SDPC
Old 06-10-2014, 04:11 PM   #1
Blitzen2013
Blitzen2013's Avatar
Drives: 2013 Chevrolet Camaro 1SS 1LE
Exclamation High beams on Non-RS 1LE do not work
Hi guys n gals!
I haven't posed in a while, but recently a problem cropped up with my high beams. I own a 2013 1LE without the RS package or the Halo's, just regular headlights.
The problem I have is that the high beams do not turn on every time I use them. Sometimes they do, but 99% of the time they do not. When I try, all the lights go off, yet the info system tells me they're on with a blue light icon.
This is bothersome to me, especially when driving down country roads where there's no street lighting, which I have to do quite often. I'd like to see the road far ahead of me as to avoid hitting something.
Has anyone had this issue, and if so, can you tell me what I can do to fix that? Is it covered under warranty? I bought the car in December of 2012 as '13 model and have never had any issues until now.
I'd appreciate any help you can give.
B.
Blitzen2013 is offline   Reply With Quote
Old 06-10-2014, 04:14 PM   #2
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Take it in. It's covered under warranty.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 06-10-2014, 04:40 PM   #3
Blitzen2013
I was thinking about that, but not sure if a dealer is trustworthy. I haven't been to one here in Pittsburgh, my car was bought in Texas, then I drove it up here, so not sure who to trust with my car. It's so frustrating.
Old 06-10-2014, 05:55 PM   #4
VOGGS-LS3-1LE
Angry by Nature
VOGGS-LS3-1LE's Avatar
Drives: 13' Camaro 1SS/RS/1LE/NPP 1 of 76
Take it to North Star Buick GMC in zelienople pa, just north of cranberry....I am the ASM there and will take care of you.
2013 CHEVROLET CAMARO 1SS/RS/1LE/NPP
1 OF 76
Roto Fab CAI
1LE BADGES
VOGGS-LS3-1LE is offline   Reply With Quote
Old 06-10-2014, 06:00 PM   #5
markgws6
markgws6's Avatar
Drives: 2013 Camaro 1SS/1LE
I have a non-RS 2013 1LE and have never had a problem with my high beams (And I've switched bulbs several times.)
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
CAI intake, Apex cold air scoop and washer bottle, Hypertech 91 tune, ZR1 diff fluid, Motul RBF-600, Russell SS brake lines, SLP skip-shift override, SRP Pedals, Forza 3 way exhaust controller, octane fuse reset
markgws6 is offline   Reply With Quote
Old 06-10-2014, 06:49 PM   #6
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Moved to Camaro Issues / Problems
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 06-10-2014, 07:08 PM   #7
Green Machine
Always Workin
Green Machine's Avatar
Drives: 2014 1SS 1LE
Tom Henry Chevrolet on Rt 8 north of tne turnpike
Sent from somewhere on the road.
Green Machine is offline   Reply With Quote
Old 06-11-2014, 10:14 AM   #8
SubSonic
SubSonic's Avatar
Drives: 2014 SS/RS M6
It could be an intermittently bad bulb. (Although 2 may be a stretch... I've had bulbs that are bad but will still light when they just happen to be making contact with broken filament) Or a bad contact at the base of the bulb itself... have you checked the connections to the high beam bulbs and bulbs?
Unless these cars have a bulb out warning... in which case, just ignore me.
But having no lights at all when your are in a situation where you need to use high beams sounds disconcerting. I'd check it out or get it checked out soon.
SubSonic is offline   Reply With Quote
Old 06-11-2014, 10:32 AM   #9
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
In my experience, bulbs do often burn out at approximately the same time. So I would check those before going bananas.
Rock-It Man is offline   Reply With Quote
Old 06-11-2014, 10:35 AM   #10
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Just an idea, it might be a multi function switch!
Old 06-11-2014, 11:01 AM   #11
Blitzen2013
No, I haven't checked the connections yet, gonna do that and see what gives. Thanks for the advice, to all of you.
Old 08-06-2014, 05:32 PM   #12
1LE Red Dragon
Train Driver
Drives: 2016 Camaro 2SS A8
I have the same problem. What was wrong with yours?
1LE Red Dragon is offline   Reply With Quote
1le, headlights, high beams
