Jason 98 TA
Old 08-07-2009, 12:21 PM   #1
logan1080
logan1080's Avatar
Drives: 2003 Crew Cab Duramax
Best way to store car over winter?
What should I do? Just park it with some fuel stabilizer in it or do I have to pull off the tires and put it on blocks or what? What is the best way to store a car over winter, what do you do to prep the car for storage (ex fuel stabilizer and what else?)?
logan1080 is offline   Reply With Quote
Old 08-07-2009, 12:29 PM   #2
coolman
Guest
If it's just for the winter, I never do anything but keep a battery maintainer on it and store it in a heated garage. I've been doing this for twenty years and never had any problems. I do run mine a couple of times during the winter just to heat them up for a while to relube.
coolman is offline   Reply With Quote
Old 08-07-2009, 12:30 PM   #3
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
Ship it down to Florida...I'll keep it in my garage for ya.
Shortcuts can slow you down...
Chevyrocker is offline   Reply With Quote
Old 08-07-2009, 12:32 PM   #4
coolman
Guest
with the keys right?
Old 08-08-2009, 03:45 PM   #5
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Clean and dry out your garage or space thoroughly..
Fill gas tank to full
Wash car and wax
Change the oil and allow to run and warm up.
Remove battery
Inflate tires to 40-42 PSI (and maintain that)
Put a large vinyl sheet on concrete under car to prevent moisture under car.
Place dessicant in interior after thorough cleaning. Will keep moisture in balance and will keep moldy smells at bay.
I will be placing my Camaro on jack stands to keep suspension parts from premature aging and reduce flat spots.
I put a dehumidifier in garage with my Harley.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 08-08-2009, 06:31 PM   #6
logan1080
logan1080's Avatar
Wash car and wax
Remove battery
What exactly is dessicant?
Old 08-08-2009, 06:46 PM   #7
DEW
Drives: Hoopdee
Rat repellant!
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 08-08-2009, 07:23 PM   #8
ABM 2SS
Drives: -
Desiccant is used to remove excess moisture or humidity from the car. I have heard that placing a bar of Irish Spring soap will keep mice or rats from taking up residence in a vehicle that is being stored over the winter.
ABM 2SS is offline   Reply With Quote
Old 08-08-2009, 07:43 PM   #9
Banshee
Banshee's Avatar
Dessicant..
http://www.adorama.com/AQU905.html
Old 08-08-2009, 07:47 PM   #10
Purdue2011SS
Boiler Up!! POTFH
Purdue2011SS's Avatar
Drives: 2011 2SS/RS IOM Camaro
ill be driving mine unfortunately, in freakin indiana...that'll be fun when there snow out...not
Purdue2011SS is offline   Reply With Quote
Old 08-09-2009, 02:59 PM   #11
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
I've been parking the SS for the winter for years. (garaged)
- full tank
- new oil and filter
- fresh detailing
- trickle charger on battery
Thats it. Never had a problem.
Moose is offline   Reply With Quote
Old 08-09-2009, 07:41 PM   #12
SoloSK71
SoloSK71's Avatar
Drives: 2010 Camaro 2SS
If you are going to keep it in a garage then you might also think about one of these.
http://www.budgetcarcovers.com/Produ...ar_Covers.html
- SK
- 2G1FT1EW9A9132212
- Life is hard when destiny believes in you.
- As coherent as a pit bull in a spin dryer. A dribbling tartan frothbucket.
- Good money, bad girls. How can life be any better?
- God saves. The devil invests.
- This may be the ultimate guide to problem solving.
Originally Posted by MontyCarlo View Post
it's not a WD-40 problem, so it's got to be a duct tape problem
SoloSK71 is offline   Reply With Quote
Old 08-10-2009, 11:46 AM   #13
billwright
Drives: Black
Desiccant is commonly knows as Silica Gel. These are the packets you see in with your new shoes, purses, electronics, etc. They are the most absorbent product commercially available, they are used to dry out phones, wet electronics, seeds, etc.
Desiccant placed in a car would help against moisture damage like Mildew and Mold. But those little Silica Gel Packets won't cut it, you would need something designed for the purposes. Here are some examples of products that would be more in line to use with a car, Dry-Packs Dehumidifier Boxes:
http://www.silicagelpackets.com/dry-packs-dehumidifier/
billwright is offline   Reply With Quote
Old 08-10-2009, 11:28 PM   #14
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
If it takes any longer for me to get an allocation, the factory will be storing mine in boxes and parts bins this winter
bono83 is offline   Reply With Quote
Got my Zaino today lordfriday2 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 261 05-31-2014 11:00 PM
Car show creetons!!!! attymf 5th Gen Camaro SS LS LT General Discussions 51 08-09-2009 10:19 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
"The car of the future may turn out to be no car at all." Scotsman General Automotive + Other Cars Discussion 2 11-03-2007 01:22 AM
