Emblempros
Old 06-15-2014, 08:21 PM   #1
WiredAVS
WiredAVS's Avatar
Drives: '13 Cadillac ATS '14 Camaro 1LE
Holley Covers and Catch Can
Ok....I've tried searching and have come up with a lot of info but nothing to help aid here....
I'm running into an issue with excessive oil in the catch can after installing the Holley rocker covers. Im using the Original Elite Catch Can two port with no check valves. I spoke with a few different individuals about the setup Including Elite and pretty much got the same opinions with the whipple installation.
A 10 mile trip will fill the can to the half way mark! Im coming from the driver back port of the cover to the top of the can and the side of the can to the blower.
On the passenger side I've tried a couple of different setups along with the catch can on the drivers side.
I've tried:
-Keeping the oil fill cap and routing the passenger port to the intake tube
-Using the 1LE separator(removes oil fill cap and routes to intake tube) and blocking the passenger port on cover
-Installing an additional catch can between the passenger port and intake tube
so far all have yielded the same result with the only exception being I trapped oil on the passenger side when I installed a catch can as well. Only a tiny bit.
Im not a big fan of using an open breather on the passenger cover so I'm looking for options.
Im wondering if the holes in the baffle of the holley's are getting hammered by oil slung off the rockers and filling the baffle causing the oil to be sucked into the can. I have removed the covers and inspected them side by side. The passenger side baffle is pretty spot on to the factory covers. The holes are nearly in the same spot. Also the Holley baffles are nearly identical to each other as well. However on the driver side there is a quite a bit of difference. Ive included driver side pictures.
Before I swapped the covers I did make the same 10 mile trip with catch can installed and did not get any oil. I drive pretty much the same all the time so thats not a factor. If I empty the can and make the run it will come back with oil in the can. Something is not right.
Im going to put the factory cover back on the driverside and see if i get any oil in the can.
As you can see the main inlet hole on the baffle is off. On the factory cover the hole is over a hump in the head that could possibly help shield oil from flowing into the hole. On the Holley the hole is directly between two pushrods. Really don't know how oil flows inside the head so I could be way off here.
Factory inlet
Holley inlet. Also notice the slots at the bottom. These are present on both of the baffles on the passenger side, the Holley and the factory. However it's not on the driverside factory.
This is the only other hole of the factory driver cover besides the larger opening. It is near the port side of the cover.
Holley port side. Again the two slots. I'm sure they are for draining oil that gets caught in the baffle. But why none on the factory driver?
Factory port. This is the one everyone says to drill out.
Holley wide open.
Any ideas?
ePhone
2014 Camaro 2SS/1LE AGM/768rwhp
Recaro's, Custom Autometer Gauges, Hotchkis 1" Lowering Coils, CAi Intake, Elite Catch Can's, 1 7/8" StainlessWorks LT's w/Hi Flo Cat's mated to factory NPP Exhaust, 160* Thermo, NightFury Cam, 2.9l Whipple on Meth @ 11lbs, JoeGibbs LS30 in the CrankCase, Built by Nick, Steven, and Tuned By Shawn at Lethal Racing....
WiredAVS is offline   Reply With Quote
Old 06-15-2014, 09:01 PM   #2
Blownhotrodder
Blownhotrodder's Avatar
Drives: Z06
Ive got Holleys on mine with no issues but im not force inducted.
Blownhotrodder is offline   Reply With Quote
Old 06-15-2014, 09:31 PM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Holley rocker covers here but an RX single checked catch can. Routing as follows per SLP.
Air tube post MAF to pass rocker cover. Valley cover blocked. Driver rocker cover to RX single cc. CC to SLP blower vac port.
I get a few drops of oil and some condensate at each drain. Usually after a fill up of corn.
No issues. 10 psi boost and a few pulls each 50 mile drive.
As you discovered, the OEM covers barely breath at all. Need to be drilled out for most boosted apps or a breather on the rocker to prevent crankcase overpressure. I run a checked Metco breather from JRE that lets overpressure vent but no air in via the breather.
Iam Broke is offline   Reply With Quote
Old 06-15-2014, 10:22 PM   #4
WiredAVS
WiredAVS's Avatar
Broke, your check valve is inline with the fitting going to the blower?
ePhone
Old 06-15-2014, 10:32 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
I'd have to look tomorrow but it is in one of the the catch can fittings allowing the SC vac port to draw air in. I can't remember if it is on the SC side or the rocker cover side, not that it would matter.
Old 06-15-2014, 10:48 PM   #6
WiredAVS
WiredAVS's Avatar
What I'm wondering is if the check valve could possibly be slowing down the amount of vac?
