Cold Air Inductions
Old 06-17-2014, 02:34 PM   #1
motogplvr
motogplvr's Avatar
Drives: 2010 1SS M6 460rwhp
Suggestions ECS 1500 kit/fuel
Thinking about which S/C kit I want to go with. The ECS Novi 1500 kit looks like a good setup. Right now I am only shooting for 650rw so I think I would stick with the Paxton head unit. I seriously doubt I will want to go higher on this for quite a while.
Will the 60/lb hr injectors that come with the kit support 650rw when coupled with a ZL1 pump + ADM FCPM? I am not trying to spend $1000 on a dual pump system if it isn't required. It seems like this would be sufficient from what I have seen on the forums.
Car is currenlty:
2010 SS M6 (454rwhp)
LMR CAI
2inch primary LT's, 3in xpipe, 3 in all the way to the tips
Tick Performance Stage 2 blower cam
planned:
ECS Novi 1500 kit
ZL1 fuel pump/ADM FCPM
If the 60lb/hr injectors won't be sufficient I was thinking about these FAST 85lb/hr injectors (good price)
http://www.amazon.com/FAST-30857-8-P.../dp/B002EDX4KY
motogplvr is offline   Reply With Quote
Old 06-17-2014, 02:58 PM   #2
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
The quick answer is yes. i ran the base kit w/meth and headers and made 684whp. However, since you have a blower cam, you may want to upgrade the injectors
SuperchargedStealth is offline   Reply With Quote
Old 06-17-2014, 03:01 PM   #3
TitusSS
Drives: ECS Supercharged 2010 SS
I don't have a cam but I have the ECS kit and long tubes. I ran out of fueling at ~570HP with 8lbs boost. I have since added a ZL1 pump (still using BAP) and will be putting in ID850's and opening up the restrictor plate. Hoping for around 650 HP. So my guess is even with the cam you will run out of fueling at anything over 600HP. But that is just based on my experience, YMMV.
TitusSS is offline   Reply With Quote
Old 06-17-2014, 03:03 PM   #4
motogplvr
motogplvr's Avatar
Yes but did you use the ADM FCPM in conjunction with the ZL1 pump? Seems (just from reading here) that the FCPM is required to get any real benefit from the ZL1 pump.
Old 06-17-2014, 03:06 PM   #5
motogplvr
motogplvr's Avatar
I'm not wanting to run meth...just plain 92 octane here in WA.
Old 06-18-2014, 10:11 AM   #6
TitusSS
that is incorrect. You can use the ADM FCPM or you can use the BAP. Both of them overdrive the pump with additional voltage. I'm not sure where the idea that the BAP does not work with the ZL1 pump came from but it really does not make any sense.
Old 06-18-2014, 10:24 AM   #7
ToddB
Drives: 2011 2SS Convertible Supercharged
You need the FCPM to get the full benefit of the ZL1 pump. The bap will not give you the full benefit of the ZL1 pump. There is plenty of information on here if you look for it.
2011 Camaro SS, LS3,Whipple SC, 13 PSI,CAI intake, ARH 2" Headers, Corsa exhaust, ZL1 fuel pump with ADM FPCM LS9 Cam and Meth,ID850, BMR suspension upgrades,Tune by JRE
ToddB is offline   Reply With Quote
Old 06-18-2014, 10:25 AM   #8
ToddB
Or ask ADM they will tell you they make the FCPM.
Old 06-18-2014, 01:55 PM   #9
TitusSS
I'm not trying to be argumentative but I would love to see some data to support this. Does it have something to do with the limitations of the existing FCPM? I am curious because I'm running just the BAP and ZL1 pump and I don't want to run lean due to ignorance.
Old 06-18-2014, 02:01 PM   #10
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
upgrade the 60# injectors that come with the ECS kit? do they give you an option to go with bigger injectors (duty cycle)?
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
Old 06-18-2014, 03:46 PM   #11
prdi
Drives: CTS-V
Yes you can upgrade the injectors to 80s if needed.. 60s will make the power you want no problems. your pump will be your weak link but you are upgrading to the zl1 pump. The 80s are a cheap upgrade if getting them with the ECS kit
prdi is offline   Reply With Quote
Old 06-18-2014, 05:23 PM   #12
motogplvr
motogplvr's Avatar
How much crank HP would the 60lb/hr injectors be good for? What duty cycle estimate would you get at about ~775 crank hp?
The FAST injectors I linked from Amazon in this thread look good, but I wonder who really manufacturers them. I figure they are probably re-branded. If I could get 80s with the kit for a small price bump then I would just go that way.
Old 06-18-2014, 05:43 PM   #13
motogplvr
motogplvr's Avatar
Check out this thread all the way through. Someone logged in hptuners ZL1 + BAP vs. ZL1 + ADM FCPM and the results speak for themselves on it. I am with you I would figure you could just use a BAP in conjunction to get the benefit, but it appears that is incorrect. I would just get the FPCM from ADM. That is what I will do as well as 80+lb/hr injectors.
http://www.camaro5.com/forums/showthread.php?t=288902
Old 06-18-2014, 06:08 PM   #14
prdi
Drives: CTS-V
i sent you a PM motogplvr
