Old 08-06-2009, 10:49 PM   #1
fireresq157
fireresq157's Avatar
Drives: 1997 SS & 2010 2SS/RS
Anyone have issues with clear coat and bird poop?
Need help! I've had the car a month now and had even waxed it a couple of weeks ago. Anyhow I walk outside today and there was two bird droppings on the roof. I was in a hurry going somewhere so I figured I'd get to it later in the day. The droppings could not have been on the car more than 24 hrs more likely 12. Anyhow all the stuff washed away no problem, but when I walked around the car and looked across the roof I noticed the outline of the splatters where still there . Upon closer inspection the whole area where the poop was looked to have damaged/smudged the clear coat finish. I tried continuously washing the area and even using zanos all in one cleaner polish, but very little if any change. The only think I can think of to do is claying the area and re-polishing. Anyone else have any ideas or solutions ? Thanks. I've never had a finish on any of my cars and 3 other camaros be smudged like that hope this is not a sign of things to come.
fireresq157 is offline   Reply With Quote
Old 08-06-2009, 10:53 PM   #2
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Yep, mine did that as well...
Can only be taken out wetsanded. Took her up to friend who manages body shop at Chevy dealer. It is from the acid in bird crap.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 08-06-2009, 10:59 PM   #3
fireresq157
Would claying work the same?
Old 08-06-2009, 11:03 PM   #4
Banshee
Banshee's Avatar
Clay takes sediments out..what you have is etching of the clearcoat. You can wetsand yourself with 2000 grit...but better left to a pro.
Old 08-06-2009, 11:05 PM   #5
Banshee
Banshee's Avatar
Good read for a DIY repair..
http://carpaint.blogspot.com/2005/07...-your-car.html
Old 08-06-2009, 11:09 PM   #6
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
its a chemical burn. you wont leave the next one on.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 08-06-2009, 11:11 PM   #7
Vash
Drives: 00 Blazer
Time to order a http://www.zainostore.com/ kit.
Old 08-06-2009, 11:13 PM   #8
fireresq157
I've never had a problem like this with any of my other 6 cars I've owned.
Old 08-06-2009, 11:16 PM   #9
Vash
Drives: 00 Blazer
Well most of the time a cheap wax will be put on the car when the dealers do make ready prep. If you don't want to spend money on Zanio there are a couple others cheaper that are good. Look in Cosmetics Forum.
Old 08-07-2009, 01:13 AM   #10
"prima"Donna
HWAY STR
"prima"Donna's Avatar
Good luck to you...hope you get the "spot" out.............good to know that "sooner, rather than later" is important in that type of situation...I always try my best to remove it ASAP, however, that's not always possible......
~ HWAY STR ~
Old 08-07-2009, 01:16 AM   #11
gplus
gplus's Avatar
Drives: 2010 RY SSRS 2010 IBM LT2
mquires number 9 is the ticket to getting it out
gplus is offline   Reply With Quote
Old 08-07-2009, 01:32 AM   #12
Banshee
Banshee's Avatar
I have 2 coats of Zaino Z5 and 2 coats Z2 with 2 coats Grand Finale.
It didn't make a difference...
Heres the scoop on the poop..
If car is hot and a bird dumps and it dries, expect clearcoat damage. If car is cool, and bird takes a dump, damage is much less...Also depends on bird, diet and acid content.
That coming from two guys with 45 years in the paintbooth for GM.
Old 08-07-2009, 06:53 AM   #13
fireresq157
I had used zaino products I thought it would have done a better job.
Old 08-07-2009, 08:55 AM   #14
thebighar
Drives: 2010 1LT CGM RS/CC
Just get it off asap. it doesnt take long to stain. Dont just wipe it off, Bird crap has little tiny stones in it that will scratch the hell out of your car. pour hot water over it until its gone, try not to wipe it, but as soon as you see it get it off, once the sun hits it it doesn't take long to leave a mark. I know this because my slob ex wife left tons of it on her 50,000 tahoe and never cleaned it, stains everywhere now.
thebighar is offline   Reply With Quote
