AAC Style
View Poll Results: Do you plan to get this recall if you had a choice?
Yes 245 15.34%
No 1,352 84.66%
Voters: 1597. You may not vote on this poll
Old 06-13-2014, 08:14 AM   #1
toti
Drives: 2SS
Post New Camaro Recall - Ignition Switch System / Key Fob
Update: June 19, 2014
GM Press Release:
DETROIT –
General Motors will recall all current generation Chevrolet Camaros because a driver’s knee can bump the key FOB and cause the key to inadvertently move out of the “run” position, with a corresponding reduction or loss of power.
The issue, which may primarily affect drivers sitting close to the steering column, was discovered by GM during internal testing following the ignition switch recall earlier this year.
“Discovering and acting on this issue quickly is an example of the new norm for product safety at GM,” said Jeff Boyer, vice president of GM Global Safety.
The Camaro ignition system meets all GM engineering specifications and is unrelated to the ignition system used in Chevrolet Cobalts and other small cars included in the ignition switch recall.
GM is aware of three crashes that resulted in four minor injuries that it believes may be attributed to this condition.
The company will change the Camaro key to a standard design from one in which the key is concealed in the FOB and is opened by pushing a button. The change will make the ignition key and FOB independent of each other, so that inadvertent contact with the FOB won’t move the key from the “run” position. There are 464,712 Camaros from the 2010-2014 model years in the U.S. included in the recall. Including Canada, Mexico and exports, the total recall population is 511,528.
Separately, GM also announced two safety recalls and one non-compliance recall involving a total of 65,121 cars in the U.S. all three of which were reported to the NHTSA on Wednesday, June 11, 2014. Including Canada, Mexico and exports, the total recall population is 69,839.
In all cases, customers will receive letters from GM letting them know when they can bring their vehicles into a dealership, where the recall repairs will be performed free of charge and courtesy transportation would be provided as needed.
The recalls:
28,789 Saab 9-3 convertibles from the 2004-2011 model years for an automatic tensioning system cable in the driver’s side front seat belt retractor that could break. If the cable were to break, seat belt webbing spooled out by the driver would not retract. The convertibles and sedans were investigated at the same time, but the convertible parts were not identical to the sedan parts. GM has since learned of customer complaints to the NHTSA for the convertibles. Dealers will replace the driver’s side retractor in the recalled vehicles. In addition, GM has issued a special coverage, so that if the same repair is required to the passenger side retractor it will be covered for the life of the vehicle. GM also extended the special coverage for passenger side belt retractors on the 2004 Saab 9-3 sedan from the original 10-year coverage to the life of the vehicle, like the convertibles. GM is unaware of any crashes, injuries or fatalities due to this condition.
21,567 Chevrolet Sonic 2012 model year compacts equipped with a six-speed automatic transmission and a 1.8-liter four-cylinder engine for a condition in which the transmission turbine shaft may fracture as a result of a supplier quality issue. If this were to occur in first or second gear, the vehicle could not upshift into third through sixth gears. If the turbine shift fractured while in one of the higher gears, the vehicle would coast until it was moving slow enough to downshift into first or second gear. In both instances, a malfunction indicator lamp may illuminate. If driven in this condition for a long period of time, all forward gears may become inoperable. The engine would continue to run and all power accessories would function. Dealers will replace the transmission turbine shaft. GM is unaware of any crashes, injuries or fatalities related to this condition.
14,765 model year 2014 Buick LaCrosse sedans because a wiring splice in the driver’s door may corrode and break. That may communicate incorrect information to circuits that control the door chime and allow passenger windows, rear windows and the sunroof to function when the vehicle is turned off and the driver is not in the vehicle. In addition, a chime will not sound when the driver’s door is opened if the key is in the ignition.
Dealers will inspect the driver door window motor harness and, if necessary, replace an electrical splice. GM is unaware of any thefts, crashes, injuries or fatalities related to this condition.
Bulletin sent to dealers:
Date: June 12, 2014
Subject: Stop Delivery Order
GM Reference Number 14294
Models: 2010-2014 Chevrolet Camaro
To: All Chevrolet Dealers
Attention: Dealer, Dealer Principal, General Manager, General Sales, Manager, New Vehicle Sales Manager, Used Vehicle Sales, Manager, Parts and Service Director and Service Manager
STOP DELIVERY ORDER
Effective immediately, stop the delivery of all 2010-2014 model year Chevrolet Camaro vehicles currently in transit to dealers as well as those already in new and used vehicle inventory for an ignition key issue. According to GM records, the total number of involved U.S. vehicles currently in new vehicle inventory is 34,233.
