Gen5DIY
Old 06-04-2014, 02:12 PM   #1
brt3
Runs with scissors...
brt3's Avatar
Drives: '14 Z/28s SIM/SW
Z/28: Let's Talk Tires!
I thought it might be time to start a single thread devoted to tire choices -- both for street/light track usage, and for dedicated track purposes. I started a discussion around tires for street and/or track usage in cool/damp weather, where the Trofeo Rs are not happy: SEE THAT HERE.
Here's my attempt at a discussion of alternative tire choices for both Street and Track usage.
STREET CONTENDERS -- ALSO FOR OCCASIONAL TRACK USE
1. Michelin Pilot Super Sports: Excellent (though ubiquitous). Kinda like the Class President in that they are good everywhere with no glaring flaws.
2. Yokohama ADVAN Neova AD08 R: a.k.a "The Dark Horse" -- which won't match the PSS in the wet but might just be the Track Champ for a street tire. Massive dry grip, which may make them well-suited to a car designed around the Trofeo R, but new enough that there are very few reviews available.
EDIT on 07/16/14: Just installed a set on my OEM wheels. Just a few miles so far, but they seem to be a good middle-ground between Trofeos and the S-04 on the street. No tramlining on irregular surfaces, very responsive feel on the street, but they are firmer (slightly harsher ride) and noisier than the S-04. Will report back after trying them under more aggressive cornering...
3. Bridgestone Potenza RE-11: Highly regarded and seem to offer good AutoX and track performance. NOTE: The RE-11A is coming soon!
4. Bridgestone Potenza S-04 Pole Position: This well-reviewed all-rounder usually finishes second to the Michelin PSS. I had to scramble to mount more street-oriented tires for a drive from TX to CA, and ended up with Bridgestone S-04 Pole Positions because the others weren't available. Wonderful on the street, but the Z/28 simply overpowers them on-track. Despite playing around with tire pressures, I could NOT get these to the point where they were anything but frustrating on-track. This was at Sears Point in moderate temperatures (highs never exceeded 80 degrees). Using a grading system based on my needs, I have to give these a FAIL.
TRACK CONTENDERS -- MAX PERFORMANCE
1. Pirelli P-Zero Trofeo R: good enough that Team Z/28 designed the car around them. Outstanding on-track, but how long will they live?
2. Michelin Pilot Sport Cup 2: Will these be close enough to the Trofeo R's on track that their longer life makes them the Holy Grail I'm looking for? Standard equipment on the SLS AMG Black Series, Porsche 918, and Ferrari 458 Speciale. Somebody needs to try these, and soon...
brt3 is offline   Reply With Quote
Old 06-04-2014, 02:30 PM   #2
Mikebrinda
Mikebrinda's Avatar
Drives: Ferrari F430 Spider F1 Azzurro Arge
Thank you for your work and time invested in this post.
Mikebrinda is offline   Reply With Quote
Old 06-04-2014, 03:01 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
x2. This is a very impressive explanation... For what it's worth, my dad has been raving about the Pilot Super Sports he just put on his Mercedes, especially when he puts it on a track. They are definitely good in all scenarios.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Caliper Conversion, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, VIS Terminator Hood, Overkill Tuned
DSX_Camaro is offline   Reply With Quote
Old 06-04-2014, 03:05 PM   #4
Mikebrinda
Mikebrinda's Avatar
Also for what it's worth, I'm a Costco fan and they sell Bridgestone and Michelin.
Old 06-04-2014, 05:14 PM   #5
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
yep got my bridgestone pole position set with nitrogen at costco great price and excellent care taken.
backtotintops is offline   Reply With Quote
Old 06-04-2014, 06:58 PM   #6
brt3
brt3's Avatar
The S-04s are fantastic on the street. I didn't like them on-track, but they made a HUGE difference in how the car felt on the street. Much more pleasurable to drive, with zero hunting and very low road noise...
Old 06-04-2014, 08:54 PM   #7
brt3
brt3's Avatar
Speaking of Bridgestone S-04s...
I noticed, when comparing the tires mentioned above, that when you select the group and then "compare all", the Trofeo Rs have what looks like a significant tread width advantage. This is described in their product literature as well.
To be honest, I never really thought much about that until today. A long time ago I ordered a set of Trofeo Rs to have on hand when the OEM set is worn out, and today they showed up. Our garage has started to look like Crazy Ray's House of Discount Tires, so I got to work stacking tires on moving dollies.
Lo and behold, here are some shots of the S-04s -- on the right, mounted to the OEM wheels and inflated -- next to the recently arrived stack of Trofeo Rs, on the left. Yes -- the garage floor is even and the dollies are exactly the same height.
Funny thing is, when I changed out the Bridgestone S-04s for the OEM Trofeo Rs, the first thing I noticed was that they seem to stick out of the wheel wells a touch more. I attributed that to my tired state over the weekend, but I guess it's true...
Old 06-04-2014, 09:03 PM   #8
Mikebrinda
Mikebrinda's Avatar
What the heck do all the numbers on the tire wall mean if the contact patch to the ground varies like that?
Old 06-04-2014, 09:08 PM   #9
DanSS24
DanSS24's Avatar
Drives: Dream Cars in my head
I would like to know too.
Wishful thinking...but I sure can dream big.
DanSS24 is offline   Reply With Quote
Old 06-04-2014, 09:23 PM   #10
brt3
brt3's Avatar
I do know from experience that Michelin Pilot Super Sports run notoriously wide. I agree -- dimensions should be exact and not "sweetened" in any way.
I'm not sure all of this is "cheating", at least in the case of the Trofeo Rs. They are very "square" and the sidewalls do not seem to bulge or round as much as the S-04s.
After going from memory I decided to go back to TireRack; here's a chart for comparison. Damn; guess Michelin is really stretching those Pilot Super Sports!
Old 06-04-2014, 09:44 PM   #11
Mikebrinda
Mikebrinda's Avatar
Thanks. I note overall diameter 26.3", but blank for Trofeo.
Old 06-04-2014, 09:50 PM   #12
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
....My $.02....all those sizes are only accurate if the tire is put on the correct width of rim for which they were made....Yes, there is a "range" of rim width the tires can be put on, but the over-all diameter, tread patch, side-wall height, etc., all is different from what is specified, if not put on the "optimal" width rim....
90503 is online now   Reply With Quote
Old 06-04-2014, 10:23 PM   #13
McRat
McRat's Avatar
Drives: 2010 ZR1 "Satan"
You'd have to look at them on the same rims.
DOH! I posted that over an hour ago.
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress
2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness.
2010 ZR1 "Satan" no times yet.
2013 Volt SCCA Solo2 #771 HS3.
And a bunch of Duramaxes.
McRat is offline   Reply With Quote
Old 06-05-2014, 11:25 AM   #14
McRat
McRat's Avatar
Here are identical 285/35-19 Michelin PS2's, one set mounted, one set unmounted.
