JUICEDMOTORSPORTS
Old 05-25-2014, 07:47 AM   #15
2010SSRSM6
2010SSRSM6's Avatar
I had the same problem with FIC injectors and my Maggie. The set I had had a bad seal and lost pressure. Swapped in a set of better (Bosch) injectors and the issue cleared up. If you have FIC injectors, call them and they should be able to help you out. I didn't have any issues with their customer service.
Old 05-25-2014, 10:21 AM   #16
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Had this same problem, which turned out to be a leaking injectors. Try doing a flood clear, you hold the gas peddle down all the way to the floor, while turning your key. Be ready to release the peddle, if it starts right away, check the injectors.
http://www.camaro5.com/forums/showth...aking+injector
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 05-25-2014, 02:16 PM   #17
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
just read that entire thread and that's exactly what's happening to me, son of a b**ch
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 05-25-2014, 03:23 PM   #18
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
I would have the tune checked first. I used FIC60lb and had a problem with it taking longer to start. Took it to a real tuner and problem was gone. Some tuners will say they are good and some are but most just know the basics.
I was having slow starts and rough idle when I first Added the Blower. And fell for the ID850 sales pitch on here and bought a set. Found a new tuner and took the car to him with the ID850's to put in and he said there was no reason to use them. After about 30min he had the start and idle perfect. He said the data that came with them was right on. Listed and sold the ID's. Now using FIC80lbs with no problems. And there is a time when a bad part will go out. Happens to ever manufacturer.
Nitroman28 is offline   Reply With Quote
Old 05-25-2014, 04:24 PM   #19
jake2212
jake2212's Avatar
Alright I'll have the tune checked out ten if it's all good I'll call the injector company
Old 05-25-2014, 05:18 PM   #20
Nitroman28
Nitroman28's Avatar
If you have fic Jeff's a good guy. He will take care
Of you.
Old 06-11-2014, 02:21 PM   #21
jake2212
jake2212's Avatar
tune is good and the fuel rails were pulled to see if the injectors leaked overnight, nothing. any other ideas as to what it might be?
Old 06-11-2014, 02:25 PM   #22
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Is it better if you step on the throttle while cranking?
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 06-11-2014, 02:28 PM   #23
jake2212
jake2212's Avatar
haven't tried that, I'm at work right now I'll try stepping on the throttle while starting when i get home.
Old 06-11-2014, 02:45 PM   #24
TOYMARO
TOYMARO's Avatar
Drives: 2011 Camaro SS/RS 2SS
TOYMARO is offline   Reply With Quote
Old 06-13-2014, 06:46 PM   #25
jake2212
jake2212's Avatar
Okay, so it's not the injectors, injector data, fuel pressure or the tune
Old 06-13-2014, 07:05 PM   #26
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
I'd raise the cranking fuel 10% in the tune and see if it helps or hurts. Still seems like a tune issue to me.
Iam Broke is offline   Reply With Quote
Old 06-14-2014, 12:36 AM   #27
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
Mine does the same thing sometimes. I don't expect it to be leak down, as it starts right up after sitting for a while, then sometimes it takes a long crank to start. Seems that it is something else.
2012LS3VERT is offline   Reply With Quote
Old 06-14-2014, 08:15 AM   #28
JANNETTYRACING
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