I'm going to make some calls tomorrow and pick some brains
ePhone
Old 06-16-2014, 10:25 AM   #7
WiredAVS
WiredAVS's Avatar
Pulled the holley, put back on the factory cover on the Driverside, and drove the 10 mile trip.
After reaching norm temps, hammered down on it a few times and replicated my normal driving habits.
Got back and checked the can. Only maybe a teaspoon of oil in the can. Crap.......
Old 06-16-2014, 10:35 AM   #8
WiredAVS
WiredAVS's Avatar
i just stumbled across this as well! This is from GM Tech Bulletin 01-06-01-011h
Might be on to something here.
photo taken from here :
http://www.camaro5.com/forums/showpo...7&postcount=85
Full read:
http://www.camaro5.com/forums/showth...ght=valley+pcv
Old 06-16-2014, 11:41 AM   #9
simon.w
Drives: 2011 2SS RS 6M Inferno Orange
Have you done a leak down test? Same issue I had ... three broken ringlands.
simon.w is offline   Reply With Quote
Old 06-16-2014, 12:04 PM   #10
WiredAVS
WiredAVS's Avatar
I have not nor do I think a leak down is needed at all. 3300 miles car runs strong, 100 miles on blower install, tuned and built by Lethal Racing.
Car wasn't having any drive ability issues.No smoking or anything to that nature.
Really no issues using the factory covers with the blower either. I reconfirmed that this morning by swapping them back out. Just wanted to add a little dress up to the engine bay and the Holley fit the bill.
After looking at where the vapor inlet is on the Holley and where it is in relation to the valve train I strongly believe that oil is just slinging into the hole and has no choice but to go to the can.
With the GM bulletin posted above, it kind of goes along the lines of what I was thinking.
I do appreciate the help.
ePhone
Old 06-16-2014, 12:16 PM   #11
Unreal
Drives: 2006 Z06
Holley covers on my car. No issues.
Nick
Corvette Z06 -1200ish rwhp
Old 06-16-2014, 12:35 PM   #12
BLACK10
BLACK10's Avatar
The whipple pulls such a strong vacuum that it pulls all and any oil mist threw a unmetered catch can system along with the holly covers that have the much freer flowing vacuum port.
Old 06-20-2014, 12:19 PM   #13
WiredAVS
WiredAVS's Avatar
update:
After numerous emails, text, and calls, I have finally figured out how to fix my issue with the Holley Valve Covers.
I would like to thank Nick@Lethal Racing, Tyler@JDP Motorsports, and Tracey@Rev eXtreme(RX) for offering their knowledge about the PCV system. I have learned a lot about proper evacuation of harmful vapors. With a combined gathering of information from you guys, I was able to come up with a solution that seems to be working for my application.
I currently have put over 100 miles of testing using the holley covers and my re-routing of the PCV system. I'm glad to say I have what I call a normal amount of oil in my catch can. Actually about the same amount that I was collecting with the factory GM covers in place after the whipple install.
My setup:
(2) Elite Catch Cans - Single Outlet original versions without check valves.
Dirty Side
-Valley Cover port (LS3) to Inlet of 1st CC
-Outlet of CC to Vac of Whipple post Throttle Body (Glass Inline Filter *not permanent)
Clean Side
-Driver Valve Cover to Passenger VC tee'd to Inlet of 2nd CC (yes Inlet. This allows filtering of the VC mist when it goes from drawing air to relieving air, usually under/after WOT)
-Outlet of CC to Intake Tube post MAF (Glass Inline Filter *not permanent)
I'm using the glass filters to monitor reversion from the VC's as well checking the effectiveness of the CC's. So far all seem to be doing as planned. Time will tell.
I could eliminate a catch can by using the Elite/RX/Factory 1LE separator. This would allow me to connect the VC's directly together making a cleaner install and the 1LE separator to handle the air in/and trap the oil dropping it back into the VC on relief.
I'm not seeing any signs of excessive crankcase pressure and no smoke coming from the back under hard throttle. Again time will tell but I think I'm good for now......that is until Nick drops a pulley!!!
Thanks to all that helped!
Old 06-20-2014, 12:37 PM   #14
Silver2S
Silver2S's Avatar
Drives: 2012 Silver Camaro SS 2SS
I had the same issue on my LS2 SS Trailblazer that was cammed. The catch can was filling up half way every 220 miles. Found out that the driver side valve cover was changed to an updated version. Looks just like yours. After I installed this new valve cover there was barely anything in the catch can. I would stick with the stock valve cover until Holley fixes their issue.
Silver2S is offline   Reply With Quote
