BeckyD @ James Martin Chevy
Old 08-08-2009, 01:56 PM   #1
Travo
Travo's Avatar
Drives: 2010 CGM 2LT/RS
Labor Cost for Custom Box?
Im trying to get a custom box made for the trunk. I took it to the custom car audio place in town and they quoted me 600 dollars for the box and labor, as long as I bought the amp and subwoofer from them. I got a cheaper deal on an amp and sub at crutchfield.com, and the new quote from the car audio place is $1200 for just the box and labor. This does not seem right at all to me, does anyone have any insight on how much this should normally cost and if it seems as if they are trying to rip me off.
Travo is offline   Reply With Quote
Old 08-08-2009, 02:41 PM   #2
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
Make it yourself out of MDF board. Just get some cardboard and make a template first.
2010 Camaro 1LT/RS
Mods: Staggered 20" Lexani LX15 Wheels, Airraid CAI, AAC Blue LED Dome/Trunk Lights, AAC LED License Plate Lights, AAC LED P13W Running Lights w/Harness, Metra Radio Kit, Kenwood DNX9960 DDIN Radio, JL Audio 10" W6 Sub, JL Audio 500/1 Amp, ******** Sub Box and Amp Rack, AeroExhaust Resonators
BigBOSS is offline   Reply With Quote
Old 08-08-2009, 03:47 PM   #3
Travo
Travo's Avatar
Id rather have it professionally made, I would just like to know what standard labor costs are usually for this type of job.
Old 08-08-2009, 04:29 PM   #4
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
I asked a shop here in town and was told it would be about $400.
Scourage is offline   Reply With Quote
Old 08-08-2009, 04:51 PM   #5
BigBOSS
BigBOSS's Avatar
http://www.camaro5.com/forums/showthread.php?t=31768
I believe the shop charged him $200 for the box, atleast that is what the same shop quoted me for the job after I called inquiring about his that they made.
2010 Camaro 1LT/RS
Old 08-09-2009, 12:25 AM   #6
Tecca
Tecca's Avatar
Drives: ...
$1200 that better include the box, speakers, woofer, install and a back massage.
Tecca is offline   Reply With Quote
Old 08-09-2009, 12:35 AM   #7
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Can I trade the back massage for acupuncture?
In all seriousness, a good box will cost more, and that price heavily depends on the content of the box. Before anyone begins discussing this massive topic, you should probably give us an idea of what you want to accomplish with your sound system. Do you want a competition winner or a little more bump than the stock system? Do you want a fully modified trunk or a concealed compartment?
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 08-09-2009, 03:17 AM   #8
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
My speaker box, materials, labor and all, ran me $250. I had my own amp and speaker. They added in the amp kit, and labor to wire it all up and we wound up spending $498 total.
Old 08-12-2009, 01:52 AM   #9
Travo
Travo's Avatar
Definitely not trying to win a competition...I wanted more of a concealed compartment with kick, sort of like tags in the link above.
It sounded messed up when they decided to charge me double for labor, about 30 minutes later they called back and said they would match the price of crutchfield and keep the labor cost to 600. All together with a RF 500w amp and RF 12" P3 its running me around $1350 (saving me $360 thanks to crutchfield.com). I guess this is what Ill have to do since I dont really know of any other places close by that will make something like I want. I just hate looking like an easy target to these type of people ya know.
Old 08-13-2009, 02:20 PM   #10
Audio Integrations
Drives: Anything and Everything
Any more details on the enclosure they quoted ya for? MDF entirely or fiberglass? Finished material - carpet/vinyl/paint?
Most shops that are capable of doing decent custom work generally charge in the $60 an hour area, standard labor (decks/speakers/amps) are quoted from a $45 an hour rate but it all really comes down to the installer...not all are created equal unfortunately. It also depends on your area - I'm not real familiar with that but some of the work we do up here (WA) would be a lot more in other places if the same quality was held.
Any decent installer should be able to handle your standard mdf enclosure, but when you get into the more custom setups and nicer finishes there's a huge difference between shops and more importantly installers.
My advise would be to ask to see some pics of what "your" installer has done in the past - if he doesn't have any there's a pretty good chance everything he's done isn't worth taking pictures of. Unfortunatley a lot of installers like to say they can build anything and everything just drop the car and cash off but I'm sure you've heard many horror stories where things went wrong or just turned out terrible.
So to give you an example - here's your kinda standard mdf enclosure - built to subwoofer's specs, .75 inch mdf construction, carpet finish (although it has a vinyl inset which is a bit "extra") Something like this usually goes for $150 - $200 plus some materials, most installers should be able to do this in 2 - 3 hrs.
Here's a more custom enclosure - built to subs specs, molded fiberglass contoured to the trunks factory panels, lightweight and strong due to the curves, carpet finish with vinyl flush trim ring. Something like this usually goes from $600 - $800 depending on thickness and overall fit and finish. If done correctly this usually takes 8+ hours. There's a lot of "drying/curing" time that isn't accounted for in the 8 hrs. Usually you can't do this in an entire day without cutting some corners although it is possible if you really know what your doing and are efficient.
