Gen5DIY
Old 05-30-2014, 04:24 PM   #1
salvagelife
salvagelife's Avatar
Drives: 2010 camaro ss
LT turbonetics help
has anyone instaled a LT headers on a turbonetics kit ? i have full bolt ons and have the stock headers and cats which i told my shop and he said he can make it work and fabricate new pipe, should i go this route?
salvagelife is offline   Reply With Quote
Old 05-30-2014, 04:54 PM   #2
Unreal
Drives: 2006 Z06
Won't help and will be a royal waste of money. That kit is designed around stock manifolds. If you want to do custom might as well just go full out custom front facing manifolds.
Nick
Corvette Z06 -1200ish rwhp
Old 06-01-2014, 11:00 AM   #3
ParkerB57
COTW 11/12/12
Drives: 1SS RS IBM
Call Turbonetics and see what they say, also Raymond Performance in Indy has experience at turbonetics mods after the base kit, good luck
Ben
ParkerB57 is offline   Reply With Quote
Old 06-01-2014, 06:25 PM   #4
caper
Drives: 2010 IOM 2ss/RS
I would just leave the stock manifolds and do a cat delete, that will give you more HP and avoid any catastrophic cat issues. also if you need to put the cats back on for inspection it will be easier. not to mention it will all be cheaper. btw the clearance for the up pipe to the turbo is slim, I don't think the system works with shorties either so a set of long tubes may not have enough room, even custom ones.
Turbonetics running 8lbs boost at 563/559 tuned by Cunningham installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 06-07-2014, 09:10 PM   #5
salvagelife
Ok I had him just installed my stock headers and cat , cats deleted ? I can have any muffler shop deleted them right
Old 06-07-2014, 11:39 PM   #6
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
I just ran into this problem today too.. I am having my shop make a custom pipe.
DaFisch is offline   Reply With Quote
Old 06-12-2014, 01:25 AM   #7
fox149
Drives: Yellow 2010 SS
do they not use the stock manifolds to try to keep it 50 state legal on emissions. You might get more horsepower with out the cats, better flow is ususally better hp with turbos. It'd call them and ask about it. I had a turbonetics kit on a 350z, no cats ran amazing was faster than a stock SS tbh. If the Camaro kit is as good and you can get bigger gains outta a dif toon, lt,s and a dif intake i'd be in for one. Post what you find out
fox149 is offline   Reply With Quote
Old 06-16-2014, 03:16 PM   #8
salvagelife
Do I have to retune it if I take my cats off ?i know I have too if I want more hp
Old 06-17-2014, 04:48 PM   #9
DaFisch
DaFisch's Avatar
yes to tune out the cats or the check engine light will be on.
Old 06-17-2014, 08:19 PM   #10
salvagelife
Aright thanks just wanted to make sure I wasn't going to mess something up , I just wait until I retune my car , just wanted more sound , to quite for my tastes with cats :/
