sjm autoprod
Old 06-15-2014, 06:31 PM   #1
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Issues with a particular Twin Fuel Pump Systems' "Rated" rwhp
Ok, I'm not going to release the name of the Company right now. I'm going to call them Monday morning and speak with the tech department to get answers, but here we go :
PCM of NC just finished tuning my car, here is the basics of the setup :
PRC 255 heads
1 7/8'' LTs
2.5'' exhaust no cats
ID850s
"800rwhp capable" Twin ZL1 pump system from " "
Procharger D1SC @ 9psi 669 rwhp/ 546 rwtq
Kelly and Alvin at PCM informed me that when Alvin was tuning my car, he was seeing fuel pressure drop in the mid/low 40's when he was dialing in the tune, and had to dial the tune back to those final numbers I posted above. Needless to say, on the companies website, they adveriste their twin pump system good for 800 rwhp...I say again, 800rwhp. Other sites, I have seen that they rate it for 700rwhp. It was also confirmed on the phone by one of their techs, that they stood by their 700-800rwhp ratings.
My tune was dialed back due to pressure drop, and obviously I made it no where close to 700. I'm not upset about the numbers, it's not always about dyno numbers, but if I paid 900$ for a fuel system that didn't meet the capabilities that the said company advertises, am I just supposed to take it for what it's worth?
At this point I'm trying to figure out which direction/route to go. I know 1,000,000 people will post and tell me "Squash", already know that. But can I actually run a BAP setup with these pumps to increase the pump voltage and get a little more out of my setup.
Also, in the colder months of Fall/Winter, I will have issues with my fuel setup, because the car will make more power with colder/denser air. So I'm definitely trying to figure things out now while it's still summer time.
Does anyone have any advice? Alvin saved the datalogs from one of the pulls where my fuel pressure was dropping into the 40s, and I plan to make sure the said Company sees that log so it's not "their word vs. mine". I'm hoping for some sort of compensation, and if I feel like I'm just going to get a "sh*t happens" type of reply, then I will post in the vendor section, and make sure this company is known.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 06-15-2014, 07:13 PM   #2
Slowhawk
Drives: 1999 Trans Am
I've seen a pressure drop numerous times with twin pumps while still ussing the single feed line system.
Anything 700rwhp or more gets a return line added. Had good luck making 800rwhp with this setup with no pressure drop on 2 pumps.
Slowhawk is offline   Reply With Quote
Old 06-15-2014, 07:22 PM   #3
LS3 SS
LS3 SS's Avatar
PM sent.
Old 06-16-2014, 09:28 AM   #4
realsquash
realsquash's Avatar
Drives: Four Door Camaro
What's a twin ZL1 pump? The ZL1 is a single pump. Are you running a CTS-V based dual pump then?
Squash Performance LLC
2010+ Camaro 800 LPH fuel systems
realsquash is offline   Reply With Quote
Old 06-16-2014, 11:38 AM   #5
thebeast916
Drives: Blown G8 GT
Squash FTW! Never want to be out of fuel.
thebeast916 is offline   Reply With Quote
Old 06-16-2014, 12:47 PM   #6
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Dont skimp on the fueling.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 06-16-2014, 12:58 PM   #7
H-E
Drives: 2010 zr1 Camaro 2011 vert
I have the twin setup in mine at 800rwhp with no issues .I had Alvin tune my car once and had an issue like yours and found a cracked bucket.Replaced and all was good.
H-E is offline   Reply With Quote
Old 06-17-2014, 06:30 PM   #8
LS3 SS
LS3 SS's Avatar
Which twin pump setup do you have? There's more than one company that makes a Twin pump system, and not all are created equal, that's for sure.
Old 06-18-2014, 07:20 AM   #9
H-E
They all use the ctsv pumps...I have the livernios at 800 rwhp.no issues
Old 06-18-2014, 11:16 AM   #10
LS3 SS
LS3 SS's Avatar
Well the bucket definitely wasn't cracked when I looked at the system, and when it was installed it wasn't cracked either. And there is another member on here that is at 650 rwhp with the same system and has the same pressure drop issues I am experiencing.
Old 06-18-2014, 11:49 AM   #11
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Its controlled by a hobbs switch right? Is that working properly?
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.8@143mph
bct10985 is offline   Reply With Quote
Old 06-18-2014, 01:02 PM   #12
Ryne @ CMS
Ryne @ CMS's Avatar
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra
if he is running twin ctsv pumps on the stock returnless system, i am not all surprised if he is seeing "some" pressure drop at a 700+ hp level.
Ryne @ CMS is offline   Reply With Quote
Old 06-18-2014, 01:11 PM   #13
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I'm running the ADM twin pumps and I'm at 740rwhp. I didn't get to watch it on the dyno when Andy tuned it but I'm sure if there was a fuel pressure issue he would have told me.
MODS:
Old 06-18-2014, 03:29 PM   #14
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
PRC 255 heads
1 7/8'' LTs
ID850s
We use the LPE Twin pumps which are the CTSV with custom fuel pump control modules to work in the Gen5 camaro.
We have run over 800 RWHP with no pressure drop on LS3 and 750 RWHP on L99 cars.
But I also know that there is always the Possibility to get a bad pump once in a while so we check every one we do on the dyno and with logging at the track.
Here we are 4 years later and we are starting to see fuel pumps go soft if you will.
94guy had the ADM version of the LPE system for 3 years then all of a sudden one day I noticed the fuel pressure dropping in one of his logs and he noted a loss in MPH.
Changed out the pumps and all is well and the MPH is back even better.
I think this is simply a case of a weak pump.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
