Old 06-16-2014, 08:16 PM   #1
mlc67ss
424 RWHP and counting
mlc67ss's Avatar
Drives: 2010 2SS/RS RJT M6
Pedders XA rear coil over leaking
I have one Pedders leaking. I am thinking that if I send it to Cali to have it rebuilt I should go ahead and send the other one at the same time.
Does anyone know if once you send in a Pedders to get fixed is it fixed back to original or is it fixed fixed.
I think the answer to this will determine if I repair or replace. and if I replace what is the "way to go" on a car that has the suspension heavily modified for road racing?
Here is the rest of the suspension system
Racing Brake stainless steel brake lines
RJT Powdercoated calipers
Motul 600 DOT 4 brake fluid
JDP Quantum brake cooling duct kit
Stock rotors
Stock pads for street
Hawk DTC-30/HP+ pads for track
BMR front adjustable sway bar
BMR front adjustable end links
BMR trailing arms
BMR Pro Poly differential bushings
BMR Delrin UCA bushings
Pfadt outer TA bushings
Pedders full Poly cradle bushings
Pedders XA coilovers lowered 1 1/4"
Pedders radius rod inserts
Pedders rear camber bolts
Pedders FE4 rear Z bar
Pedders rear drop links
GM FE4 LCA's
GM ZL1 toe links
Thanks for your help
Matt
mlc67ss is offline   Reply With Quote
Old 06-16-2014, 09:39 PM   #2
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Where are you sending it?
Deftones is offline   Reply With Quote
Old 06-17-2014, 07:49 AM   #3
mlc67ss
mlc67ss's Avatar
Still looking
Old 06-17-2014, 02:26 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
If you found a place to repair, I'd probably send both to be sure they both end up the same; Possibly even have them put on a dyno to be sure.
If not, the RideTech coilovers are a good option. They are available separately front and rear, so you can still hang onto your fronts. We've been switching quite a few people over lately. Let me know if you have any questions.
Best regards,
Tyler
888-308-6007
Old 06-17-2014, 06:39 PM   #5
mlc67ss
mlc67ss's Avatar
Tyler do you know of a place I could send them for repair?
Matt
Old 06-17-2014, 06:42 PM   #6
JDP Sales
JDP Sales's Avatar
Matt
I don't.. If you find somewhere, please share.
Best regards,
Tyler
888-308-6007
Old 07-02-2014, 07:05 PM   #7
octane
octane's Avatar
Drives: 2010 black lingenfelter
Rob Anderson at wretched motorsports sent me a pm saying he could get them fixed for 100 each but I just installed the ridetech rears today so I will be contacting him soon
[/SIGPIC]600 hp lingenfelter TVS 2300 package pedders springs adjustable struts sways all bushings brake hose kit cold air fuel pump boost twindisc clutch 1400hp axles 3.70 gear borla cat back badging coil covers floor mats lpe pedals 20"forgelines nitto,s, idealg master, clutch res,,lethal racing cam package with oil pump pushrods timing chain ,meth kit ,zl1 pump ,kooks 1 7/8 high flow Kats , ridetech rear coilovers ,air fuel gauge, fuel pressure gauge , shift light ,way cool awsome set up love it!
octane is offline   Reply With Quote
Old 08-20-2014, 08:53 PM   #8
mlc67ss
mlc67ss's Avatar
Well here you go sports fans if you have a broken or leaking coilover send them to Feal Suspension in Cali
http://www.fealsuspension.com/
Old 08-20-2014, 10:36 PM   #9
smokum
smokum's Avatar
Drives: 2010 2ssrs
They did a great job on my supercar awhile back. Still works perfect.
smokum is offline   Reply With Quote
Old 08-20-2014, 10:50 PM   #10
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Good to know.Glad the rebuilds hold up.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And DSE swaybars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is online now   Reply With Quote
Old 08-20-2014, 11:30 PM   #11
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
That is awesome news for us folks that have pedders or pfadt coilovers and need to have them rebuilt.
CHMSC is offline   Reply With Quote
Old 08-20-2014, 11:41 PM   #12
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Excellent news! Thanks for this. Hope my supercars hold out till JusticePete.com is in business! If not, i know where i can send them.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
