HURST
Old 08-07-2009, 12:26 AM   #1
tattoopunk
Drives: 2010 2lt Camaro
Oil pressure gauge
I changed my oil at 1500 miles and decided to switch to fully synthetic oil. I have now noticed the oil pressure going up and down with the rpms. I didnt pay attention to before I changed oil. Im wondering if anyone else has experienced this or is it normal? I have the 3.8 v-6.
tattoopunk is offline   Reply With Quote
Old 08-07-2009, 12:45 AM   #2
Kwaz1335
The Kwaz
Drives: Black 2010 Camaro 2SS/RS
Send a message via AIM to Kwaz1335
Usually its a sign of normal working pressure. Unless the needle is sweeping the full range of the gauge you really have nothing to worry about. If its dropping tottally in the danger zone and picking back up you either have a bad oil filter, not enough oil in the system a clogged oil pump pickup, or the sensor itself is bad. Sometimes with a restrictive oil filter the oil pressure dose drop slightly from time to time but its nothing to get all worried about. If your really concerned with the dips in oil pressure I would recommend switching to a more free flowing oil filter. In my Mustang I was using FRAM oil filters and had the same situation and ended up switching up to a Mobil 1 oil filter which solved the problem. Hope this helps
And oh yeah...the Camaros come from the factory with Mobil 1 synthetic..so essentially you did not switch to synthetic
Ordered:3/13/09
1100: 3/13/09
3300: 5/12/09
Picked up and brought home 6/26/2009
2010 Black on Black SS/RS Camaro
Silver stripe package
Ground effects package
6 Speed Manual Transmission with Hurst short throw, Magnuson Supercharger, SLP loudmouth 1 kit.
Kwaz1335 is offline   Reply With Quote
Old 08-07-2009, 09:33 AM   #3
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
This is normal. Oil Pressure will change as you go through the rpm range.
Crowley
Crowley is offline   Reply With Quote
Old 08-07-2009, 10:36 AM   #4
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
1) V6 did not come with synthetic.
2) Mine idles @ 30# and off the end at any RPM over idle.
3) This started a 450 miles.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 08-07-2009, 11:12 AM   #5
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Mine does the samething and I PM fbodfather to see if he could look into this...no answer yet.
RickRay is offline   Reply With Quote
Old 08-07-2009, 01:42 PM   #6
OUR72GTO
OUR72GTO's Avatar
Local dealers have no idea other than it "might" be a faulty sensor.
Looks like there may be a bunch of them.
Old 08-07-2009, 09:53 PM   #7
tattoopunk
Thanks to all who replied. Im just gonna roll with it and let it fly.
Old 08-08-2009, 12:01 AM   #8
ozman2005
#8504
ozman2005's Avatar
Drives: 2016 Camaro 2SS
Ok, no one else said it so I'll be that guy. It's a 3.6 V6, not a 3.8
Just for g.p. and my OCD doesn't allow me to leave the thread until it's corrected
2016 Camaro 2SS Hyper Blue, A8, NPP
Past:
2010 Camaro 2SS/RS M6, Silver Ice Metallic w/ Cyber Gray Rally Stripe package, Inferno Orange interior, factory "perma-grin"
VIN: 2G1FT1EW1A9108504
Delivered 7.7.09
ozman2005 is offline   Reply With Quote
Old 08-08-2009, 12:13 AM   #9
OUR72GTO
OUR72GTO's Avatar
I thought about
1) 3.6 does not come with.........
Already corrected one .......
Old 08-08-2009, 12:20 AM   #10
JewelZ
Just Lovin' My Camaro!
JewelZ's Avatar
Drives: CGM 2LT/RS/AUTO
Here is the section from the Owner's Manual PDF.
Engine Oil
Pressure Gage
The oil pressure gage, located in
front of the shifter, shows the engine
oil pressure in psi (pounds per
square inch) when the engine is
running. Canadian vehicles indicate
pressure in kPa (kilopascals).
Oil pressure may vary with engine
speed, outside temperature and oil
viscosity, but readings above the low
pressure zone indicate the normal
operating range. When the oil
pressure reaches the low pressure
zone, a message appears in the
Driver Information Center (DIC).
See
Engine Oil Messages on
page 4-32
and Engine Oil on
page 9-10
for more information.
WARNING
Do not keep driving if the oil
pressure is low. The engine can
become so hot that it catches fire.
Someone could be burned.
Check the oil as soon as possible
and have the vehicle serviced.
Notice:
Lack of proper engine oil
maintenance can damage the
engine. The repairs would not be
covered by the vehicle warranty.
Always follow the maintenance
schedule in this manual for
changing engine oil.
A reading in the low pressure zone
can be caused by a dangerously
low oil level or some other problem
causing low oil pressure. Check
United States
Canada
4-12 Instruments and Controls
CGM( GRAY 2 tone interior ) 2LT/RS/AUTO
NJHKKM $29,965.00 1EH37 1100 03/28/2009 AFF, B34, DCP, FE9, GBV, LLT, MX0, SGC, UQA, WRS, 2LT
50 YEARS FROM NOW, DON'T YOU WANNA BE ABLE TO LOOK BACK AND SAY YOU HAD THE GUTS TO GET INTO THE CAR!?!?
ORDER STATUS : 6000 as of 08.18.2009. VIN# 33,985!!! His name is 'GOLIATH'!!!
GOT MY CAR!!!! AND I LOVE IT!!!!
JewelZ is offline   Reply With Quote
Old 08-08-2009, 01:22 AM   #11
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
Yeah, it'll increase as you're RPM's go up. No worries.
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
Old 08-10-2009, 12:04 PM   #12
OUR72GTO
OUR72GTO's Avatar
Oil pressure gauges work with the read out in the middle...........this one is off the deep end past the end. More like as mini speedometer
Old 09-27-2012, 12:44 PM   #13
rocknRllr
rocknRllr's Avatar
Drives: 2013 2LT Crystal Red Metallic
Same here - went to full synthetic and my idle is fine; however while i'm driving at higher speeds the gage is pegged.
rocknRllr is offline   Reply With Quote
best oil pressure??! omarrakeen 4th Generation Camaros 10 04-12-2009 07:47 AM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
