JDP Motorsports
Old 08-07-2009, 12:16 AM   #1
tom692010
Drives: 4 wheels
Did I hurt my chances for better time
First time drag racer last night out at Bandimere speedway in Colorado. About 5000ft above sea level. My question is on all of my runs except 1 I ran the tack to about 5500 rpm before shifting. At that rpm I never made it to 4th gear. Since I'm as green as the day is long on this matter should I have shifted to the next gear before 5500. Car was still pulling pretty good as I past the finish line so I'm not sure. Car is bone stock 1ss.
tom692010 is offline   Reply With Quote
Old 08-07-2009, 12:22 AM   #2
1320junkie
Drives: The Imperial Army
man the air is thin up there..whew..I would try some runs shifting around 58-5900rpm a few times...but then how is she breathing up there?
Old 08-07-2009, 09:03 AM   #3
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
I assume you have an LS3? And, Yes, you hurt your times significantly, considering you shifted over 1000 rpm BEFORE redline. This motor makes peak hp at 5900 rpm, you never even got there! I understand the tach is a bit lazy, particularly in first gear, but get it as close to 6600 as you can before shifting, just back it down a bit if you find you are hitting the limiter. Don't worry, you won't hurt it.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 08-07-2009, 02:11 PM   #4
tom692010
Drives: 4 wheels
wow 6600, I though the limiter was at 6000 and shifting a little early not trusting the factory tac.
thanks,
BTW yes it is a LS3
Old 08-07-2009, 02:14 PM   #5
tom692010
Drives: 4 wheels
No air
That is one of the issues. And having the stock air cleaner in it doesn't help. I ordered the CAI Henessy has out but it has not arrived yet. I will have it by the time I get to the track again in about 3 weeks
Old 08-07-2009, 02:15 PM   #6
1320junkie
thanks,
BTW yes it is a LS3
I would just shift a little past the meat of your powerband
Old 08-07-2009, 02:18 PM   #7
2010 2-Tone
2010 2-Tone's Avatar
Drives: 2010 RY 2SS with Custom Stripes
At exactly what rpm does the limiter come in??
2010 2-Tone is offline   Reply With Quote
Old 08-07-2009, 06:55 PM   #8
Timberline
Timberline's Avatar
Drives: 2010 SS/RS,LS3,M6,VR
I raced at Bandimere for over 20 years and know what you are up against with the thin air. The track is at 5800' so please don't feel bad about not matching the sea level car times. Only compare your car to other cars at Bandimere. Don't worry about sea level times.
To answer your question about rpm and an extra shift before the end of the track.
I would start off with shifting your car at 6000 at each shift since the red line is at 6600rpm. Make two runs like that then raise the shift points by 200rpm and see if it gets quicker, if it does raise it 200rpm more once you reach this point raise or lower by 100rpm. You will soon find the sweet spot where it runs the best. Since I don't have my car yet I can't say where the rev limiter comes in. Like someone else said if you do hit the rev limiter you haven't hurt the car its there to protect it and you certainly don't want to use the rev limiter as a shift point , you just lose time if you do that.
These cars are geared for 155+mph so it is not real suprizing that you never made it to fourth gear.
Your best times will be run on cool evenings at street night or test & tunes at night. If you run at Bandimere during the day in the heat of the summer the DA will reach as high as 15,000+ feet above sea level which = slower. Been there done that many times.
2SS/RS, Victory Red, Black Leather, LS3, 6spd, Polished wheels - R6P -
Timberline is offline   Reply With Quote
Old 08-08-2009, 12:15 AM   #9
tom692010
Drives: 4 wheels
Thanks for the info. I've been experimenting with each pass. My rev limiter I believe kicks in closer to 6000. I had it kick in 2x while I was on the road . I really wanted to know if I should have put it into 4th to get a better time. Knowing I was headed in the right direction is good to know. Ran only 5 runs taht night,on line for a 6th but the rains came. All in all I had a blast. Now I can't wait to get back there to keep improving.
Old 08-08-2009, 12:20 AM   #10
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
This is how your car feels.....lol
GMtothecore is offline   Reply With Quote
Old 08-08-2009, 12:23 AM   #11
JewelZ
Just Lovin' My Camaro!
JewelZ's Avatar
Drives: CGM 2LT/RS/AUTO
Shift after 5500 and before 6000.
CGM( GRAY 2 tone interior ) 2LT/RS/AUTO
NJHKKM $29,965.00 1EH37 1100 03/28/2009 AFF, B34, DCP, FE9, GBV, LLT, MX0, SGC, UQA, WRS, 2LT
50 YEARS FROM NOW, DON'T YOU WANNA BE ABLE TO LOOK BACK AND SAY YOU HAD THE GUTS TO GET INTO THE CAR!?!?
ORDER STATUS : 6000 as of 08.18.2009. VIN# 33,985!!! His name is 'GOLIATH'!!!
GOT MY CAR!!!! AND I LOVE IT!!!!
JewelZ is offline   Reply With Quote
Old 08-08-2009, 08:09 AM   #12
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I thought the rev limiter was 6600 rpms in the LS3s? I also thought redline was 6500 rpms?
Based on this information you should be shifting a lot higher than you are
(around 6300 rpms or so).
The L99's rev limiter is around 6200 rpms. I tap shift my A6 up around 5800 rpms. So you should be able to shift a lot higher than that with an LS3.
Old 08-08-2009, 09:18 AM   #13
rayhawk
rayhawk's Avatar
Fourth gear is very tall in this car, I would stay in 3rd as long as possible. You hit the rev limiter at the top of first gear at only 6000? I think that is just how much lag the tach has due to the faster acceleration in first gear. These should be your shiftpoints, at 6600 rpm:
1-2 54 mph
2-3 79 mph
3-4 114 mph
4-5 163 mph
Notice that 4th gear doesn't run out until over 160 mph, I think if you shift into 4th early it will definitely hurt your time and trap speed.
-Al Bundy
Old 08-08-2009, 09:18 AM   #14
Timberline
Timberline's Avatar
Keep experimenting with it you will get quicker.
Since I don't have my car I don't know where red line is or where the rev limiter comes in. It is suprizing to me that the rev limiter is coming in at 6000 if red line is actually at 6600.
I'm really disappointed from the camaro lap time in Nurburgring!!! _GTO_ 5th Gen Camaro SS LS LT General Discussions 84 11-30-2009 10:12 PM
First Time Camaro Owners? Legend 5th Gen Camaro SS LS LT General Discussions 105 11-10-2008 01:15 PM
New Ring Time for ZR1: 7:22.4 DGthe3 General Automotive + Other Cars Discussion 23 10-30-2008 04:28 AM
My last day here for some time. 13F20 Off-topic Discussions 52 09-24-2008 09:34 PM
Time Problem? Maybe? TAG UR IT Site Related Announcements / Suggestions / Feedback / Questions 9 08-30-2007 04:53 AM
