Old 08-07-2009, 11:31 AM   #1
Chris@Livernois
Chris@Livernois's Avatar
Drives: 2010 Camaro
2010 SS - Corsa, Rotofab, U/D Pulley - VIDEO
Today we had a customer bring his L99 Auto in for some mods. We installed a Corsa exhaust system, Rotofab CAI, and SLP U/D Pulley. He then asked that we made a video like the one of our G8 on YouTube....
Baseline numbers were 327 RWHP / 340 RWTQ. With a tune only it made 344 RWHP / 362 RWTQ. After installing the Corsa, Rotofab, and pulley it made 363 RWHP/ 376 RWTQ.
Stock vs. Tune
Stock vs. Corsa, Rotofab, and Pulley
Click Here for a video showing Start, Idle, Rev, Dyno, and Street Footage.
Regards,
Rick LeBlanc
Livernois Motorsports
Chris@Livernois is offline   Reply With Quote
Old 08-07-2009, 11:43 AM   #2
logan1080
logan1080's Avatar
Drives: 2003 Crew Cab Duramax
How much did all that cost him?? Sounds pretty good.
logan1080 is offline   Reply With Quote
Old 08-07-2009, 01:15 PM   #3
Chris@Livernois
Drives: 2010 Camaro
The entire package was $2,499.00 installed and tuned.
Thank you
Regards,
Rick LeBlanc
Old 08-07-2009, 01:56 PM   #4
RR
Nie
Drives: Camaro 2SS/RS
VERY NICE! How much HP did the Roto Fab make by itself? How much HP would a Borla S Type, Hennessey CAI, Kooks Headers, MTI High Volume oil pump, MTI Spark Plug Wires, Vengeance Racing 25% underdrive pulley, and a 160 degree thermostat make?
RR is offline   Reply With Quote
Old 08-07-2009, 01:58 PM   #5
logan1080
logan1080's Avatar
Haha you won't really know for sure until you do it and dyno it!
Old 08-07-2009, 02:01 PM   #6
GTAwheelman
Drives: 1985 Camaro Sport Coupe
Thank you
Regards,
Rick LeBlanc
thats not bad,
man that exhaust sounds great.
GTAwheelman is offline   Reply With Quote
Old 08-07-2009, 04:48 PM   #7
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Nice numbers and cool vid
Old 08-07-2009, 05:00 PM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Those numbers are really good. If that L99 had long tube headers and high flow cats one would expect it to gain another 20-30 rwhp. That would put that L99 in the 380 - 390 rwhp range.
That's seems almost too good to be true.
Are his numbers in line with what the other stock L99's are pulling on your dyno? Because I'm trying to see if I can find a relationship between temperature and humidity and lower stock dyno numbers. I'm finding that high humidity combined with hot temperatures are negatively affecting some of the stock L99's.
So far the three highest stock L99 dyno numbers I've seen have come from Northern states (N.Y.and Michigan).
Old 08-07-2009, 06:06 PM   #9
Chris@Livernois
Drives: 2010 Camaro
Thanks for all of the replies!
All of the stock L99's we've done to date have made 315-320ish RWHP stock. With the correction factor and a calibrated dyno, the numbers should be the same no matter what.
-Rick
Old 08-07-2009, 06:59 PM   #10
9c1ny
9c1ny's Avatar
Drives: C6 Zed-oh-six
nice numbers!
how many miles on the car?
I hope to get a CAI on mine soon and another dyno pull, hoping for 350/365ish with just a tune and CAI
9c1ny is offline   Reply With Quote
Old 08-07-2009, 07:24 PM   #11
jrpxxii
jrpxxii's Avatar
You stated you put the U/D pulley on this car, I am guessing it also requires new belts? I have considered doing pulley on mine but can't get an answer from anyone as to where I will get the correct belts to go with new pulley.
Old 08-07-2009, 07:29 PM   #12
Chris@Livernois
Drives: 2010 Camaro
Originally Posted by 9c1ny View Post
nice numbers!
2500 Miles.
You should be in the ballpark. From tests we've done, it seems the Corsa is worth 10 HP.
Yes, it does require new belts. The instructions had the wrong parts numbers, so we had to call SLP to get the correct numbers.
-Rick
Old 08-28-2009, 09:06 PM   #13
Roto-fab 1
Roto-fab 1's Avatar
Drives: 16 Camaro SS w/ Roto-fab CAI
Roto-fab CAI
Thanks for making the Roto-fab CAI part of the package! We've been consistently seeing good numbers with a wide array of combinations.
Roto-fab 1 is offline   Reply With Quote
