Emblempros
Old 08-08-2009, 05:38 PM   #1
logan1080
logan1080's Avatar
Drives: 2003 Crew Cab Duramax
Prep work when applying Vinyl decals.
Besides making sure the surface is spotless, what things should we do before applying vinyl decals? heat up the surface at all or anything like that? I am putting some decals on my bowties so I am just curious, I want them to look perfect.
logan1080 is offline   Reply With Quote
Old 02-10-2011, 12:19 PM   #2
THEO
Drives: 2010 2LT inferno orange camaro
clean the surface with some rubbing alcohol on a micro-fibre to remove any wax or grease etc.....then take a small sray bottle filled with water add a few ( 3 ) drops of Sunlight dishsoap shake it up a bit ......spray your decal sticky side .......this will allow you to position where you want it ......once in place use a small squeegie or credit card ( wrapped with the microfibre ) and squeegie out the excess water and let dry and your good to go
THEO is offline   Reply With Quote
Old 02-10-2011, 02:11 PM   #3
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
I also clay bar the area.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 120 07-31-2016 05:37 PM
This site is like crack. You know you're addicted to Camaro5 when... GameOver620 5th Gen Camaro SS LS LT General Discussions 463 01-03-2011 02:28 PM
RiderGraphix - AVOID Moonsault Cosmetics and Lighting Modification Discussions 80 06-28-2009 02:02 PM
