Gen5DIY
Old 08-07-2009, 08:04 AM   #1
RoyalKev
Drives: 2010 Camaro SS
DIY painting your engine cover
Can some one put up some nice instructions on how to properly paint the engine cover with heat enamel spray paint and clear. Im going to do this tomorow and want to see how I should do it.
RoyalKev is offline   Reply With Quote
Old 08-07-2009, 08:04 AM   #2
RoyalKev
P.S I know a little bit about painting but im not a genius at it.
Old 08-07-2009, 11:45 AM   #3
viper1cobra
Member Club Elite #131
viper1cobra's Avatar
Drives: 2017 50th Anniversary H50 2SS
I would like to know also. I think that the painted engine cover is a great eye catcher with hood open.
viper1cobra is offline   Reply With Quote
Old 08-07-2009, 02:47 PM   #4
Tecca
Tecca's Avatar
Drives: ...
Step 1: Scuff it up with some 600 grit sandpaper. Note: if you want it ultra smooth as the cover has some texture start with 180 and work your way up
Step 2: Spray a light coat of adhesion promoter then follow with a mrdium coat.
Step 3: Spray on a plastic primer a couple coats, if you see in defects this is the step to fix them.
Step 4: Paint multiple light coats of the base coat.
Step 5: Put atleast two coats of clear
Step 6: wait at minimum 24 hours recommended 3 days for the clear to completrly dry and finish with some rubbing compound for the ultimate shine.
Quick and dirty steps but should help you out
Tecca is offline   Reply With Quote
Old 08-07-2009, 10:56 PM   #5
Forrest
Drives: 2001 Pontiac Grand Prix
http://www.camaro5.com/forums/showthread.php?t=23340
Although I probably should ahve seperated them >.<
Forrest is offline   Reply With Quote
Old 08-08-2009, 09:22 AM   #6
oilman63
rjt ordered 10-15 2ss
oilman63's Avatar
Drives: 2010 2SS badass camaro
painting cover
Hold tight guys.My nephew is awesome painter.He just mixed up some RJT for mine.I'll post pictures sometime next week.Sticking paint on plastic's not as easy as one would think.I'll pick his brain later today.
oilman63 is offline   Reply With Quote
Old 08-08-2009, 02:03 PM   #7
oilman63
oilman63's Avatar
plastic prep
PPG ONECOICE PLASTICPREP .Follow instructions.
Old 08-09-2009, 04:25 PM   #8
Rookie13
Hooked on AutoX
Rookie13's Avatar
Drives: 1SS/RS
Send a message via Yahoo to Rookie13
YUP! The most important step in this whole process if the preparation of the raw Plastic. If it is not prepared properly you will not have any adhesion and your paint will be gone in no time.
Fact: Turn the piece of plastic over and look on the underside. You should see some coding, like... ABS, ABS-c, ABS+, etc... Use those codes to find the adhesion promoter you need to buy at Napa or where ever you shop for your auto paints... (Tip: you can call a local body shop and ask them where they shop. Most use local vendors for this stuff.)
Good Luck and make your paint stick!!
_________________________
Camaro5 Fest 2010 Panogram Photo of the Host Hotel
Rookie13 is offline   Reply With Quote
Old 08-15-2009, 01:12 PM   #9
GJG
GJG's Avatar
Drives: 2SS
Sleep well America.....my MARINE has your back......
GJG is offline   Reply With Quote
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
Is anyone else dissapointed by the V6 ENGINE COVER ?? Grandeos Cosmetics and Lighting Modification Discussions 59 11-01-2010 01:13 PM
Engine cover = giant heat trap? rodimus prime Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 86 08-20-2009 12:53 PM
My engine cover, where is it??? 350 HRSS Camaro Price | Ordering | Tracking | Dealers Discussions 7 07-05-2009 10:11 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
