HeadlightArmor
Old 08-08-2009, 11:26 AM   #1
jackka
jackka's Avatar
Drives: 2011 Black/Black 2LT/RS M6 w/Sroof
Location: FT. Rucker, Alabama, the home of Army Aviation!
FOR BEST FUEL ECONOMY?
Amsoil, Mobil 1, Royal Purple, etc etc
Obviously all these oils are good enough, at least for me.
And according to the manual, 5-30w is best while 0-30w is also acceptable in cold areas.
So my question is, does either the brand or the viscosity/weight actually have meaningful differences in mpg?
Although I'm no expert, I would think on common sense that 0-30w would give me better mileage, at least technically.
So why does the manual recommend 5-30w?
What combination of brand and grade should I use from a cost effective point of view? All I want is a decent oil that is not overpriced and will give me the best mpg.
jackka is offline   Reply With Quote
Old 08-11-2009, 05:15 AM   #2
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
it doesn't really matter between those three you won't see a difference in mpg's but maybe in other areas
and you should only uses lower weight oil if you live somewhere that has extreme winters and only during that time. the wider the range the less actual oil is in the quart so less protection and cooling effects
Gentry78 is offline   Reply With Quote
Old 08-11-2009, 07:00 AM   #3
FI4T0MCAT
FI4T0MCAT's Avatar
Drives: 1969 SS Camaro
http://www.camaro5.com/forums/showthread.php?t=36773
FI4T0MCAT is offline   Reply With Quote
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Fuel Economy and Crash Safety Can Conflict Scotsman General Automotive + Other Cars Discussion 2 04-20-2008 09:23 PM
Americans unwilling to pay for big fuel economy gains, carmakers say Scotsman General Automotive + Other Cars Discussion 7 04-18-2008 01:27 PM
Bob Lutz, and Scott Settlemire on fuel economy. Mr. Wyndham Off-topic Discussions 19 11-18-2007 03:01 PM