I understand everybody's point of view on the buying gear online because it's cheaper and it is hard to pay more for something when you know you could of paid less for it but at the same time look at it from the shops point of view as well - and for an example let's just take audio out of it because I have no idea why this industry (mainly alone) has taken the main beating in this area.
So your Jiffy Lube or local one stop oil change shop in your town - can you buy your oil, filter and gaskets online then bring them into their shop and just have them do the labor? I haven't seen it but don't ya think if you could you most likely would have to pay a little extra for it?
The bottom line is most any business plans on making profit on the items they sell....be it a little margin or a lot. It is not cheap to have a retail location, employees, store displays, product and everything else it takes to run a business. If a shop is to just do the labor they will have to charge more than the shops selling gear and doing labor, that's the only way they'll be able to keep their doors open.
One other thing to consider - most shops stand behind their gear and labor 100% - meaning if you purchase and amplifer and subwoofer from them and then have it installed if you run into any issues (product failure or other) down the road they're going to look into it for free and figure out what happened - if it's install related they will take care of it because it's on their end, if product failure there's only so much they can do but will look to get it repaired or replaced. This is part of the service you "paid" for when you purchased the gear from them.
Now lets say you bought all the gear online and just had them do the install. They are going to charge you to diagnose the problem at an hourly rate and then of course to fix it. If it's install related then they should take care of it free of charge but if it has anything to do with the gear you brought in from somewhere else well it's really not their issue and it should be a paying service to figure it out...that's just to be expected and is justified to me.
It's already been happening and probably will continue in many different industries but if shops can't make money selling some gear along with the install they won't be able to stay open, that same shop you plan on going to to get your newly purchased gear from online just may not be there when your ready for the install. Eventually your only option may be to purchase gear online and then install it yourself as nobody will be around to do it.
Sorry for the long post - just wanted to give ya something to think about - I gave up selling gear in my shop because of the internet, ya can't compete so it's just not worth it.
- Todd
Audio Integrations is offline   Reply With Quote
Old 08-31-2009, 02:05 AM   #11
Travo
Travo's Avatar
Sorry its been awhile but here was the finish results from the custom box I had made...the last pic is where they installed the amp (behind the trunk molding)
Old 08-31-2009, 02:36 AM   #12
TAG UR IT
TAG UR IT's Avatar
Very cool, man. Looks VERY clean.
I'd have liked to have my amp hidden as well. Oh well. I supposed I can always have it fixed.
Old 08-31-2009, 04:52 PM   #13
Audio Integrations
Yeah, looks good!
If ya don't mind what did this run ya and what is it's construction - fiberglass, mdf, or a combo of both?
Old 09-01-2009, 09:35 AM   #14
TeamTCA
TeamTCA's Avatar
Drives: 2010 Camaro 1SS/RS #21068
Great post Audio Integrations! I too own a car audio shop, TC Audio, in Benton, Arkansas. I have been in business for 20 years this month. And I don't know how many people don't understand what u just explained. I am no different than any ordinary customer by wanting to obviously get the best price on what I want BUT quality does cost. We do retail but mainly have to relay on all types of custom work to stay in business. The internet is a killer when it comes to electronics. I have built my business on reputation, quality install, and customer service being the most important. We have a decent following nationwide. I ship to all over the country. And yes, you are going to pay a little more at a specialty store than online. But you get a warranty and more importantly, someone who stands behind what they sell.
As far as the custom box goes, you couldn't have covered the options any better. My main variables to ask a customer are: 1. What do you want it to look like (finish, etc), 2. How loud or how much "extra sound" are you looking for, and 3. How much do you have to spend? The last upsets a few people but you have to be blunt. It's not rude. But I don't have time to spend 2 days on a custom box for $250. If that's all you have to spend, then great we can build you something in your price range that will work and be nice for that but it's not gonna be a $1k custom fiberglass/painted subbox. So many people just don't get it so shop around and investigate your options.
Our old website is currently being updated but not finished by any means. Check it out at www.tcaudio.net. I have a SIM 1SS/RS that I will be competing with prob next year. I will post pics up as available. Right now, we are building two new cars for USACi World Finals this year (OCT 3,4 in Tulsa, OK). I will be there.
Check at Metro Audio Dynamics in Omaha or Stereo West. I know guys that work at both. They should be able to help you out. If not, give us a call...
Sorry for the long post. It's just nice to see someone else out there who deals with what I do...
Kenwood Excelon, Rockford Fosgate, JBL, Hertz, Audison, Illusion Audio,
Mosconi, Diamond Audio, Hybrid Audio, WetSounds, & more
TeamTCA is offline   Reply With Quote
fuse box gtjacket 5th Gen Camaro SS LS LT General Discussions 14 02-25-2011 11:26 AM
CAI vs Air Box rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 06-25-2009 03:32 PM
No "Show Signature" Box in Miscellaneous... RPO_Z28 Site Related Announcements / Suggestions / Feedback / Questions 10 06-20-2009 01:08 AM
