Old 08-08-2009, 04:23 PM   #1
SSCamaro2010
SSCamaro2010's Avatar
Drives: 2010 Camaro 1ss/rs
catalytic converter
i know the stock ls3 comes with 4 of these. what do we do when we put an aftermarket exhaust on with only 2, what do we do with the other two sensors??
SSCamaro2010 is offline   Reply With Quote
Old 08-08-2009, 06:11 PM   #2
TeddyP25
TeddyP25's Avatar
Drives: 2SS
I went with ARH, one sensor attaches at the lower portion of the headers and the other attaches on the tube portion with the cats, so 2 per side.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 08-08-2009, 06:27 PM   #3
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
I heard the sensors were hard to remove, should I say anything to the place that installs mine or if all they do is this kinda work would they be familiar with it. I am going to a local guy who is highly reccomended and don't want to insult him by mentioning something that would be to him like tieing his shoes.
jpsuperman81 is offline   Reply With Quote
Old 08-08-2009, 08:12 PM   #4
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Not hard at all, they will know what to do. I'm no mechanic by any means or even a backyard one, thes took me and my friend on his dads lift just over 3 hours to install.
Old 08-08-2009, 08:17 PM   #5
jpsuperman81
Yep I'm back!
Thanks man.
Old 08-08-2009, 10:08 PM   #6
SPAWN
SPAWN's Avatar
Drives: 2009 GT500
The top sensors on each side are the actual O2 sensor.
The lower 2 measure the condition of the Cats.
Even with the holes there you should have a tuner turn the bottom sensors off. Most times the engine will detect the fact that flow and AFR is different than with cats so the computer will think the cats are bad. it will then throw a code.
Once those sensors are turned off you can use that hole in the off-road pipe for a wide-band AFR gauge. With a wide-band you can almost tune yourself. At Least you will always know that you are running a safe tune if the afr looks good.
Pony Wars Founder RichV@Showandgofast
NMRA True Street Bradenton 12.0 3rd place March 5th 2011, NMRA Bradenton True Street 12.0 Winner! March 6th 2010, NMCA Bradenton True Street 12.0 Winner! March 20th 2010, NHRA Unleashed 12.0 Qualifier November 5-6 2010,
SPAWN is offline   Reply With Quote
Old 08-08-2009, 10:11 PM   #7
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
You use all 4 sensors. On both sides, one of the sensors attach before the cats and the other attaches after the cats. It's this way on the oem exhaust as well. If you are doing it yourself, you don't need to worry about getting them mixed up as the sensors are designed to only fit one way.
6l80 torque converter stall ToddSS V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 42 12-08-2017 01:51 PM
my oh my.. L99 burnout with yank torque converter installed DanD V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 75 06-12-2010 06:42 PM
Fuel Management or Torque Converter issue? bamacarfool Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-15-2009 01:54 PM
V6 to V8 Torque Converter Compatability Backyard Mechanic 3rd Generation Camaros 1 07-01-2009 03:46 PM
