ADM PERFORMANCE
Old 06-11-2014, 09:39 PM   #1
RKCamaro13
RKCamaro13's Avatar
Drives: 2011 Red 2SSRS A6
Is this Right?
I ordered BC coilovers last week, and I am working on the fronts right now. I just pulled both of them off and I think I have the coilovers setup right. I just want to make sure first before I go back with them. Also does anyone know what depth will make what ride height? Like Pedders said 24mm from the piston to the bottom of the clevis would be 660mm of ride height. Here are some pics I took, right now I have a 7/8" depth from the bottom of the clevis, very arbitrary.
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Struct Tower Brace, Foot well Lighting, CNC ported throttle body, Roto-Fab CAI, SW long tube headers, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Magnuson Supercharger (soon to be).
RKCamaro13 is offline   Reply With Quote
Old 06-12-2014, 12:01 PM   #2
RKCamaro13
RKCamaro13's Avatar
No one?
Old 06-14-2014, 03:11 PM   #3
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
I think you're just going to have to put them back in, tighten everything up and drive slowly around the block and re-measure your ride height, and make additional adjustments. Once you get your target ride height then do a realignment. Also time your bushings immediately after your first ride around the block. There's a certain ratio of changes in the front and rear spring adjustments that translates to ride height change, but I don't recall what that is. Like if you move the fronts 1/2" it makes 1/4" difference in height--something like that.
Meh
My 5th is offline   Reply With Quote
Old 06-14-2014, 03:23 PM   #4
amanc96
amanc96's Avatar
Drives: 2011 SIM 2SS/RS
I think your suppose to remove the foam spring insulator. I have the pedders coilovers and they said to remove it. Also check this thread out.
http://www.camaro5.com/forums/showth...ilover+install
For the megan coilovers, the foam spring insulator was removed as well.
amanc96 is offline   Reply With Quote
Old 06-14-2014, 07:16 PM   #5
RKCamaro13
RKCamaro13's Avatar
I got it all worked out now, thanks.
