Cold Air Inductions
Old 06-16-2014, 07:56 PM   #1
kold
kold's Avatar
Drives: 2011 LS White Camaro
how to make my ride smoother
Hey guys, sorry if this has been asked b4.
Was wondering how i could make my ride smoother, have a 2011 v6 camaro that is sitting on some eibach lowering springs right now and i can feel every pebble i go over. Looking for something to make the ride smoother, please leave suggestions down below.
kold is offline   Reply With Quote
Old 06-16-2014, 08:00 PM   #2
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
First step will be to get rid of the bouncy Eibach's and possibly pick up some new struts. How many miles do you have on your car?
Best regards,
Tyler
888-308-6007
Old 06-16-2014, 08:06 PM   #3
MLAZ1990
MLAZ1990's Avatar
Drives: 2012 black camaro 2LS
Buy a Mercedes
SLP Loud Mouth 1 Exhaust, K&N CAI, RS Headlights, NightOwl V2 halo kit, ZL1 Grille, Custom 2LS Emblems, Green Footwells, GM GFX splitter, Ace Alloy Convex All Matte Black Wheels(20x9 & 20x10.5) wrapped in Toyo Proxe STII(255/45/20 & 295/40/20)
MLAZ1990 is offline   Reply With Quote
Old 06-16-2014, 08:19 PM   #4
ssrs2lt
ssrs2lt's Avatar
Drives: too many
I spent lunch looking for this answer. all I find is smart ace comments or track set ups.. good luck, I hope ya find a way..
ssrs2lt is offline   Reply With Quote
Old 06-16-2014, 08:31 PM   #5
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
I agree get rid of those lowering springs and see if you can go back to stock. Also what size wheels and tires do you have. If they are large wheels with very low profile tires you could go back to a smaller wheel and use a tire with a larger sidewall height.
The Bird is the word!
Old 06-17-2014, 10:24 AM   #6
tooheysmax
Drives: Black 2SS RS
Air suspension is only way its going to get smoother. Remember the smaller the spring the tighter the coils are wound and the more rigid it will feel. And cut coils which I am aware you do NOT have basically cause a weak point in the spring and for it to collapse.
tooheysmax is offline   Reply With Quote
Old 06-17-2014, 11:01 AM   #7
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Stock V6 springs, larger sidewalls on the tires.
Honestly, Camaros were not designed to be a smooth ride. This much weight and this much horsepower needs a certain level of rigidity to keep everything where it's supposed to be (namely, the car on the road). If you like the power but want something smoother, check out the Caddilac CTS's.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 06-17-2014, 12:29 PM   #8
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
air.
Chris14RS is offline   Reply With Quote
Old 06-17-2014, 01:19 PM   #9
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Eibach's are the worst riding springs on the 5th gens, they are also the cheapest, see were i'm going. You get what you pay for.
If you want the lowered look, better handling than you currently have and great ride quality get yourself a set of Hotchkis springs. I have swapped out Eibach's for Hotchkis at least a dozen times over the last 4 years at my shop for ride quality alone.
And as mentioned in one of the posts above, when you switch them out check your shocks and struts, depending on your mileage and use they may need upgrading.
Good luck.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 06-17-2014, 04:02 PM   #10
kold
kold's Avatar
thanks for those that helped. Yeah i have thought about getting some better springs i got the eibachs cause they where super cheap i think i payed 100 for them off another member. Car currently has about 50k miles on it, and is a daily driver. I thought about going stock again but i really like the stance i get with the lowering springs, any 1 have any recommended spring brands and links? i understand i will need to pay for more comfort and to be honest if i could just get the stock comfort with the lowering springs stance that would be good enough, i just feel like the eibachs are not very good and i literally can feel anything i go over. Will def look into some hotchkis springs
Old 06-17-2014, 04:02 PM   #11
kold
kold's Avatar
btw car is sitting on the stock SS rims and tires.
Old 06-17-2014, 06:23 PM   #12
JDP Sales
JDP Sales's Avatar
The Hotchkis springs are very good and are one of the best riding springs out there. With you having 50K miles on your struts, they are nearing the end of their life as well, so I'd recommend picking up some 1LE Struts to replace them with at the same time.
Let me know if I can help you further.
Best regards,
Tyler
888-308-6007
Old 06-17-2014, 06:30 PM   #13
Angrybird 12
Best regards,
Tyler
888-308-6007
Won't 1LE struts be stiffer and make the ride harsher?
Old 06-17-2014, 06:39 PM   #14
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Yup.
OP. Get a set of stock springs. That's going to be the best ride.
Then step down to an 18" wheel and tire package. Maybe 19s. If you're DEAD SET on keeping the 20s, look into a softer all-season tire.
-SLAMMED LOOK
-BIG WHEEL/TIRE
-RIDE QUALITY
Pick TWO. That's all you get.
shibbs is offline   Reply With Quote
