sjm autoprod
Old 04-17-2010, 10:43 PM   #15
meltyface
meltyface's Avatar
Drives: 2010 1SS CGM LS3 w/ blk rally
Looking at it, you could probably use the existing H-pipe for the headers, I'm not 100% sure if it would mesh up with the exhaust, but I think it might. You actually have to use the stock clamps to mesh the cats to the aftermarket x-pipe. And if you decided to use the stock H-pipe it might require some cutting (I didn't measure any of the stock components, sorry).
One thing to look out for with kooks though is DOUBLE CHECK what they send you BEFORE install. I found out 2 hours into my install that Kooks never sent me nuts for my cat bolts. Luckily the garage I was working in had a few extras.
Installed mods:
Kooks 1 7/8" headers w/ high flow cats, Borla x-pipe, Borla Stinger exhaust, Cold Air Inductions CAI, markers, tail and reverse lights plus parking light blackouts, body colored bowties, body colored SS emblems, Passport 9500 radar detector (a must have), Kenwood DNX9960 radio w/ metra kit. Matte Black Giovanna Dalar 5V: 20x8.5 & 20x10 wheels
Mods in the future:
Relocating guts of "shark fin" and removing it, cam, super charge/turbo?...unsure what after that...
Gotta have MORE power!!
meltyface is offline   Reply With Quote
Old 04-18-2010, 01:16 AM   #16
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
THXXX
AlSuwaidi is offline   Reply With Quote
Old 04-22-2010, 06:35 PM   #17
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Installing Kooks long tubes with Noweeds diverters this weekend!!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 04-22-2010, 06:36 PM   #18
jsharp
jsharp's Avatar
then off to livernois for a tvs wont that be loud!!!
Old 08-20-2010, 08:33 PM   #19
carfansince73
carfansince73's Avatar
Drives: Carefully
I was hoping to install my 1 7/8" Kooks at home in the garage, but I don't think my jack or jack stands will get the car high enough. :( I might have to let my local LSx shop do this. I will need a tune anyway.
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! I wonder if the state would allow this vanity plate---> KISSMYSS
2014 CTS-V Sedan, Black/Black, Auto, Recaros, Ultra-view, Red Brembos. Stock
carfansince73 is offline   Reply With Quote
Old 09-10-2010, 09:55 AM   #20
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
Installing Kooks today!
BlaSSt Off is offline   Reply With Quote
Old 09-22-2010, 01:52 PM   #21
carfansince73
Drives: Carefully
How did the install go?
unbolting the steering shaft, what's involved in this and did you use any locktite when hooking it back up?
Old 09-22-2010, 04:42 PM   #22
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
You take the pinch bolt out. Then push the shaft up and off to the side. Getting mine back on was a pain. It wouldn't go back over the shaft. I finally figured out to screw a small sheet metal screw into the crack. This opened it up enough to get it back over the shaft.
If yours won't go back on because the crack closed up. Try the small screw trick, it will spread it back open.
I used blue loctite.
Old 09-23-2010, 08:07 PM   #23
carfansince73
Drives: Carefully
Thanks.
Is there any way I can mess up hooking that part back up? That's a pretty important thing...
Old 01-31-2011, 01:42 AM   #24
Sturmer
Drives: Chevrolet Camaro 1LT 2010 V6 A6
So the OEM exhaust has 4 converters (2+2).
So is 2 high-flow converters enough (1+1) or do I need to add 2 more to get same result?
Sturmer is offline   Reply With Quote
Old 04-19-2011, 06:40 PM   #25
thasleeper
thasleeper's Avatar
Drives: 2010 Camaro 2 SS/RS\ CYBER GREY
thasleeper is offline   Reply With Quote
Old 07-30-2011, 09:42 PM   #26
Augie1978
Augie1978's Avatar
Drives: 2011 2SS RS Vert
Can you screw up hooking the steering wheel column back up? I think I got it put back together OK but it is concerning.
2SS RS, Triple Black Vert, Manual, Hurst Shifter. American Racing Headers, Roto-Fab CAI
Augie1978 is offline   Reply With Quote
Old 08-31-2011, 09:56 PM   #27
n5jws
n5jws's Avatar
Drives: 2011 VR SS/RS M6
I am doing this install, just the short system though. No problem disconnecting the steering shaft, once I got it off it was obvious that it only goes on one way. I know I was concerned about this part of the install too, however there really is nothing to worry about guys. Remove the bolt and compress the shaft toward the firewall and out of the way. Then remove the OEM exhaust manifold and install the header, I had no problem sliding the u-joint back over the lower steering shaft.
Thanks Nine Ball for the DIY thread, can't wait to fire this thing up. Good luck all with your installs.
Chris
2011 2SS/RS VR MN6
Heritage grille
CAI
ARH Headers
High Flow Cats
JRE Tune
n5jws is offline   Reply With Quote
Old 01-09-2012, 08:53 PM   #28
evilbeef54
tail lights for u
evilbeef54's Avatar
Drives: Bumble Bee 2010 2SS/RS
bump for an old great thread, my new LT's should be here thursday, cant wait, this will definitely help
1972 Camaro 350/Muncie M22 - SOLD
1986 Camaro RS - R.I.P.
1994 Camaro Z28 - SOLD
2010 Camaro 2SS/RS RY M6- LOVIN' it
Kooks LT's & HFC's, Flowmaster Single chamber mufflers, C.A.I. Intake, ADM Scoop, Rotofab w/w relocate
Semper Paratus
You have to go out You don't have to come back!!!
evilbeef54 is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
Vortech Supercharger Systems for 2010 Camaro Official Release Brian@Vortech Forced Induction - V8 98 02-20-2010 12:04 AM
