking a little long to build pressure. If its still doing it you need to get your tune looked at.
Old 05-24-2014, 06:24 PM   #13
jake2212
jake2212's Avatar
What would cause that? Bad fuel pump?
Old 05-25-2014, 02:58 AM   #14
jake2212
jake2212's Avatar
just did it again, turned the key for 15 sec, then cranked it and it turned right on.