All 2010-2014 model year Chevrolet Camaro vehicles that are in dealer inventory (new and used) must be held and not delivered to customers, dealer traded, or used for demonstration purposes until further instructions are received.
Instructions for releasing the involved vehicles from this stop delivery will be provided in the near future.
Please do not call GM Technical Assistance.
END OF MESSAGE
GM CUSTOMER CARE AND AFTERSALES
toti is offline   Reply With Quote
Old 06-13-2014, 08:17 AM   #2
BigRed585Lbs
Drives: Sierra and Tahoe
New Recall - Camaro Ignition Switches!!!!!!
Here we go again.
http://media.gm.com/media/us/en/gm/n...11-recall.html
BigRed585Lbs is offline   Reply With Quote
Old 06-13-2014, 08:19 AM   #3
Pi kappa alpha
Pi kappa alpha's Avatar
Drives: SS Vert
Nevermind
I want to go to college for the rest of my life.
Pi kappa alpha is offline   Reply With Quote
Old 06-13-2014, 08:20 AM   #4
ChevyGirl661
ChevyGirl661's Avatar
Drives: 2011 Camaro LS
So they are going to change the key? I like my key... :(
So they are saying all 2010-2014? CRAZY.
ChevyGirl661 is offline   Reply With Quote
Old 06-13-2014, 08:21 AM   #5
eblanchette
eblanchette's Avatar
Drives: 1LE
the salesman just called me to say that. I was supposed to take delivery today. wtf GM
Sent from my Nexus 7 using Tapatalk
eblanchette is offline   Reply With Quote
Old 06-13-2014, 08:22 AM   #6
BigRed585Lbs
Well, they've got a *hit load of keyed ignition switches they need to get rid of, and........
Old 06-13-2014, 08:25 AM   #7
gpskinzhut
gpskinzhut's Avatar
Drives: 87 IROC-Z, 2017 2SS, 2014 2LT vert
This is very minor.
2017 2SS M6: Stock
2014 2LT Convertible: Stock
1987 IROC-Z: 305 TPI, World Class T5 5-speed, G92 perf option, T-tops, weekend toy
gpskinzhut is offline   Reply With Quote
Old 06-13-2014, 08:29 AM   #8
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
Reading comprehension is key (no pun intended). There is supposedly nothing wrong with the ignition and the recall does not call for any ignition changes. The recall is to replace our nice key fobs with the rectractable key to an old fashioned key with a separate FOB.
Personally I don't drive with my knees in the column and I have no desire to get a separate ugly FOB.
JR 1 is offline   Reply With Quote
Old 06-13-2014, 08:29 AM   #9
007s 'Vert
Formerly Lil'BlueCoupe
007s 'Vert's Avatar
Drives: '13 2LT/RS Vert, Summit White
Well that sux....I happen to like my switchblade style FOB a lot......it would be nice if they just send us the new keys and then we can have the option of using either style.....
007s 'Vert is offline   Reply With Quote
Old 06-13-2014, 08:31 AM   #10
BigRed585Lbs
Like I said, they've got a lot of "old fashioned key" switches they can use for replacement parts.
Old 06-13-2014, 08:34 AM   #11
luis550
Drives: 2013 2lt
i like my key too
luis550 is offline   Reply With Quote
Old 06-13-2014, 08:34 AM   #12
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
awww...I like my key. I would replace the switch and plastic around it due to the maniacal 1st owner who must have been Jack the Ripper's sister. There are more stab marks on the plastic surround than on a piece of rice in N. Korea.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 06-13-2014, 08:39 AM   #13
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
Hm.. Okay
DaFisch is offline   Reply With Quote
Old 06-13-2014, 08:39 AM   #14
EastWood-SS
Born To Run
EastWood-SS's Avatar
Drives: 2013 BRM SS/RS LS3
Well, this sucks.
Just Lettin' the Night Roll...
2013 Blue Ray Metallic 1SS/RS
Dual Mode Exhaust + Fuse Pull / CAI inc. CAI/ 1LE Strut Tower Brace/ ACS T4 Splitter/ SunRoof/ BA Audio/ Performance Shifter/ White Rally Stripes
EastWood-SS is offline   Reply With Quote
2014, camaro, new camaro, question, recall
