Emblempros
Old 06-14-2014, 10:28 AM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
FE1.....FE6?
Ok, so maybe this is a noob questions but what if the difference between all these FE suspension call outs?
FE2
FE3
FE4
FE6 (1LE?)
I have a 2013 2LT RS...so which do I have?
Thx
Mods:
Old 06-14-2014, 01:46 PM   #2
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
The V6 has FE2. As for the difference I know the major difference between FE2 and FE3 are the sway bars, Springs and struts. FE4 introduced the new outboard mounted rear sway bar and the FE6 has FE4 components with different Springs, Struts, and a few other parts.
I am sure someone else will chime in with things that I might have forgotten or got wrong.
Proud owner of litho #179 Click Picture for Build Thread
Old 06-14-2014, 08:46 PM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
By the lack of responses maybe I'm no the only one confused. lol
Mods:
Old 06-14-2014, 10:43 PM   #4
OK2DRUL
ace5.org (Atlanta Club)
OK2DRUL's Avatar
Drives: 2010 Black/IOM 2SS LS3
FE2=V6
FE3=2010-early 2012 SS
FE4=mid 2012 to current SS
FE5=ZL1
FE6=1LE
All FE 4/5/6 lower control arms are the same with outward mounting locations and the difference is the size of the front and rear sway bars, shocks/struts, and the ZL1 having mag ride.
OK2DRUL is offline   Reply With Quote
Old 06-14-2014, 11:58 PM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Originally Posted by OK2DRUL View Post
FE2=V6
FE5=ZL1
FE6=1LE
Ah, thank you.
That clears it up!
Mods:
Old 06-15-2014, 07:07 AM   #6
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
FE6 also has stiffer cradle bushings that really help.
Scott@Bjorn3D is offline   Reply With Quote
Old 06-16-2014, 05:50 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
FE2=V6
FE3=2010-2011 & 10-14 convertible
FE4=2012 to current SS
FE5=ZL1
FE6=1LE
Fixed that a little bit for ya.
Best regards,
Tyler
888-308-6007
Old 04-29-2016, 04:42 PM   #8
JWoj3540
JWoj3540's Avatar
Drives: 2012 2SS/RS M6
great info. here, thanks!
JWoj3540 is offline   Reply With Quote
Old 04-29-2016, 08:20 PM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
JDP,
Isn't the rear shock mounts for the 1LE stiffer to compliment the mono-tube shocks???
Orange Krush II
1LE Front with DSE Links and 32mm JPSS Rear Bar, Splitter, 3.91 Gears with 1LE Axles, 14/15 Heat extractor in a 13 1LE hood, 1LE shocks and struts,1LE Suede Flat bottom Steering wheel restitched in orange, Factory Hurst short throw shifter with the Pegasus rear poly shifter mount, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, Skip Shift eliminator, 1LE diffuser with dual mode mufflers, Z/28 headers and Cats, 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers and CTS-V Rotors, PAFDT Solid Cradle bushing, Z/28 Toe Rods and UCA Bushings.
Old 05-01-2016, 12:04 PM   #10
RichCamaro10
RichCamaro10's Avatar
Drives: 2010 Camaro 2SS
Originally Posted by olblue75 View Post
JDP,
Yes, the FE6 has stiffer mounts in the back the P/Ns are (22922445, 22922446)
Also, I can find part numbers for the FE6 rear shocks but not the front? The only FE6 part numbers that I can find for the front is the strut/spring/mount combos (22812984, 22812985). Are the FE4 and FE6 front struts the same?
2010 Black Camaro 2SS
RichCamaro10 is offline   Reply With Quote
Old 05-01-2016, 12:12 PM   #11
68rssscamaro
Camaro: A Legend Reborn!!
68rssscamaro's Avatar
Drives: SOLD: 12 2SS/RS LS3 45th
Not to change it around, but this is a good topic. Do all the verts have FE3? Or did they make a change after 2012?
[SIGPIC][/SIGPIC]
68rssscamaro is offline   Reply With Quote
Old 05-01-2016, 12:18 PM   #12
RichCamaro10
The easiest way to see if you have an FE3 or FE4 is to look at your rear sway bar. If your end links mount to the lower control arms at a point that is inboard of the rear shocks/springs, you have FE3. If they are outboard of the shocks/springs, you have FE4.
Old 05-13-2016, 08:30 AM   #13
RSMike
RSMike's Avatar
Drives: 2015 2LT RS A6
So the FE2 is for all V6's no matter the year?? I have a 2015 2LT RS
RSMike is offline   Reply With Quote
Old 05-13-2016, 08:41 AM   #14
RichCamaro10
I have confirmed that 22812984 and 22812985 are the P/Ns for the front struts and not the combos......
