Rick@Livernois
Old 05-25-2014, 01:06 PM   #1
Str8_W8
Deadlift King
Str8_W8's Avatar
Drives: 2012 Camaro SS
VHT Painted Calipers - 1LE Design
VHT's paint line is the best I've ever used. The clear coat looks like Dupont's High Image clear that I used when I painted cars a few years ago. Thanks to thkfast for the write up!
I've used Dupli-Color caliper paint kit in the past but VHT out shines and goes on so much easier. Prep was key. I used 220 grit sandpaper on the factory "Chevrolet" and "Bremo" logos to sand them completely off then used 320 grit to finish that area. Everything else was scuffed with a red scotch-brite pad making sure to get into all the dips and groves. I covered the tops of the brake pads with tape so they wouldn't get painted.
I also scuffed the rotors and sprayed them VHT metallic silver. I painted everything yesterday afternoon and they should be good enough to drive on today. Now, I can get the silver paint off the brake pad's path on the rotor.
Name:  Caliper closeup.jpg
Str8_W8 is offline   Reply With Quote
Old 05-25-2014, 03:19 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
They look great!
Mods:
Old 05-25-2014, 03:28 PM   #3
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2012 Camaro 2SS Convertible
Nice
Where did you get the Chevrolet decals
Ryan
Ryan
* 2012 2SS Camaro Convertible Ashen Gray
Car Build: http://www.camaro5.com/forums/showthread.php?t=257256
Old 05-25-2014, 05:10 PM   #4
RxRated
RxRated's Avatar
Drives: 2013 SS/RS LS3 NPP/Hurst
They are on ebay for $16. I just did this too!
RxRated is offline   Reply With Quote
Old 05-27-2014, 08:41 AM   #5
Str8_W8
Deadlift King
Str8_W8's Avatar
Yep, got them on eBay. Be sure to push the stickers down on the paper they come in or the letters will get stuck and break. I broke the "o" and filled it in with a sharpie. It's actually in the picture above but you can't tell.
Old 06-02-2014, 11:31 PM   #6
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Nice, just did mine in red but used duplicolor I had from my 2010. Sand papered best I could but a pain with all the grooves and angles
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 06-08-2014, 06:41 AM   #7
thkfast
thkfast's Avatar
Drives: '14 Red 2SS/RS/LS3
Looking good! Great job Ryan!
2014 Red Hot 2SS/RS/M6/NPP/Shifter/Nav/Roof/SilverRallyStripes/Airaid intake/GM StrutTowerBrace/50%-35%tint
thkfast is offline   Reply With Quote
Old 06-08-2014, 09:08 AM   #8
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
i used the same write up!
Tmick5jr is offline   Reply With Quote
Old 06-09-2014, 04:57 PM   #9
Outlaw77
Outlaw77's Avatar
Drives: 2010 2SS/RS I.O.M. Camaro 6MT
Looks good! Why did you paint the rotors?
2010 Cammed & Blown Inferno Orange 2SS/RS LS3 6M
Maggie TVS 2300 8 psi/1:1 overdrive cogs/3.6 pulley/LPE GT-14 cam/BTR valve train kit/KB BAP/LPE ZR1 63lbs injectors/NGK TR71X plugs/Roto Fab CAI/Kooks LT's & cat deletes/Magnaflow x-pipe & mufflers/BMR springs/carbon fibre stripes/20% tint
Cam specs: 223/235 duration @ .050 lift - .610/.620 115.0 C
640 rwhp 603 rwtq
Built and Dyno Tuned by Davenport Motorsports
Wheels: Rohana RC7 Matte Graphite 20x10, 20x11 Super Deep Concave + 275/40, 315/35 Nitto NT05
Outlaw77 is online now   Reply With Quote
Old 06-10-2014, 08:24 AM   #10
Str8_W8
Deadlift King
Str8_W8's Avatar
I scuffed, cleaned, and painted the center of the rotors and all of the vented edges so they do not look rusty anymore. The paint where the pad makes contact with the rotor comes off as soon as you use the brakes. I didn't mask it off because I knew it wouldn't sick to the smooth part of the rotor and I have no paint edges.
Old 06-11-2014, 08:10 AM   #11
Taco Time
Taco Time's Avatar
Drives: 2014 1SS
Is there any difference between the VHT engine paint and the caliper paint? I'm wanting to do my calipers yellow. I found yellow engine paint but not caliper paint.
Taco Time is offline   Reply With Quote
Old 06-12-2014, 04:47 AM   #12
thkfast
thkfast's Avatar
Taco,
I think it would be alright to use VHT engine paint on your calipers. There's nothing "special" about the appearance or finish of caliper paint.
One thing that happens on these forums is someone stumbles across a product or procedure that works so well, others want to know the exact products used so they get the same result. There's always a little fudge factoring allowed.
Old 06-12-2014, 08:39 AM   #13
Str8_W8
Deadlift King
Str8_W8's Avatar
Originally Posted by thkfast View Post
Taco,
I think the engine paint does not shine like the caliper paint. I would also get the VHT clear coat spray and do several coats over the paint. The paint already shines good but the clearcoat makes them shine a lot better and brake dust can be easily removed.
